09-25-2007, 10:38 PM
#141
If that bill arrived in our mail. I'd hear, "we can't keep spending like this!!!, then peel Chris off the ceiling. Yikes!! Are these tanks anodized aluminum?, or just plain ole plastic? :-)))
JIM n CHRIS
‘62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,’90 SQ Sream, ‘06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
09-26-2007, 12:24 AM
#142
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
I know, the sticker shock kinda hit us too...but, when you compare it to a new 10 gallon fibergalss black tank for Maxwell which would be $450 +/- and it's readily available and mass produced - it's not so bad. These are custom made to specifically fit the curves & frame spacing on our trailer that never had tanks to begin with. All are welded 1/4" thick polyethylene sheets (not fiberglass - which I believe are more prone to pin-holes over time).
Black Tank - Tank "A" is an above floor with a radiused corner - capacity 11 gallons.
Grey Tanks - Tank "B" & Tank "C" are below floor trapazoid shaped grey tanks - the combined capacity is just over 17 gallons.
Fresh Water Tank - 30 gallons and we already have it - it's one of the few things that came with the trailer that we are able to re-use. The two grey tanks fit within the frame and don't hang down below and maximize the capacity available.
Tank "A" = $482.12
Tank "B" = $412.24
Tank "C" = $518.33
Shipping = $87.00 (oversized) from CA
So, once it's broken down...it's not as bad as it first appears.
Shari
P.S. I've attached a .pdf of the tanks & sizes...but they are specifically for our trailer with minimal tolerances, so I doubt anybody would really have a need for them except as a reference or to understand what we are doing.
09-26-2007, 12:40 AM
#143
1968 17' Caravel
Battle Ground
Well, it's also one of those things that you don't want to do later, and it's only practical to have grey tanks (and an absolute necessity to have black), so who cares what it costs. I'd do it too. It's just shocking to see the total. But that sure will be nice. Did you add grey tank to maxwell? That is something I've sure wished I had in the caravel. If I have to redo the floor in the back someday I'll add one then. I like that you can order the tank just the shape and size you need.
Stephanie
09-26-2007, 12:50 AM
#144
1956 22' Safari
Conifer/Evergreen
No, we didn't have to do anything like this on Maxwell. His black tank is fine and the floor was solid, so there was no need to get into the frame/floor and mess with things. If/when we need to change the black tank out, we may consider it. In the meantime, the blue tote is fine...has been since day one for us. We either camp where grey on the ground is okay, have hook-ups or deal with the blue tote - maybe twice a year. We even debated whether or not to put the grey in Birdy...but as I've said more than once, these trailer restoration projects are slippery slopes...
Shari
09-26-2007, 05:45 AM
#145
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
OK, so tank C goes under the front floor...right? Centered between the begining of the A-frame?
Tank B under the floor to the curbside? And the Black tank in the front streetside floor cavity? These look like more than 17Gal, though.
I think the price is fair. The convenience and clean install more than make up for it, you will soon forget the money spent.
09-26-2007, 07:31 AM
#146
1956 22' Safari
Conifer/Evergreen
Yes. The kitchen will drain directly into this one.
No, this one goes on the street side under the front dinette seat. It will pick up the shower & bath sink. The two grey tanks will be connected so they level each other out and fill together as needed.
No. This one goes above the floor in the front streetside corner. The curve of the banana wrap doesn't leave much room in the frame area. The tank will be above the floor with a low profile toilet sitting on top. We will then be getting a stainless steel floor pan that steps up over it made as ours is a wet bath.
The two grey tanks should be just over 17 gallons combined - they are only 3-7/8" high - the black one is about 6" tall. The total of all three tanks is supposed to be about 27-28 gallons - we'll see when they arrive and we can actually test them.
After the intial sticker shock...we feel the same. No regrets - we are restoring this trailer as a "keeper" not to spin and get our money out.
Oh yeah, we also calc'd the "full" weights as follows:
Tank "A" = 91.8 lbs
Tank "B" = 48.1 lbs
Tank 'C" = 97 lbs
It's a lot of tongue weight...but is well balanced with the kitchen cabinets on the curb side - and we don't intend on traveling "full".
