Old 11-24-2016, 10:18 PM   #1
1976 Argosy 28
Hazlehurst , Georgia
Smile stripped interior skins, what primer/paint to use.
We have gutted, replaced interior wiring, insulation. Moving on to putting the stripped skins back in. We want to paint. Our question what paint and or primer to use on the stripped interior skins. Thanks for your help.
LittleRedHen is offline   Reply With Quote
Old 11-25-2016, 06:49 AM   #2
1966 22' Safari
Fredericksburg , Texas
We stripped the vinyl off our interior skins on the 66. This was the first year AS switched from Zolatone to vinyl. May not be period correct, but the vinyl was in bad shape. We primed with Kilz Adhesion to make sure the Zolatone system bonded well. We will be using the same on our 55.
Hope this helps.
Bubba L is offline   Reply With Quote
Old 11-25-2016, 07:43 AM   #3
1976 Argosy 28
stripped skins, what paint/primer
Thank you Bubba L. Kilz adhesion may be the answer were looking for.
Sincerely
Little Red Hen
Old 11-25-2016, 06:38 PM   #4
1973 31' Sovereign
Minneapolis , Minnesota
I used both Kilz and Zinsser both. sand, wash, primer, sand, wash, primer, sand, wash paint, sand, wash, paint, sand, wash and paint.
How many layers was that again?
fairtheewell is offline   Reply With Quote
Old 11-26-2016, 09:32 AM   #5
1976 Argosy 28
Stripped Skins. What paint/primer?
Fairtheewell thank you for your resonse. And number one are your happy with the results? Is it holding up as you had hoped? Thank you again.
Old 11-26-2016, 11:28 AM   #6
1966 22' Safari
Once I had the interior skin stripped and installed, I wiped down the interior with TSP. Once dry I primed with Kilz Adhesive. We couldn't find this particular Kilz locally so we had one of the box stores order for us. Then we used Zolatone Flex with the base coat and finally the top coat. It holds up great and very happy with the results. This is the only roll on Zolatone. This is an incredibly tough, scrubable surface.
Old 11-26-2016, 10:55 PM   #7
1973 31' Sovereign
Extraordinarily happy. Thrilled. It is so many payers because even after cleaning with scrubbing bubbles, those weird white fiberglass sponge things, TSP, vinegar, soap, etc. it was still this 70's yellow. It is now eggshell white and robins egg blue. Dare I say gorgeous. Yes. It is holding up well. Although right now it is just me banging around in it, in the spring I open a store, an apothecary, in her. So I'll be able to tell you then how she holds up with (hopefully) large amounts of traffic.
Old 11-27-2016, 05:01 AM   #8
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Do you have pictures of the finished paint job? It sounds nice.
I hope you post some pics when your shop is up and running.
Dingo Girl is offline   Reply With Quote
Old 11-28-2016, 11:43 AM   #9
vanster's Avatar
1967 17' Caravel
Oakland , California
Before you put the skins back on you should consider sealing all the seams behind the insulation. Wurth Seam sealer is about the best as it's used for joint sealing in German cars. Not cheap but while you have it apart you should consider it
vanster is offline   Reply With Quote
Old 11-28-2016, 05:59 PM   #10
1979 23' Safari
Wayland , New York
Rustoleum makes primer especially for aluminum. I used a self etching primer when I did mine.
Consider hitting all the metal with a orbital sander first, the 'rough' surface helps the paint stick better.
Old 11-29-2016, 02:34 PM   #11
1976 Argosy 28
Thank you and it would have been a great idea. But we are past that point with polyiso insulation taped into place at every seam.
Old 11-29-2016, 02:36 PM   #12
1976 Argosy 28
Yes Thank you we have used that where we found Galvanic corrision. We sanded and sprayed that to stop it.
Old 11-29-2016, 05:36 PM   #13
1973 31' Sovereign
I believe I would be able to post them.
Darn. Just a minute. I'm figuring it out.
Old 11-29-2016, 05:38 PM   #14
1973 31' Sovereign
Please ignore the flooring. I was working on it when I took this photo. <3
Old 11-30-2016, 03:41 AM   #15
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you! The shell looks great. Please post more pics as you progress. ☺
Old 11-30-2016, 06:25 AM   #16
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
LittleRedHen,
We finished our '68 this spring. It has the vinyl on the interior walls, so we cleaned it very well (Simple Green solution and brush), then used a paint called "Cabinet Enamel" from the local Lowes. (They can mix to any color on their color cards.)
We've got about 30 nights in the trailer since and, so far, it's holding up well with no stickiness.
Good luck and enjoy your project,
Roy and Marie
64airstream is offline   Reply With Quote
Stripping silver paint and yellow primer? M. Childs Cleaning, Stripping & Polishing 7 09-08-2013 08:23 PM
What paint primer to use? MrJ General Interior Topics 5 11-08-2011 08:30 AM
Can grey exterior paint be stripped? 4Cochrans Cleaning, Stripping & Polishing 4 11-12-2008 03:51 PM
Battery Primer Over59 Electrical - Systems, Generators, Batteries & Solar 0 04-13-2006 09:12 AM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 11:56 AM
