Old 04-13-2020, 07:52 AM   #41
1973 31' Sovereign
Mantua , Ohio
We have ordered wool for our 31’ airstream. This weekend we installed it in the main door and are very impressed with the sound deadening! I do agree that it dries out very well. We had some stored in the airstream over the winter that got a little wet. It dries out in a few hours! Definitely does not hold onto moisture! We didn’t have any critters try to use it to make nests either! Not even a trace and our airstream is wide open! So far I’m really impressed!! I can’t believe more folks aren’t using this. It resists settling very well! One note is that you need to string up yarn to hold it in place until you get the skins in. We ordered 5 bags or the two inch thick stuff from havelock wool. Each bag does 125sq/ft. We’re not planning on doing the underside with it, but the math i did on the shell is spot on (i hope!). Cheers!
knowmercy is offline   Reply With Quote
Old 04-14-2020, 05:25 PM   #42
1975 Argosy 22 Rear Door
atlantic city , New Jersey
Originally Posted by knowmercy View Post
We have ordered wool for our 31í airstream. This weekend we installed it in the main door and are very impressed with the sound deadening! I do agree that it dries out very well. We had some stored in the airstream over the winter that got a little wet. It dries out in a few hours! Definitely does not hold onto moisture! We didnít have any critters try to use it to make nests either! Not even a trace and our airstream is wide open! So far Iím really impressed!! I canít believe more folks arenít using this. It resists settling very well! One note is that you need to string up yarn to hold it in place until you get the skins in. We ordered 5 bags or the two inch thick stuff from havelock wool. Each bag does 125sq/ft. Weíre not planning on doing the underside with it, but the math i did on the shell is spot on (i hope!). Cheers!
Thanks so much for this response. I also am going to go with wool, and you helped me feel more confident in my decision. Some people said wool smells when it's wet... did you have any experience with that? Also, how did you determine the square footage for 5 barrels at 31 feet? I have a 22 footer and cant figure out how many bags I need. I already insulated the end caps as well. Can you advise?
girasoledonn is offline   Reply With Quote
Old 04-14-2020, 05:43 PM   #43
1973 31' Sovereign
Mantua , Ohio
The wool has a scent. The havelock wool we purchased smells like you a sheep when you put your face up to it. I donít think itís stinky and my wife didnít think so either. From what i observed itís not really any different wet or not. Once we got it in the door i donít detect any more scent.
Okay as for the sq/ft i did my best measurements for the main part of the shell. Letís say the straight portion of my wall is right around 22í. The length of the entire hoop is right at 18.5í (i really think mine was 220Ē from memory). So 22íx18.5í puts us at around 407 sq/ft. I think i mentioned before but the 2Ē bags from havelock cover 125sq/ft. Since you already have the end caps filled you should be able to compute what you need like that. Your airstream is a 75? They should share that hoop measurement. Does this help? Good luck! Keep me posted how it goes. Cheers!
Old 04-14-2020, 08:14 PM   #44
@steadystreamincashios
Zcashio's Avatar
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs , Arkansas
I haven’t used Havelock in an airstream but will one day. But I have used it in a camper van build. Such a great product and no messing with itchy fiberglass and not knowing exactly what’s in the product is worse. The smell of the wool was much nicer than fiberglass or anything else. We wanted something natural. Glad the wool is working for you guys and I hope to use it in an Airstream one day soon. Thanks for the replies after you purchased it
Zcashio is offline   Reply With Quote
Old 04-15-2020, 08:39 AM   #45
van guru
1994 28' Excella
Hood River , Oregon
Thinsulate SM600L acoustic/thermal insulation has several advantages over wool. It is hydrophobic, has no smell at all, contains no borates, less weight, easier to install, and passes all pertinent Federal Motor Vehicle Safety Standards.
All the best,
Hein
Hein is offline   Reply With Quote
Old 04-17-2020, 08:40 AM   #46
tallytwo1994's Avatar
tallahassee , Florida
All the best,
Hein
Hein,
Why do you continue promoting this synthetic product when it has no comparison to a natural product? I take it you work for this company? This just seems wrong to me.
Carol
tallytwo1994 is offline   Reply With Quote
Old 04-17-2020, 12:56 PM   #47
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
I have no horse in this race but after reading up on it this sounds like an excellent product. Placed with spray adhesive it will stay in place and deaden sound effectively too. R value is 5.2.
drairstream is offline   Reply With Quote
Old 04-18-2020, 11:43 AM   #48
van guru
1994 28' Excella
Hood River , Oregon
Originally Posted by tallytwo1994 View Post
Hein,
Carol
Sorry if I offended you, Carol. Our van upfit supplies company does sell several varieties of Thinsulate acoustic/thermal insulation which is specifically engineered for vehicles. We have many thousands of DIY and professional upfitters who are very satisfied with the ease of use and performance. Many more folks use Thinsulate in the their vans than use wool. Wool does have an ugly side (https://youtu.be/aE66ZC7RJQA) and has to be treated with borates which are definitely not natural. There is a lot of energy used in processing wool and it can also contain residual pesticides from sheep being treated for lice.
All the best,
Hein
DIYvan
541 490 5098
Old 04-20-2020, 05:47 PM   #49
All the best,
Hein
DIYvan
541 490 5098
Hein,
You should disclose you interest in this product by listing yourself as a commercial vendor, as other vendors do. I donít understand why the moderators havenít called you on this issue already. There are quite a few commercial vendors who participate in the forums and I thought it was required to list yourself as such when you are regularly promoting a product you sell.
Carol
Old 04-23-2020, 10:16 AM   #50
your 31 is 407 square feet? Hmm. I did my measurements subtracting my windows and end caps and came up with 283 square feet. Do you think thats too big given mine is a 22 footer and yours is nearly 9 feet bigger? I guess its plausible that yours could be 125 feet bigger? Anyway, you said you bought 5 bags, i'm gonna need 3 and have a little leftover... maybe i can make a nice quilt for winter time with it
Old 04-23-2020, 08:47 PM   #51
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
I just insulated my 72 31' sovereign center bath, and I used all but one batt of 5 bags of 24" x 48" x 2" thick Rockwool AFB if I remember right there are 12 batts in a bag. that works out to 472 sq ft. this is walls, ceiling and some over the wheel wells. i used all the little cut off bits to fill cracks and narrow gaps, so no real scrap there.
"Daddy when's the trailer going to be finished?"
Can of beans is offline   Reply With Quote
Old 05-22-2020, 05:45 PM   #52
Bullhead City , Arizona
Hein, can you tell me what the R-value is for the SM600L? I'm interested in using it in my Airstream Argosy. Thanks.
AZ4ME is offline   Reply With Quote
Sheep wool insulation? rippie Ribs, Skins & Rivets 15 07-15-2019 12:24 PM
Mineral Wool Insulation? GypsyKarma Interior Restoration Forum 9 08-01-2016 12:05 PM
sheep wool insulation part 2 workinonit General Interior Topics 10 06-04-2014 08:42 PM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
Bear vs. Sheep Wayne&Sam Off Topic Forum 4 04-25-2009 09:23 PM
