03-30-2021, 07:27 AM
#81
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
I just finished installing a MaxAir vent fan in the 69 Globe Trotter 21'. The old fan had a broken blade, and wasn't very effective. I must say the Max Air is a well designed piece. It has a "variable fan speed" control, it runs in reverse creating a "ceiling fan" experience, it has a tinted plastic cover that allows some light in, but not Colorado glaring sun, and it has a permanent rain shield so if you leave the vent open, you don't get wet.
I had to enlarge the opening a bit so it would fit, and I had to make a "picture frame" between the exterior skins and interior skins for the mounting screws to attach to. Thin Airstream aluminum on the roof would not adequately support the MaxAir in my judgement.
The Fantastic Fans are along the same line, but I don't have experience with them. My friend helped me install the MaxAir and he wants one or two for his Sovereign.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
03-30-2021, 12:55 PM
#82
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
Originally Posted by Aopsahl7
Talk to me about your ideas for the off road airstream.. I am all ears!
I've got a 31' Excella from which someone removed the middle (to repair another trailer). So if I put the front and back end together, I've essentially got a Bambi with all dual pane windows. I've been watching progress from a couple forum members who have installed Timbren axle-less suspension systems. Basically, you set up a trailer with four wheels and no axles, and each wheel has it's own suspension. It's a pretty cool system, and the guys who installed them are using them on 31' trailers, so a 17 foot "Bambi" shouldn't be a problem.
I already pull my 25' Landyacht with a diesel Jeep KJ 4x4, and I've been in some pretty crazy places, but with another 8 feet shaved off, no axles to hinder clearance, and four wheel independent suspension, I should be able to really take advantage of this cool place in which we live.
I have already been implementing systems and ideas that make four season boondocking much easier, so those will obviously be implemented: much better insulation with thermal barriers on all ribs, all mechanicals and lines grouped together for easier "freeze proofing" in winter, tanks set up to allow for four season use, an elevated sleeping platform to allow for space below for dogs and storage as well as an isolated area that is easier to heat/cool in extreme situations, and so on.
I plan on using Coosa or hopefaully sourcing the material that Airstream is now using for subfloors (depending on how well it works in the field), and building out the underside to be tougher than typical (reinforcement, undercoating, not housing items that are fragile, etc.).
This trailer will also be quite a bit lighter than stock Airstreams.
My goal is to have a short, custom Airstream that looks really cool going down the road, but can also access spaces that a "regular" Airstream can't go.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
03-30-2021, 01:02 PM
#83
1972 25' Tradewind
1975 24' Argosy 24
Denver
I can confirm that with a little bit of modification, you can install a Fantastic Fan in an existing Airstream roof vent (the original vent). I have an "office" in my yard (the middle portion of a 31' Excella) that utilizes a Fantastic Fan in the original Airstream vent housing.
I have also been experimenting with various high capacity 12v computer fan set ups instead of a Fantastic Fan. They don't move as much air, but as such, they are much quieter. It becomes an issue of configuration to maximize airflow (multiple points of entry) and preventing water ingress.
BeahmStream.com
03-30-2021, 01:53 PM
#84
Denver
That sounds awesome.
I am pretty happy with the height. It’s big but so is the ground clearance.
I am taking a similar approach with making it a true 4 season trailer as well as off grid!
1974 Ambassador (Boondock or Bust) - In Progress
Denver, CO
03-30-2021, 01:54 PM
#85
Denver
I would have done the Maxxair but they are about 3X the price and I really just want the basic functionality of exhausting hot air when needed. I don’t see myself running the fans when it’s raining as I could always keep the big side windows open. We shall see!
Denver, CO
03-30-2021, 02:04 PM
#86
1972 25' Tradewind
1975 24' Argosy 24
Denver
You never need a fan in the rain... until you do. I have gone back and forth on this issue a lot. Mostly, I just don't like littering the top of the rig with all kinds of garbage that sticks up and takes away from the lines.