Shari
09-26-2007, 07:41 AM
#147
1956 22' Safari
Conifer/Evergreen
Yeah, but we only have two trailers to restore, store and maintain... uh, what's your herd up to now?
Shari
09-26-2007, 08:14 AM
#148
Ahhhh, you got us there! Just check our signature, as the list "could" grow?"-)))
JIM n CHRIS
09-26-2007, 08:35 AM
#149
1956 22' Safari
Conifer/Evergreen
Yeah...I've heard those whispers in the wind...
Shari
09-26-2007, 09:06 AM
#150
1951 21' Flying Cloud
1960 24' Tradewind
West Coast
, BC
Shari,
There will always be folks who can find a better deal than I seem to get. Sometimes substantially less. I don't know how they do it and I wish I had the knack - a case in point - an inline hot water heater - our buddy picked a brand new one up at a garage sale he happened past on the way home from breakfast one morning and paid $10. It works great in their trailer. I can't find a comparable unit anywhere for under $200. He constantly finds good deals and that's his lot in life.
Overall, when things are all said and done, you will have a gorgeous trailer that is fully functional to your needs for a fraction of what a new(er) one would have set you back. Finding the right tanks to fit your exact requirements is expensive. When I was pricing tanks I was blown away at what some of them cost. Your trailer should be a beauty when it's done.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
09-26-2007, 10:42 AM
#151
1968 17' Caravel
Battle Ground
Originally Posted by safari57
Shari,
I've known people like that too - and I hate them
I'm one of those who rarely catches a break and often pays top dollar during the wrong season when it costs the most. Oh well!
Stephanie
09-26-2007, 12:26 PM
#152
1956 22' Safari
Conifer/Evergreen
So Barry, are you saying you think I'm getting a deal or over-paying?
I think it's fair...considering a ready-made fiberglass tank is about the same price.
Shari
09-26-2007, 01:10 PM
#153
1960 24' Tradewind
West Coast
, BC
Shari
Shari - I think you are getting an acceptable deal. The tanks are what you need and no playing around trying to fit tank "deals" that are not quite the right size or shape. It's what I'd be doing - I'm tired of spending more time and effort trying to make the special deal fit when for a few dollars more I could have had the real thing. What ever it takes to get your trailer done in a timely manner.
Steph - yep, you and I seem to be in the same boat (uh, no reference to your own recent acquisition of course). I'm always at the upper end of the pricing scale it seems. But hey, life is good, I have what I want (well, mostly ) and if I really need a deal on something I've been known to ask the deal getter buddy to see what he can find.
Barry
Barry & Donna
09-26-2007, 02:16 PM
#154
1956 22' Safari
Conifer/Evergreen
My sentiments exactly...
Shari
10-04-2007, 03:57 PM
#155
1956 22' Safari
Conifer/Evergreen
Got the tanks today...that was pretty quick!
If I get home before dark, I'll post pics of them where they go - if not, I will this weekend.
Shari
10-16-2007, 08:56 PM
#156
1956 22' Safari
Conifer/Evergreen
Okay...day late and a couple of dollars short! But here are the pics of our tanks - placed temporarily in the frame just resting on the belly pan. Also our Sealand Low profile toilet.
Shari
10-17-2007, 10:46 AM
#157
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area
, Tennessee
It's encouraging to see these possibilities. I'm sure one day I'll have to replace the Tradewind's black tank. And gray tanks would REALLY be nice.
Birdy is going to be an awesome coach.
10-17-2007, 11:05 AM
#158
1956 22' Safari
Conifer/Evergreen
Oh boy, oh boy, oh boy!
Birdy had a busy "ebay week"...she even bought something to share with Maxwell!
Can't wait to start putting things back together!
Shari
10-17-2007, 08:15 PM
#159
1963 16' Bambi
Southeastern Area
, Tennessee
Man, I never find cool stuff like that. You must have some fantastic search strategy.
10-28-2007, 04:43 PM
#160
Massachusetts
Replacing floor w/o removing shell?
Shari -- I saw on an earlier post in this thread that you are replacing the floor without removing the shell. How will you do that? I thought the ribs were attached to the top of the floor.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
