Old 11-26-2016, 01:27 PM   #1
1953 21' Flying Cloud
Salida , Colorado
Advice on interior painting!
Hi! I'm new to the Airstream world and was wondering what you do if the interior walls are aluminum and you want to paint? They are pretty dinged up and I didn't know if there is something to put over the walls to cover it..? Any info is always appreciated!
Pope97 is offline   Reply With Quote
Old 11-26-2016, 03:28 PM   #2
millertimeUS's Avatar
1976 25' Tradewind
What year airstream? Many vintage models have a vinyl coating over the aluminum. I used Krylon Fusion on mine, as have many others, with excellent results.
Matt
millertimeUS is offline   Reply With Quote
Old 11-26-2016, 06:10 PM   #3
Salida , Colorado
It's a 1953 Flying Cloud. How can I tell for myself if it has vinyl? If you need a pic I can post one!
Old 11-26-2016, 06:59 PM   #4
1976 25' Tradewind
A good question. My 76' Tradewind it was somewhat obvious with the texture. For your year and model perhaps someone else out there had a definitive answer? Make sure you degrease the walls before you paint, it builds up over the years.
Matt
Old 11-26-2016, 06:59 PM   #5
1979 23' Safari
Wayland , New York
You'd know if it was vinyl covered, it looks like bad splotchy beige wallpaper on the walls.
If you have bare aluminum walls and really want to paint them right, you'll need to clean very thoroughly, then sand them slightly for paint to stick to, then clean again, then prime them with either a primer made for aluminum or a self etching primer, then paint.
Old 11-26-2016, 08:03 PM   #6
Salida , Colorado
I will be picking up the airstream Fri and maybe It will be easier to tell in person. Thank you both for the information!!
Aslyn
Old 11-27-2016, 06:45 PM   #7
1967 17' Caravel
Stayton , Oregon
Is it Zolite
Our 1967 Caravel has very nice off white cross hatch patterned Zolit (unsur of spelling). It cleaned up nicely with some soft scrub and some scrubbing. It is almost 50! Before you paint see what you have to work with.
tin twinki is offline   Reply With Quote
Old 11-27-2016, 07:46 PM   #8
1979 23' Safari
Wayland , New York
A '53 may have zolatone which is a hard paint. Find an inconspicuous spot and scrape a little, it'll be easy to tell if it's plastic/vinyl wallpaper or zolatone.
Old 11-27-2016, 08:22 PM   #9
1966 22' Safari
Fredericksburg , Texas
Chances are it's Zolatone. I don't believe they started the vinyl until around
66. We still have some of the original green Zolatone in our 55. It doesn't come off easily. I used aircraft stripper but still had to sand. I'll be going back with a
different colored Zolatone.
Bubba L is online now   Reply With Quote
Old 11-27-2016, 09:35 PM   #10
reinergirl's Avatar
Hollis , New Hampshire
1953 is definitely not vinyl. I'm sure it was zolatoned. Might clean up using a degreaser with a Mr Clean magic eraser. That of course would be easiest!
I stripped the original zolatoned paint ( and many layers of additional paint) see here
http://63overlandermoonraker.blogspo...ka-moment.html
http://63overlandermoonraker.blogspo...issing-me.html
Then I primed with Benjamin Moore Stix and painted with the new Roll-on Zolatone. My experience here.
http://http://63overlandermoonraker.blogspot.com/2015_09_01_archive.html
reinergirl is offline   Reply With Quote
Advice and opinions on painting blue stripes Hoobiedoobie Clearcoat, Exterior Paint & Trim 23 07-07-2017 12:12 AM
Interior painting question? JoshuaTonbo General Interior Topics 19 05-28-2016 08:24 PM
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 01:35 AM
painting the hitch? color advice? tdoescher Clearcoat, Exterior Paint & Trim 3 05-04-2009 07:30 AM
Painting Interior walls, Ceiling DJbyRequest General Interior Topics 37 05-29-2005 09:51 PM