My land yacht has vent lids that tilt, but my Argosy has vent lids that lift uniformly (at all four corners)... if it's a gentle rain you can get away with keeping the non-tilting ones open.
I'm actually more for figuring out how to put fans in windows for cross-breeze. Any holes in the roof are mostly good for leaks.
BeahmStream.com
03-30-2021, 06:22 PM
#87
Denver
Makes sense. I had Fantastic Fans on our old 21’ Winnebago and it rained a few times when we needed the fans. I just raised the vent enough to let the air out and it worked. Definitely can’t run them on the high setting but it moved enough air to be comfortable.
Completely agree on cross flow. Would be cool to have a powered side vent but again seems like overkill. My feeling is if it’s too hot have another beer .
Denver, CO
03-30-2021, 10:34 PM
#88
Denver
Drilled out the rivers in all three roof vents. Had to do it from the interior which was challenging. Plus drilling over your head a good 50+ rivets is not fun. But it is done.
Tomorrow I will remove the old roof vents and get ready to install the fantastic fans and skylight.
Denver, CO
03-31-2021, 10:56 AM
#89
1972 25' Tradewind
1975 24' Argosy 24
Denver
I assume you're saving everything, but I'd be interested in those old vents if you're just recycling them.
BeahmStream.com
03-31-2021, 11:04 AM
#90
1966 24' Tradewind
Kansas City
, Missouri
I need a 50x50 shop ha ha. But for now my project progress is based on the weather!
Yeah, well, I have one (or should say that my nephew graciously lets me use his). Sometimes I think I might be further along on my project, if working outdoors imparts any sense of urgency.
03-31-2021, 11:20 AM
#91
1972 25' Tradewind
1975 24' Argosy 24
Denver
In the midwest it does (it's gonna rain!).
In CO it doesn't. If it isn't sunny today, it will be tomorrow!
BeahmStream.com
03-31-2021, 01:18 PM
#92
Denver
All yours! DM me.
Denver, CO
03-31-2021, 06:16 PM
#93
Denver
CO weather has a mind of its own and I love it. I schedule my work around the next days weather.
Denver, CO
03-31-2021, 09:29 PM
#94
Denver
Grabbed some pictures after getting the stairs back on.
I was in a bit of a rush on the year down that I realize I am missing some critical stair parts. Currently I have the stairs you see in the picture with the 4 bolts on. It’s actually functional in the down position but it obviously doesn’t stay up as I am missing the levers etc. Any ideas?
Denver, CO
04-01-2021, 06:11 PM
#95
1972 25' Tradewind
1975 24' Argosy 24
Denver
I can take a look at what's missing when I come down there and we can compare it to mine and figure out how to replace what's needed.
BeahmStream.com
04-01-2021, 06:16 PM
#96
1986 34' Limited
1975 27' Overlander
Conifer
Those folding aluminum stairs are neat, but kind of a pain. A replacement is maybe $850. I believe there are three kinds of bolts that hold the various joints together, and they are expensive too. I think we paid maybe $25 for each bolt.
Out of Doors Mart has step parts, for a price of course.
We could not get the up position retention mechanism to work right when we reassembled the stairs. So we just made a simple latch that holds the stairs up from the outside.
David
04-01-2021, 11:42 PM
#97
Denver
Very nice.
Denver, CO
04-01-2021, 11:43 PM
#98
Denver
David
I’ll look on out of doors and see what they have. I don’t even know what I am missing.
Denver, CO
04-02-2021, 06:09 PM
#99
Denver
Started working on the roof. 1 fantastic fan in and 2 patches from the old TV antenna and plumbing vent.
Whoever thought roofing tar was a good idea should find a building to jump off.
Denver, CO
04-02-2021, 06:10 PM
#100
Denver
They have everything. Just a lovely $150 in basic parts.
Denver, CO
