2015-2020 Classic Lavatory Door Handle
BEWARE!
The latch that moves back and forth that allows the door to open and to remain closed broke in my trailer while I was on a 10 day trip. The latch no longer appeared in its normal location.
After disassembly, I found the small spring inside had broken. (BTW, it is not supposed to be opened, I had to drill out the pressings)
IF this happens to you, the replacement latch set costs $187.00.
Yes. $187 for a handle and latch assembly. The spring probably costs about $.05.
My good buddies in the parts department at Out of Doors Mart (who had this in stock -- which I found amazing), pointed out on the box label that the assembly was made in Italy.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
