Yes. So, are you reinstalling your original skins, or are you putting in brand new skins? If you are using your original skins, then I suppose it is debateable whether you really need to cleco it in place before riveting, but it certainly doesn't hurt. If you are doing brand new skins, and holes haven't been drilled yet, then I would say clecos are a great help. You will need 1/8" clecos If you intent to install 1/8" rivets (which is what I did, and it worked fine--afterall, the rivets do expand a bit as you install them), and a pair of cleco pliers. You can find both at places like Vintage Trailer Supply, Aircraft Spruce, The Yard, ebay, etc.
good luck
