Old 03-15-2020, 06:22 AM   #1
2003 22' International
Gilroy , California
Drawer latch
Hello, any tips on locating a replacement drawer latch ? thanks
-Mark
#2003CCD
Mr Gilroy is offline   Reply With Quote
Old 03-15-2020, 08:17 PM   #2
2009 23' International
2020 27' Globetrotter
GREENSBURG , PA
You can try these or any of the others listed on-line.
https://www.amazon.com/Cabinet-Drawe...324964&sr=8-11
Joe15601 is offline   Reply With Quote
Old 03-16-2020, 11:15 AM   #3
2016 30' Classic
Houston , Texas
I too was successful get a replacement and some spares from Amazon. On the broken part, I noted the manufacturer's name to make certain the Amazon replacement was compatible.
dhroberts is offline   Reply With Quote
Old 03-16-2020, 12:28 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes....bead latches.👍
Get rid of the cheep plastic for good.
ID:	363383   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Instead of going to íStarbucksÖI make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire"
Amanamus
Tahawus....🌥
Old 03-16-2020, 03:49 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I agree with Mr. Cross. You might find your search enhanced using the following terms to locate sellers via the web: "double ball latch catches"
These latches come in a variety of sizes (length & width) and have different ball tension (15lb, 20lb, etc.) that you can adjust with a small screw driver. They can be mounted to drawers (screws opposing) and wardrobe/cabinetry doors (screwed at 90 degree abutment). They are generally cheaper than the plastic RV products and are durable enough to outlast your ownership period.
https://www.amazon.com/Solid-Cabinet...dp/B07VRCJYBG/
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 03-29-2020, 03:35 AM   #6
1981 31' Excella II
Tallahassee , Florida
These ball latches look like a great idea for a remodel like mine. My question is, can they hold the drawers, doors, etc. closed going down the road? I thought Iíd need some sort of locking knob. I was thinking of the round push knobs.
Happy2BeHere is offline   Reply With Quote
Old 03-29-2020, 06:17 AM   #7
I have not had that problem since install 9yrs.
A trick for quick install, install the screws as pictured, close the door and push, drill a pilot hole at the marks. (I used 3M 4200 on the threads)
A nice feature...the latch tension is adjustable.
ID:	364202   Click image for larger version
Molly Ivins
Amanamus
Tahawus....🌥
Old 03-29-2020, 08:48 AM   #8
Mollysdad's Avatar
Originally Posted by ROBERT CROSS View Post
A trick for quick install, install the screws as pictured, close the door and push, drill a pilot hole at the marks. 🇺🇸
Brilliant!
Drawer latch Teppy General Interior Topics 5 01-02-2019 07:30 AM
Can't get drawer to close/latch Stews General Repair Forum 3 09-24-2017 03:32 PM
Drawer slide latch repair Rob Edgerton Cabinets, Counter Tops & Furnishings 3 04-12-2017 11:32 AM
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
