Old 04-20-2017, 03:39 PM   #1
1968 26' Overlander
Bonnington , British Columbia
covering textured walls
Does any one have experience with covering textured walls with plaster of paris or anything else? I have a 68 overlander I'm currently restoring and the interior walls have texture that I am not fond of at all, also a lot of holes. I would like to cover the textured surface with a thin layer of something, fill in the holes then paint over it hoping for a smooth finish.
Any suggestions? The walls appear to be a vinyl material, a bit shiny, I'm not sure if plaster of paris will stick to it. Thanks in advance.
Tracy
Tracy Lynne is offline   Reply With Quote
Old 04-20-2017, 07:16 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
P of P will not withstand the expansion and contraction of the inner skin let alone travel down the road.
Old 03-20-2018, 03:54 PM   #3
1988 29' Excella
North East , Maryland
Hi,
The plaster of paris will not work. It sets up hard and will break when the aluminum walls expand and contract.
Why not patch the wholes and paint the walls. Search the forum for interior paint. Should be lots of good info.
Ladyfish is offline   Reply With Quote
Old 03-20-2018, 06:51 PM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
A more workable solution might be just to strip the vinyl off, then paint the (now smooth) bare aluminum. Maybe Bondo the holes if necessary.
TheGreatleys is offline   Reply With Quote
Old 03-20-2018, 07:35 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have not stripped off the vinyl although others have. Sounds like a lot of work. Others have painted it using a strong cleaner to remove the oily stuff on the surface and a primer like Kilz. How about Zolotone or another speckled paint. It would look great in your AS. It can be sprayed but can also be rolled. Both oil and water based versions are available.
Old 03-20-2018, 09:32 PM   #6
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Use Mr Clean sponges to clean the walls then wipe down with water on a rag. This will leave the walls clean and non sticky.
Trying to remove the vinyl from the aluminum is an exercise in frustration . It is bonded during production of the aluminum sheet.
As for the holes get colored rivets from http://www.VintageTrailerSupply.com
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Covering uncleanable mouse fur walls and ceiling 3 Dog Nite Upholstery, Blinds, Walls & Interior Finishes 16 06-30-2024 09:18 PM
To Rip Off Walls Or Not To Rip Off Walls... belikethefox Upholstery, Blinds, Walls & Interior Finishes 5 07-23-2021 07:11 AM
Remove wall covering and paint walls rkendall Land Yacht/Legacy Motorhomes 13 07-15-2018 10:02 PM
Rustoleum Textured Paint Roadrunner Upholstery, Blinds, Walls & Interior Finishes 2 04-10-2010 11:01 PM
Covering the trailer for winter Happycampers Winterizing, Storage, Carports & Covers 13 10-26-2003 07:13 PM
