Old 04-11-2020, 12:47 PM   #1
1976 23' Safari
summit , Montana
Piping? Which is which?
We are wanting to remove the copper water lines but not gas - at first we thought the thicker ones were water and the small ones are gas. Help!
ID:	365483   Click image for larger version
ID:	365485   Click image for larger version
coco97 is offline   Reply With Quote
Old 04-11-2020, 01:00 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
All of the gas lines should be under the trailer attached to the bottom of the belly pan. The feeds to each of the gas appliances will Tee off of the main line and run straight up into the cabin of the trailer and attach to the appliances. My 75 TradeWind had shut off valves at the Tee for the water heater and the furnace. Having the lines running on the outside under the trailer was to prevent filling the trailer with propane if there was a line leak.
You should be able to trace the propane line from the tanks and regulator to the propane line under the trailer. Everything in the pictures looks like water lines to me
Richard
Old 04-11-2020, 01:01 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Gas usually runs under the trailer outside of the belly pan and up directly under the appliance.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 04-11-2020, 01:02 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Damn Richard, you beat me by a minute.
Bill
Old 04-11-2020, 01:18 PM   #5
1976 23' Safari
summit , Montana
Thank you for the fast reply!
Old 04-11-2020, 02:56 PM   #6
1976 Argosy 28
Buford , Georgia
Yup, those are all water lines..
strangepod is offline   Reply With Quote
Old 04-12-2020, 02:58 PM   #7
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
To be sure they use solder joints on water pipes. NEVER on gas.
bibbs is offline   Reply With Quote
Rubber or plastic piping on cabinet edges? durans54 Cabinets, Counter Tops & Furnishings 12 03-28-2007 09:07 PM
Changing out faucets- what size copper piping? charlie tuna Fresh Water Systems 10 08-22-2006 11:02 AM
PVC piping Devoman Fresh Water Systems 8 09-30-2005 07:46 PM
Water Pump Piping Navigator Water Heaters, Filters & Pumps 2 02-08-2004 10:16 AM
Hot water piping Pahaska 2002 - 2005 International 8 01-29-2003 07:19 AM
