Old 03-05-2021, 07:55 AM   #1
1987 34' Limited
Crofton , Kentucky
Mystery Switch?
Hello! Ever since I came into possession of my '87 34" Excella Limited, I've never known what this lightswitch was for. It's above the kitchen countertop close to the outlet and what used to be the water pump switch. It doesn't seem to connect to any lights. Does anyone have any idea or know what it leads to? I really appreciate it!
(I swear I'm not dumb- this light switch has just stumped me! )
Cnorton1 is offline   Reply With Quote
Old 03-05-2021, 08:07 AM   #2
Coloradobus's Avatar
Its probably the switch allowing to toggle between running your A/C or your microwave. Unless youre powered by 50 amp, at 30 amp you cant run both appliances together
JIM n CHRIS
62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,90 SQ Sream, 06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
Coloradobus is offline   Reply With Quote
Old 03-05-2021, 08:36 AM   #3
ITSNO60's Avatar
Tucson , AZ
One way to verify this is to see if the switch is a 3 way. A 3 way toggle switch will be smooth with no lettering on it as opposed to a single pole toggle switch which will always be stamped "ON" and "OFF".
Brian
ITSNO60 is offline   Reply With Quote
Old 03-06-2021, 12:37 PM   #4
1987 34' Limited
Crofton , Kentucky
UPDATE: I found out that the switch goes to the outlet under the sink that was meant for the hot water dispenser! Months and months of irritation finally relieved Thanks for the help!
Mystery Switch jagcb750 Classic Motorhomes 54 10-09-2011 11:50 AM
'89 Excella 25 mystery switch? Pix attached also... BillTex 1987 - 1989 Excella 12 05-22-2011 01:05 PM
Switch Mystery excella1976 1975-1976 Excella 500 2 01-26-2008 08:06 AM
Mystery toggle switch mpumphrey04 Electrical - Systems, Generators, Batteries & Solar 9 12-07-2005 07:47 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
