Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 09-20-2016, 01:59 PM   #1
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
Fiberglass end cap repair
Hi,
I want to paint the fiberglass end cap in my 65 Safari. There are multiple holes from snaps, rivets, etc. I want to patch and smooth the holes and then paint with a Krylon spray paint. Is there such a thing as spackle for fiberglass? Or, can I use fiberglass resin and hardener to fill the holes, sand it down after it hardens and paint it? Any other suggestions would be appreciated.
Dave
Chatooga11 is offline   Reply With Quote
Old 09-20-2016, 02:18 PM   #2
1955 22' Safari
Laredo , Texas
Use thickened resin
Is there a marine store nearby?
55AS is offline   Reply With Quote
Old 09-20-2016, 03:19 PM   #3
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
Yes. Whatcha got in mind?
Old 09-20-2016, 04:36 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would mix the resin and paint the edges of the hole then add filler or wait till the resin started to harden and fill the hole with the thickening resin.
May be easier to just use Bondo.
2004 Excursion 4x4
Old 09-20-2016, 05:58 PM   #5
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
Dave, If you try to just fiil holes they will crack and show or fall out. I suggest you use an orbital sander to hollow out a circle around the hole, lay in some fiberglass screen with some epoxy and then fair out with fiberglass bondo. All can be found at home depot. Itried to attach sketch but dont see it.
JLGT5107 is offline   Reply With Quote
Old 09-21-2016, 12:37 AM   #6
1979 23' Safari
Wayland , New York
I didn't want a big can of epoxy so I used gorilla glue epoxy. Comes in a 2 part syringe. Mixed some in tin foil cupcake cups and put it into the hole with Popsicle stick. Tape around the holes for runs. Then sanded down after letting cure overnight. Painted with krylon, only way you notice them is the epoxy was a little smoother than the surrounding endcap. If you force some epoxy into the hole then put a piece of tape over it the epoxy settles to the tape getting really close to a smooth surface.
HiJoeSilver is offline   Reply With Quote
Old 09-21-2016, 03:17 AM   #7
65CV's Avatar
Western , Massachusetts
The PO of our '65 caravel cut the rear bathroom in half. We fixed that and the endcaps with West Systems Epoxy. I've also used it for quite a few boat repairs -- it's the standard in the Marine Industry.
Here's one source. I'd use:
105 Resin
206 Hardener (205 in cold weather)
Pump dispensers to get mix correct
410 microlite filler for non-structural areas
Fiberglass, if necessary for larger repairs. Use on back of endcap if possible.
Lots of good advice at the West Systems site
65CV is offline   Reply With Quote
« Inner skin | Top | End caps »
Bathroom and fiberglass end cap RoomRarities Airstream Classifieds 0 08-10-2016 08:49 AM
Fiberglass End Cap - 1965 Airstream Sovereign KimBo Airstream Classifieds 0 05-17-2015 09:44 PM
Bathroom Fiberglass End Cap and Shower Question mello mike General Interior Topics 4 03-25-2010 04:29 PM
Fiberglass End Cap The Flintstones General Repair Forum 13 07-10-2007 03:02 PM
How to repair inner fiberglass cap? mello mike General Interior Topics 5 11-10-2004 09:29 PM
