Old 03-24-2018, 03:12 PM   #1
1995 30' Excella
Harper Woods , Michigan
Removing interior skin rivets -don't drill -strike off the head & punch the rest
Hello, This idea for removing skins may work for you.
I found drilling out rivets tedious. I found that a wood/demolition chisel can be used to strike off the head of a rivet in one blow with a hammer. I used a DeWalt 'side-strike' demolition chisel, as well as cheapo Harbor Freight wood chisels (a 4pc set @$5). Then I used a punch to push out the remainder of the rivet to free up the panel. If you don't have a punch then cut the point off a nail and use it as a punch.
With a bit of practice, you can strike off the head with little or no damage to the surface of the aluminum skin. But this method may not work for those who wish to polish the aluminum skin after removing the adhesive for the mouse fur. But if you're going to recover anyway, this may save you a lot of time. Also, you can strike the heads off rivets that are hidden under the edge of another panel
Bob Blarney is offline   Reply With Quote
Old 03-24-2018, 06:53 PM   #2
1976 31' Sovereign
Oswego , Illinois
I use metal putty knife w/edge sharpened as former AS retired factory serv. dept. showed me.
Old 06-18-2018, 08:36 PM   #3
Silver57's Avatar
Fresno , California
It appears that the inner skins were pop riveted and buck riveted. Will the ceiling skins come off in one large piece by just removing the pop rivets?
Silver57 is offline   Reply With Quote
Old 06-18-2018, 08:59 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Yes the pop rivets hold the big sections up. When you get the ceiling piece down it can be removed out the door if you hold the piece as a big "u" shape rather then roll it up. Takes at least 2 people to do.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 06-29-2018, 06:28 AM   #5
Silver57's Avatar
Fresno , California
Thank you Shacksman for the confirmation on the upper roof interior removal. I really do not want to remove this section but it must be done to place electrical wiring for the two vent fans and roof reinforcement for an ac unit. My plan is two fantastic fans forward and aft vents with the penguin II in the center.
Sent from my SAMSUNG-SM-G935A using Airstream Forums mobile app
Old 07-08-2018, 11:59 AM   #6
1995 30' Excella
Removing the skins doesn't sound like fun. Maybe you could consider running the wires along the streetside near the floor, and then fish the wire up the inside the wall with an electrican's reel.
Old 07-08-2018, 03:10 PM   #7
Silver57's Avatar
Fresno , California
Yes I considered that idea however I still will need to reinforce the center rough vent for the 100 pound a/c unit. Thank you.
Old 07-08-2018, 03:11 PM   #8
Silver57's Avatar
Fresno , California
Center roof vent that is!
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Removing pop rivets on interior skin? kokomoscalls Upholstery, Blinds, Walls & Interior Finishes 2 02-16-2014 03:59 PM
Solar to drill or not to drill-HELP Orson Electrical - Systems, Generators, Batteries & Solar 2 08-24-2012 08:03 AM
Front Bed Head rest storage Mangin 2002 - 2005 International 2 09-22-2010 05:47 PM
Drill Baby, Drill! Mount external antenna TropicGuy Computers, Internet & Satellite 5 04-17-2010 03:02 PM
