Old 05-01-2021, 09:49 PM   #1
1973 29' Ambassador
Conway , Arkansas
Vinyl wallpaper options
Just purchased an 73 ambassador with center bathroom. The interior walls ate very nasty and we’re looking for your opinions on what you’ve done and what most people do.
1) clean and restore
2) clean and prime for paint
3) remove and rewallpaper
4)?
Ambassador73 is offline   Reply With Quote
Old 05-02-2021, 06:34 AM   #2
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
My wife really wanted a subway tile. I found these on Amazon which had bad reviews. Most of the bad reviews were the tiles peeling. I also noticed that those individuals adhered them to a backsplash behind the cooktop where there can be excessive heat. It states right in the instructions, not to use in areas with excessive heat. Anyway, I installed mine 2 months ago and no issues. They look nice, they do feel like rubber and not subway tile.
https://www.amazon.com/gp/aw/d/B088C...b_b_asin_title
s1000pre is offline   Reply With Quote
Old 05-02-2021, 06:59 AM   #3
1966 22' Safari
Fredericksburg , Texas
People have done all the above. I guess it’s what you want the finished product to look like and it’s durability. In our 66 we stripped the wall covering, primed and applied Zolatone. A friend of ours stripped the loose vinyl and installed 1/16” Plastic Polywall from the box stores. I looked at it afterwards and it looked great. I guess you could repair, but it came loose once, it’ll do it again. Good luck
Bubba L is offline   Reply With Quote
Old 05-02-2021, 08:52 AM   #4
1973 23' Safari
Arroyo Grande , California
Greetings. Is the wall covering damaged or sticky and dirty? The walls in our 73 Safari were very dirty when we brought it home and we were advised to scrub the walls with Spic and Span in hot water and the rinse. After they dried we then wiped on Mop and Glo to seal them. Some say the original glue for the vinyl covering used on this era would out gas and cause the walls to become sticky. We did this about three years ago and the walls still look good.
Steve
StevenD is offline   Reply With Quote
Old 05-02-2021, 09:09 AM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
My 25' Safari was bought used and the PO had nailed and stuck photos to the bathroom walls. We got a good deal on it so decided to cover up their work with a pre pasted wall paper. We did a western theme and papered all of the walls of the bath room.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 05-02-2021, 09:31 AM   #6
CC
1972 27' Overlander
Heinsburg , AB
I am working on a '72 overlander. I have cleaned what I can, stripped a portion that had a small piece of the vinyl peeling, painted and applied peel and stick paper. I have to try the spic and span mentioned above; I still have sticky parts. The portion of the vinyl that I stripped was PAINFUL; I can't imagine doing the whole trailer. The painted parts are bright and clean. I have had issues with the peel and stick. If you choose this, I would recommend spending a bit more money. Over the winter, I have had the cheaper vinyl come off the wall completely. It would be great to see some before and after pictures. Anything will be an improvement. Good luck.
CC
Camper Crazy is offline   Reply With Quote
Old 06-13-2021, 04:52 PM   #7
Ron Glow's Avatar
2018 27' Flying Cloud
Haubstadt , Indiana
Peel and stick wallpaper
My wife wanted this wallpaper in the bathroom. I removed the toilet and mirror cabinet and it was still tight and difficult, but worked out in the end. I used a pin to poke a tiny hole in any bubbles and pushed the air out.
Ron
ID:	397372   Click image for larger version
Ron Glow is offline   Reply With Quote
Old 06-13-2021, 05:12 PM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Krud-cutter will almost take the sticky off the old Airstream vinyl wallcovering. I use the Krud-cutter then wash with a soap and water and finally with fresh water. Does a pretty good job. In a few years the sticky comes back. I do think it is coming through the vinyl from the adhesive.
Old 06-13-2021, 08:55 PM   #9
G-Ranch
G-Ranch's Avatar
1970 25' Tradewind
Smyrna , Georgia
Vinyl wallpaper solution
We have a 1970 Tradewind with vinyl on aluminum interior. The interior was dismantled and interior skins removed.
Set up a large work bench to thoroughly clean and paint the skins and bathroom fiberglass 1/4 dome. Used PPG Breakthrough paint. Absolutely the way to go.
G-Ranch is offline   Reply With Quote
Vinyl wallpaper in bathroom merseyo 1969 - 1973 Safari 1 07-27-2019 12:49 PM
Best way to remove Vinyl from interior vinyl clad Eric H General Interior Topics 11 10-21-2013 11:32 AM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 07:50 AM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 03:38 PM
Removing vinyl wallpaper/paint GAS Upholstery, Blinds, Walls & Interior Finishes 19 07-21-2003 12:35 PM
