Old 04-04-2020, 03:59 PM   #1
1976 23' Safari
summit , Montana
What in the world?
Does anyone else have these pipes in their bathroom? We just got this Argosy 24 and these black pipes take up a ton of space. They are not sealed together, but we have no history on what has been done or not to this project. Any ideas what this is for and if we can tear it out? Pic attached
ID:	364842   Click image for larger version
coco97 is offline   Reply With Quote
Old 04-04-2020, 04:17 PM   #2
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Plumbing vents. Probably meant to be inside or next to a closet wall. Your waste tanks need to be vented or you will not like the smell.
Old 04-04-2020, 04:31 PM   #3
1976 23' Safari
summit , Montana
Thanks! Wondering if all of these are overkill, seems like one smaller pipe would do just fine?! When space is so valuable ��
Old 04-04-2020, 04:33 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
That's what size the standards say they are supposed to be.
Old 04-04-2020, 07:02 PM   #5
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
These lines perform multiple functions. They do keep odors away from the interior, but the also allow air to escape the tanks when draining water into the tanks from sinks/shower/toilet. When you drain your tanks they also allow air into the tanks so a vacuum isn't created slowing down the draining. Smaller lines can compromise these functions. Your choice.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 04-04-2020, 09:00 PM   #6
1976 23' Safari
summit , Montana
Anyone care to post what your lines for this look like?!
Old 04-04-2020, 09:10 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
We had a 75 TradeWind and the plumbing looked very much like what you have. All of the pipes were out of sight inside a closet area in the bathroom.
Richard
Old 04-04-2020, 09:10 PM   #8
1976 Argosy 26
Reidsville , North Carolina
28í
Iím replacing rear bath floor in 28í. My vent pipes look very similar to exactly like yours. I cut off for the floor rot and will slice back together
76argosy is offline   Reply With Quote
Old 04-05-2020, 06:20 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
My guess...all that was hidden. The open pipe is the sink drain. The line up the rt side was where the wall fastened to hide all the pipes.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Instead of going to íStarbucksÖI make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire"
Amanamus
Tahawus....🌥
Old 04-05-2020, 10:08 AM   #10
1996 25' Excella
Tillsonburg , Ontario
You can reroute them just use 45 elbows not 90 degrees
Personally I wouldn't have a problem going one pipe size smaller IF they are 1 1/2 inch but I don't think you gain much room by doing that.
JCW
JCWDCW is offline   Reply With Quote
Old 04-05-2020, 12:12 PM   #11
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
You need the venting, but you certainly can re route, with an assortment of fittings, to hug the wall and not waist so much valuable space. Notice the oversized hole in the floor, typical airstream, quality, think of the poor little mice, needing easy access to the inside
bibbs is offline   Reply With Quote
Old 04-05-2020, 02:27 PM   #12
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
You can also use P-trap vents for under the sink: Trap Vent
HOWEVER... if your tank ever fills up all the way, it could overflow through this thing! I'm thinking about 3D printing myself a trap that has a tube sticking up higher than the sink drain, which would solve the problem.
SuzyHomemakr is offline   Reply With Quote
Old 04-06-2020, 07:21 AM   #13
1976 31' Excella 500
Chappell Hill , Texas
Plumber here, That's your gray and black tank vents and lavatory p-trap and vent. Plumbing code said that vents can only be tied together above the flood rim of the highest fixture (top of sink in this instance).
tbashin is offline   Reply With Quote
Old 04-12-2020, 07:33 PM   #14
1976 Argosy 26
Henderson , Kentucky
Images: 16
All are good responses. This looks like my rear bath 76 Argosy. There was a closet then a vanity/sink positioned at rear of trailer where drain pipe and water lines are located. Lateral pipes are under vanity. Wall brackets are on back wall where side wall for closet was located and upright pipes are just inside wall of closet.
Ky76Argosy is offline   Reply With Quote
Old 04-12-2020, 08:20 PM   #15
2018 25' International
Slidell , Louisiana
Returning to the pipe sizes, the plumbing code is based on years of best practices, gleaned from the school of hard knocks. As others alluded, smaller vents tend to back up with water, slowing drains, forming pressure vacuums and siphons that empty your p traps, back up into other fixtures, and generally increase all the annoying gurgling sounds of plumbing being drained. I don't advise using smaller vents.
Brian
Old 04-12-2020, 09:35 PM   #16
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lafayette , Colorado
Yep, Argosy rear bath drain and vent pipes... What to do with them and everything else in that busy rear corner of the trailer. Black tank and toilet, power inlet and charger/converter/fuse box, bath plumbing etc. We didn't reuse anything in the picture except the main vent stack (make sure to reseal it at the roof). Start with a thorough floor inspection, I'd be surprised if there wasn't some issue under/behind the black tank. Then about that 12 gallon gray tank under the floor, maybe upgrade that? We removed the black tank/toilet and use a PortaPotti Curve. Installed a 35 gallon gray tank. re-plumbed the shower, moved the vanity to the streetside wall and re-plumbed it with proper but more streamlined drain and vent runs. After 4 years we're very happy with it. Also ran a new 30 amp inlet and replaced the converter/charger and fuse box and added solar all in that back corner.
Just a couple thoughts, skies the limit...
Argosy on, Mark D
mrdes8 is offline   Reply With Quote
"Small World" forum experience mcneon Our Community 3 03-07-2004 02:40 PM
Buying mattress pad? beware of Camping World false ad. femuse Our Community 5 03-19-2003 06:55 PM
Camping World - No A/C Pan? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-25-2002 08:55 AM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
