I have a 69 Overlander 27' that needs a lot. I have a friend who is restoring a 63 Tradewind. Does anyone know if I can use the interior parts, specifically the bathroom components, wall panels, tub, sink cabinet etc from the 63 Tradewind in my 69 Overlander?
Any other info/ feedback on this topic?
Thank you!
Wade
06 Safari
69 Overlander
1969 was the first year of the wider body and a different body shape. You could make a template of the tub and hold it in place but likely a different curve. If their 63 has the wide bathroom sink cabinet vs the small center cabinet then it wouldn’t be wide enough. You can always modify the wood stuff. The fiberglass isn’t that forgiving however.
__________________ Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
