Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1954 - 1959 Safari
Old 11-27-2011, 10:13 AM   #21
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Will you please explain how (and with what) you made the roller? Thanks.
RankAm is offline   Reply With Quote
Old 11-27-2011, 04:05 PM   #22
SafariSteve's Avatar
1956 22' Safari
Gresham , Oregon
There have been a few posts about similar rollers. Its really a simple idea and one that has been around a long time. Some rollers are totally homemade, and other people have been able to find ready-made options. Everything from a metal-shop project to a formica countertop roller.
In my case, I worked with what I had in the garage... a heavy duty adjustable paint roller, a skateboard wheel, a suitable bolt, wing-nut and a few flat washers that gave it clearance to roll easily. I think a longer handle will give it more leverage... the paint roller handle is threaded so that's an easy option. Also if you can access both sides it will work better... more like an English Wheel.
SafariSteve is offline   Reply With Quote
Old 11-28-2011, 09:03 AM   #23
RankAm's Avatar
Dallas , Texas
Thanks. Will you please explain how you built the shaft to which the wheel is bolted? Is it the original shaft for the paint roller that you reconfigured?
Old 11-28-2011, 10:42 AM   #24
1956 22' Safari
Gresham , Oregon
Yes. The shaft was already part of the adjustable paint roller handle. I looked around on line and this is the closest thing I could find.
http://www.thebossmaker.com/index.htm
As I said, I used what I had in my garage. I don't know how common these style of paint rollers are (I think mine was a gift) but I don't think I ever used it for painting.
Good luck!
-Steve
Old 12-18-2011, 12:43 AM   #25
1956 22' Safari
Gresham , Oregon
Thanks to a helpful fellow Air Forums amigo, I was able to locate two sconces to match the one that we have in our trailer.
I've spent the last few evenings refurbishing one, and it's looking good. I still have to locate three new lamp inserts with the switch on the back, but the shade and base are looking great.
For the base I removed the latex paint, and applied a few coats of black Rustoleum hammer finish. Same with the base of the shade.
The fiberglass shade just needed a good scrubbing, a little 0000 steel wool rubbing and three or four coats of Penetrol. I'm happy with the results. Two more to go.
ID:	147196   Click image for larger version
ID:	147198   Click image for larger version
Old 02-06-2012, 05:21 PM   #26
1956 22' Safari
Gresham , Oregon
I'm finally ready to finish putting in new plywood for the subfloor.
Now this may sound strange, but my hang up has been what should have been a very simple thing: new wires for the trailer brakes.
Originally, one heavily sheathed wire containing two strands was fished through holes drilled through the frame along the center under the floor and above the belly pan, T-ing off to both wheels.
I couldn't find similar wire. The auto parts and home stores only had single strand. More than one salesman tried to send me home with wires for speakers, thermostats, lamps, or just said to zip tie two wires together. I sent in my question to The Vintage Airstream Podcast guys who said I could ask for trailer brake wire at any trailer parts counter. I asked at the Camping World parts counter and they thought I was from the moon.
Then it hit me... an extension cord. I had a 50-foot 12 or 14 gauge two wire (non ground) my son had chopped the end off while trimming a bush. Perfect!
I was a little worried about burying a nut connection at the T junction like they did back in 1956, and the guys at The VAP had a solution for that. Run one wire from the umbilical to one wheel, then connect another wire between the two wheels. No more connection buried between the belly pan and the subfloor. I could use all the original holes, and only have to drill one more for the connecting the two wheels together wire.
It's done now, and ready for me to install insulation and new plywood.
Whew! 'Bout time!!!
ID:	150474   Click image for larger version
ID:	150476   Click image for larger version
ID:	150479   Click image for larger version
Old 09-10-2012, 12:15 AM   #27
1956 22' Safari
Gresham , Oregon
I think it's time to get serious. The wife thinks May would be a great time for a shakedown inaugural voyage.
I know this schedule is both basic and ambitious, but I gotta have a goal!
SEPTEMBER
Patch and rivet bellypan
Install remaining 2 subfloor sections
Remove last old floor section
Install final new subfloor section
Reseal vents
Reseal seams
Polish when possible
OCTOBER
Install new running lights
Rewire existing tail/brake lights
Rewire umbilical cord
Rewire interior (lights, outlets,
Paint rear bumper
Fix gas tank holder
Paint tongue
Fix dents in front
NOVEMBER
Replace interior wall panels
Reseal windows
Replace broken glass
Fix rear window
Buy and replace window openers
Reseal door
Concoct door lock solution
DECEMBER
Paint interior
Install 1/4 plywood over subfloor
Install interior overhead lights
Sort out plumbing
Sort out electrical (batteries, fuse box)
JANUARY
Install floor
Layout interior
Locate major systems (tanks, water heater, gas heater, batteries, refrigerator, cook top, gas lamp...)
FEBRUARY
Build cabinets that contain systems
Fabricate bathroom floor and black tank cover
MARCH
Finish and install cabinets
Obtain and install new brakes
Install new tires & wheels
APRIL
Upholstery
Countertops
Booth table
Foam for beds
Curtains
Screens
MAY
Shakedown camp weekend!
