Old 06-30-2021, 02:38 PM   #1
1967 28' Ambassador
Sackets Harbor , NY
Flooring 1967 ambassador
Based on the picture below.. what is most likely under this carpet?
Looking to remove carpet, and metal strip in order to add engineered hardwood planks over the vinyl and throughout the flooring.
Trying to make the flooring as level as possible without removing the vinyl. The carpet rides slightly higher at the moment.
Jakerez7 is offline   Reply With Quote
Old 06-30-2021, 03:09 PM   #2
1966 22' Safari
Fredericksburg , Texas
Your carpet and vinyl are applied on your plywood subfloor. When you remove the carpet, and the vinyl is missing, you have a couple of options to level the subfloor. You can use a self leveling material like Ardex or get a scrap piece of vinyl and patch in where the carpet was installed. Renovators have used Ardex on Airstream subfloors. But someday if you decide to replace your new plank flooring, I don’t know how easy it would be to remove the Ardex. You may be better off to cut your existing vinyl at your cabinet bases and remove it. Is your new plank flooring glue down or floating?
Bubba L is offline   Reply With Quote
Old 07-01-2021, 08:29 AM   #3
1967 28' Ambassador
Sackets Harbor , NY
Thanks bubba. We will be using floating flooring. We will not be using Ardex. We can try to remove carpet and vinyl piece of flooring to see if that will level the floor.
I didnt want to remove the vinyl in fear of disturbing asbestos - but not sure either.
Old 07-01-2021, 09:56 AM   #4
1966 22' Safari
Normally, the tile with asbestos were 9”x9” square and the adhesive.
Replacing original flooring with vinyl plank flooring Team Hardy Repairing/Replacing Floor &/or Frame 23 10-26-2019 07:45 PM
And so it begins..... 1967 Ambassador till 1966 - 1969 Ambassador 58 07-13-2006 04:15 PM
STOLEN: 1967 Safari m/o 1967 Dodge 300 truck, Oakland CA. siliconboy Our Community 3 07-27-2005 09:47 AM
1967 Ambassador colplink 1966 - 1969 Ambassador 4 06-10-2004 11:23 AM
1967 Ambassador saltyvines 1966 - 1969 Ambassador 21 02-28-2003 07:27 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
