Old 11-22-2022, 10:43 AM   #1
1976 31' Excella 500
Crewe , Virginia
Building 2 sets of Triple Bunks - 76 Excella 500 Center Bath
With having 6 kids, we chose to build submarine style berth/bunks. This is one set down. 1 more to go. The window is still operational as it should be.
ID:	425658   Click image for larger version
Dspchef is offline   Reply With Quote
Old 11-22-2022, 11:49 AM   #2
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Very nice, and each has a reading light.
10Smiles is offline   Reply With Quote
Old 11-22-2022, 03:38 PM   #3
Mollysdad's Avatar
Check out some rock and roll tour busses. The band's come with 12 bunks, and each has a reading light, TV, fan, and privacy (as much as possible) curtain.
Old 11-22-2022, 06:24 PM   #4
Crewe , Virginia
Thanks for the suggestion, but itís a little too late. Iíve already made the first set and now starting the second set. I do have privacy curtains getting made. The 12volt reading lights all have a USB port for electronics and USD desk fans.
Old 11-22-2022, 09:03 PM   #5
coloradoup's Avatar
1966 24' Tradewind
1987 34' Excella
Olathe , Kansas
Nice work! Sounds like some good times are ahead.
Link to my build.
https://www.airforums.com/forums/f11...nd-224399.html
coloradoup is offline   Reply With Quote
Old 11-23-2022, 05:53 PM   #6
Crewe , Virginia
......and so it continues......
Started the roadside bunks today. Got the head board made, wired for lights and now location for the thermostat (furnace) and will be making enclosed box on the side of the lower bunk for power junction box, power cord and small access door will be for the water hoses. It all makes sense in my head....
Name:	Roadside Bunk.jpeg
ID:	425683   Click image for larger version
Old 11-23-2022, 07:30 PM   #7
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Looks like you at one time had the retractable water and electricity hose reels which was standard on Excella 500s. Itís a shame you no longer have them as they are tremendously convenient and makes connecting and disconnecting at the campsite a breeze. Do you still have them or were they already gone when you bought the trailer?
4RXLA is offline   Reply With Quote
Old 11-23-2022, 07:53 PM   #8
Crewe , Virginia
No, they were toast when I got the trailer. The springs were broken in both, the contacts broken/melted in the power reel and the sign of not winterizing was present in the hose reel. I really tried to restore them, but those springs would cost the same as new reel. Since we were putting in triple bunks, off the to dump they went.
Old 11-23-2022, 10:36 PM   #9
4RXLA's Avatar
Images: 33
Thatís too bad but understandable given your situation.
Old 11-23-2022, 11:47 PM   #10
Crewe , Virginia
I donít have situations. I have challenges that spark creativity!
Old 11-26-2022, 09:54 AM   #11
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
Good job, keep posting the updates.
Streamracer is offline   Reply With Quote
Old 11-26-2022, 10:34 AM   #12
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 219
Very nice!
I added a pair of double bunks in our 73 sovereign back in the day with a 5th supported cross ways on top of the to top bunks. I also removed the hallway closet across from center bath and added another set of double bunks. (We topped out at nine children)
Kept the 10 gallon water heater (street side) so was somewhat limited with floor space.
I used plywood framing with aluminum angle to support the luan mattress base.
Never rigged night lights (I'm sure they would've loved that.)
Now that we have only the youngest two camping with us, I repurposed all the bunk material into two matching twins for the bedroom. (Believe it or not, they grow up and you will be amazed at how much room there is inside a Sovereign!)
Many fond memories...and you will have also! Enjoy them while you can!
(Those were the days)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old Yesterday, 02:38 PM   #13
Crewe , Virginia
And so it continues.......almost done!
I got the outer access door compartment functional since taking out the original bed base out. It will be for water hoses. I also have the junction box covered, but still have access to it if I need to replace the power cord. If it comes to that, I will probably end up installing the newer twist lock outlet with detachable power cord. I finally got the other side up and am now looking at storage lockers with some of the scrap and left over wood. This has been quite interesting to come up with.
Name:	Storage Compartment.jpeg
ID:	425924   Click image for larger version
Name:	JunctionBox Cover.jpeg
Bunks vs no bunks... dianagillmd Member Introductions 18 07-31-2017 08:01 PM
Bunks for adults? Weight limits on DIY bunks? flaagan General Interior Topics 10 04-19-2015 10:57 PM
Building New Walls and Bunks Silverflames Upholstery, Blinds, Walls & Interior Finishes 51 05-21-2014 08:39 AM
Nice Used Airstream 30' Bunks Safari TravelTrailer RV SNice Used Airstream 30' Bunks eBay Watch Airstreams on eBay 0 02-17-2011 07:00 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
