72 landyacht, I forgot how the plastic light cover attaches to the alluminum light fixture. too long on my restoration. one side attaches to toggle switch the other side to the crank. there must be something on the crank side I am missing. can someone post a picture? thanks
The body of the crank is larger than the hole in the cover so when you tighten the crank screw it holds that end of the light cover up. The 2 holes may be different diameters so make sure the correct one (smaller I think) is used on the crank end.
Dennis
