Old 04-16-2021, 08:50 AM   #1
Golden , Colorado
Lightbulb Purchasing interior skins
I have been searching for a few days for rolls of 5052 0.032 aluminum for my interior skins and Im Having trouble finding them
I would love advice on where to go
Thank you so much yall
Emmaggy is offline   Reply With Quote
Old 04-16-2021, 09:38 AM   #2
LY31
1977 31' Sovereign
MI , USA
Emmaggy re aluminum
I bought mine at www.airpartsinc.com in Kansas City.
LY31 is offline   Reply With Quote
Old 04-16-2021, 10:33 AM   #3
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
You might try airpartsinc.com but I've always purchased 5052 H42 in sheet form, 2024 is def available in rolls up to 32' IIRC.
truckasaurus is offline   Reply With Quote
Old 04-16-2021, 12:24 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We also got ours at Airparts, Inc. and used 2024-T3.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 04-16-2021, 01:21 PM   #5
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Same here, Airparts, Inc. found at: https://www.airpartsinc.com/298_5052...inum_Sheet.htm
2019 Ford F350 Platinum
Gen-Y Torsion 10,000 lb Hitch
Rock Tamers
seldencove is offline   Reply With Quote
Old 04-29-2021, 10:12 AM   #6
Golden , Colorado
Thank you!
Can you help me understand why one would choose sheets vs rolls and what width is best? Also best method for figuring out how much I need?
Old 04-29-2021, 11:34 AM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
I can't think of any reason to buy sheets over a roll, except maybe the alloy you need isn't offered in roll form. We bought 2024-T3 in a roll because:
1. The sheet sizes are limited - we needed panels longer than sheet size and didn't want to add seams
2. We needed multiple panels so less waste to cut from roll
3. The panels on an Airstream are rarely (if ever!) going to match up to the sizes of standard panels.
4. Easier to ship a roll than sheets
Regarding the width - You will be cutting it anyways, so the width doesn't really matter - get 4' or whatever is the widest panel you need. Then cut-to-fit as needed.
Use your old panels as patterns, if you have them. We were fortunate to have our existing panels to calculate the length from and use as patterns - they were just damaged.
If you don't have your original panels, keep in mind, that the seams need to overlap "-1"+ and line up with the ribs. Then:
1. Do a sketch of the panels you need on grid paper make a pattern, then add them up for the length.
2. Do full scale rosin paper patterns - then lay them out and add them up.
3. Order enough to get started (measure the easy part - straight panels (from the floor to waist high all the way around the trailer + "a little extra") then place a second order once you get the hang of it.
Good luck!
Shari
Moving Traveler with no interior skins 60traveler Towing, Tow Vehicles & Hitches 1 11-01-2011 02:35 PM
Aluminum Interior Skins in ??? models? Alluminatrix General Interior Topics 8 01-14-2010 01:34 PM
Interior skins won't budge plossl Interior Restoration Forum 2 09-04-2007 01:02 PM
Removing Interior Skins Swanny General Interior Topics 5 07-20-2006 10:39 AM
Interior Skins jcferguson General Interior Topics 5 08-12-2005 06:49 PM