Fix nothing, because everything will work perfectly
Finish polishing while sipping an ice cold Arnold Palmer
Old 09-10-2012, 07:47 AM   #28
Central , Mississippi
That looks llike a plan!
One thing to remember...The sooner you get behind, the longer you have to catch up...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 09-21-2012, 07:46 AM   #29
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Sounds like a plan! You need to add "post more pictures on AirForums each month" to your list! We all want to follow along with your progress ~
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 10-02-2012, 08:50 PM   #30
1956 22' Safari
Gresham , Oregon
Uh oh. I am making good progress, but there is one bad rusty spot. Two holes... Both about the size of a quarter.
Any advice? I have a welder and a father-in-law who really knows how to use it.
ID:	169448   Click image for larger version
Old 11-13-2012, 10:06 PM   #31
1956 22' Safari
Gresham , Oregon
Making progress!
ID:	172713   Click image for larger version
Old 01-23-2013, 07:25 PM   #32
1956 22' Safari
Gresham , Oregon
Slipped in the front piece of subfloor today. One more piece (tomorrow) then on to rewiring.
Old 01-24-2013, 06:51 AM   #33
Vintage Kin
Fort Worth , Texas
I subscribed just now, and am also wondering in what way "retirement home" applies to the TT?
Old 01-24-2013, 07:51 AM   #34
Melody Ranch's Avatar
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Nice work on a great 56. I highly recommend sealing the edges of the flooring before its in place. I also paint and seal the entire floor panels....top and bottom....personally I use top quality porch paint...others go the poly coatings.
Old 01-24-2013, 03:43 PM   #35
1956 22' Safari
Gresham , Oregon
Thanks! I have applied many coats of oil based waterproofer to all of the edges and even gave both top and button sides at least 1 coat. Porch paint would have been a good choice, but I wound up using deck waterproofer.
Also, I just realized that the final piece I cut using a mostly rotten piece as a pattern is 3/8" too wide. Time to trim and reseal. :-/
Old 01-24-2013, 03:52 PM   #36
1956 22' Safari
Gresham , Oregon
If by TT you mean Tavel Trailer, it's what my wife calls our trailer in anticipation of when we can retire and travel around the country. We're SO looking forward to it. :-)
Old 01-24-2013, 06:55 PM   #37
1956 22' Safari
Gresham , Oregon
I managed to pop the last subfloor piece into place today. FINALLY! I had to trim 3/8" off one edge, so i gave it a few coats of sealer. Now I just have to screw them into place and move on to the wiring.
Yikes. I don't know how to do the wiring. Wish me luck. :-)
ID:	177375   Click image for larger version
Old 01-24-2013, 08:04 PM   #38
Vintage Kin
Fort Worth , Texas
Originally Posted by SafariSteve View Post
If by TT you mean Travel Trailer, it's what my wife calls our trailer in anticipation of when we can retire and travel around the country. We're SO looking forward to it. :-)
The sticks & brick house will be sold, a few items put in storage, and you're on the road?
I ask, as I am not presently aware of anyone else with a TT of this age doing the same (and others will correct me, in short order).
There are many gradations of full-timer. I am one, but the TT is unlikely to travel much the next 1-2 years (full-time work, plus a very good amount of repair/restoration about to commence). After which it may travel quite a bit. I'm ready to move out of South Texas. But I'm not retired. By choice, TV & TT contain all of what I own. I won't say this 35' is crammed, but both vehicles will take some planning to get separated what is necessary from what is simply desired. A smaller TT with two people is a good bit more work in this same line (so I am wondering aloud).
It isn't that I mean to pry, but to understand better what I am looking at as I read your thread. That is some careful planning to undertake if my assumptions above were correct.
Your year model (those years, per se) are beauties, IMO. I love the windows!!
Old 01-25-2013, 01:13 AM   #39
1956 22' Safari
Gresham , Oregon
Perhaps "retirement vacation home" would be a more accurate term to describe what the ultimate purpose of the trailer will be.
Our future plans will be multi month excursions to wherever the two of us want to visit. We are both born and raised westerners and are looking forward exploring what goes on east of the continental divide. :-)
We are planning on keeping our "sticks & bricks" and adding a few places that will act as "home base" close to areas we find interesting... But first things first. I gotta get this Safari roadworthy. And we agree... The 13-panel end caps and the 10' bank of windows on the 54-56 Safari are awesome. We just hope to be able to start enjoying it soon.
Thanks for the encouragement!
Old 01-25-2013, 04:44 AM   #40
Vintage Kin
Fort Worth , Texas
Thanks for the explanation. An excursionary vehicle. Interior design is fraught with compromises. Tougher than it looks. Much tougher.
Look forward to more!
AS Tax Deduction as Second Home boutdoors Dollars & Cents 36 05-16-2016 02:58 PM
1500 Mile Trip to get her home - Suggestions? Bambi_Bandit 1960 - 1964 Overlander 17 03-01-2015 05:17 PM
New home for Safari idmtman Member Introductions 7 02-06-2011 07:46 AM
