Old 05-14-2021, 08:31 AM   #1
Golden , Colorado
Lightbulb Installing interior skins
Silly question:
HOW exactly do I install the interior skins? I know itís with rivets and Iím getting pop(pull) rivets
Do I line up where I am Placing the rivets with the holes in the ribs?
I have seen some people line the rivets with like an insulting tape to help keep the AS better insulated if I go this route how do I attach the skins to the ribs and find the holes?
I am new to this and almost ready to put my skins in, help/advice/or point me to another thread would be MUCH appreciated
Thanks yíall
Emmaggy is offline   Reply With Quote
Old 05-14-2021, 09:25 AM   #2
1966 22' Safari
Fredericksburg , Texas
I think if I were using tape for as a thermal break on the ribs, I would do this: say itís a 12í x 4í sheet of aluminum going back in its original location. I would cleco a few places on the top side of the sheet. Then push it against the ribs and try a few lower holes with clecos. You can feel around with clecos. If you have the sheet lined up with the original holes, then remove the lower clecos leaving the top ones. I would lift up the bottom of the sheet and tape the ribs. Then push the sheet against the ribs and cleco the bottom going through the tape. After that, remove the top clecos and tape that. Cleco the top through the tape. The sheet should be aligned. Iím assuming youíre going back with 5/32 pop rivets since the original 1/8 rivet holes are stretched out? Anyway, thatís my thoughts. Any other methods out there? Good luck
Bubba L is offline   Reply With Quote
Old 05-14-2021, 04:17 PM   #3
Golden , Colorado
Thank you so much
They will be all new skins the trailer came fitted with no skins there why Iím wondering about best way to attach to the existing ribs and holes
Thoughts?
Old 05-14-2021, 04:45 PM   #4
1966 22' Safari
I donít know how anyone could possibly drill new holes in a sheet of new aluminum and match up to the existing holes in the ribs. I would just place the new sheet against the wall and drill/cleco as I went along. I would try and stagger the existing holes in the ribs and place the new rivets spaced evenly apart. Measure the existing rib holes and space your new rivets accordingly. Good luck
Old 05-14-2021, 05:17 PM   #5
1986 31' Sovereign
Miami , Florida
If you have a small airport in the vicinity, check and see if they have an Experimental Aircraft Association (EAA) chapter. Those folks build airplanes out of whole cloth and I bet you could get some ďhands onĒ guidance for cheap (maybe free). If no EAA, ask around to see if there isnít an Airframe and Powerplant mechanic around that you could hire for an hour or so to get you started.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 05-15-2021, 10:17 AM   #6
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Hello, I just PM'd you, I'm just over in Green Mtn., glad to come take a look or help out....Mark D
mrdes8 is offline   Reply With Quote
Old 05-15-2021, 10:51 AM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
It is possible...
It is possible to reuse old rib holes with a Hole Finder or Strap Duplicator Tool, but not necessary.
It's kinda like a pair of tweezers with nub on one leg that goes in the old hole in the rib & a hole in the front that tells you where to drill the sheet for your new rivet hole. You put the sheet in between the two legs and use it as a guide to drill your new hole.We have one and got it at Aircraft Spruce. That and a few hundred "Clecos" come in real handy when replacing panels....I can't imagine replacing a panel without them.
Alternately, if you have your old panels, you can use them as templates for your new panels. We did that too.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 05-15-2021, 11:24 AM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
If you don't use the old holes, make sure your new ones are far enough away from the old ones so your pop rivets will have enough rib to grab onto. Otherwise, the holes will be too big for the rivet stems to catch the rib.
Shari
Old 05-15-2021, 01:21 PM   #9
1966 22' Safari
Shari, thatís a neat little tool thatíll come in handy. Got to get me one. I can see that for perimeter holes in installing a new panel, but what about the holes in the field of the panel? I guess you would have to work from the bottom up? Still worth a try. The holes would have to line up perfectly to align the pop rivet shaft through the new hole in the panel and the existing hole in the rib.
Old 05-15-2021, 03:18 PM   #10
1955 26' Cruiser/Overlander
harrisburg , Missouri
what year of airstream do you have? Do you have to make the end caps? That is going to be by far the hardest part if you do. I saw a YouTube video of someone building them. It helped me when I was putting mine back together because for some reason the original end caps did not fit back like they came out and I had to take them apart and re-rivet them back together as I installed them. Anyway, end caps go in first, then bottom sheets down each side, then middle, then top. I would not try to align the new panels with the old holes. seems near impossible. just try to stay away from the old holes. I just finished mine and it took over 2,000 rivets to put it back together. I bought a milwaukee 12v. rivet gun and I am glad I did.
Aaron
a duncan is offline   Reply With Quote
Old 05-15-2021, 04:53 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
<snip> ...but what about the holes in the field of the panel?
That's where using the old panels for a template works better.
Shari
Installing a 2nd fridge in 22' Sport (or installing larger fridge altogether)? skicrazy801 2005 and newer - Bambi all models 12 09-22-2019 01:43 PM
Aluminum Interior Skins in ??? models? Alluminatrix General Interior Topics 8 01-14-2010 01:34 PM
Simple trick for installing upper inner skins... malconium General Interior Topics 3 03-08-2007 11:51 AM
Removing Interior Skins Swanny General Interior Topics 5 07-20-2006 10:39 AM
Interior Skins jcferguson General Interior Topics 5 08-12-2005 06:49 PM
