Old 08-19-2016, 10:59 AM   #1
Sprouty's Avatar
1972 23' Safari
1963 16' Bambi
1947 22' Liner
Hillpoint , Wisconsin
Pipe frame owner.... Whats under you subfloor?
We are working on a 1947 liner and built a new frame for it. We recently pulled the shell off the old frame. Here is what we found. Its scary to think I towed it home and to a rally but it seemed pretty sold. We have two other pipe frame Airstreams to restore and I know the frames on those two are far worse then this one.
ID:	269455   Click image for larger version
ID:	269457   Click image for larger version
Sprouty is offline   Reply With Quote
Old 08-19-2016, 11:10 AM   #2
Sprouty's Avatar
1972 23' Safari
1963 16' Bambi
1947 22' Liner
Here is the replacement frame.
Old 08-28-2018, 10:35 AM   #3
1948 22' Liner
Bordeaux , Gironde
Great job
Beautiful job Sprouty. How long did it take to do that ?
pierrew is offline   Reply With Quote
Old 08-29-2018, 09:04 AM   #4
Sprouty's Avatar
1972 23' Safari
1963 16' Bambi
1947 22' Liner
[QUOTE=pierrew;2148678]Beautiful job Sprouty. How long did it take to do that ?[/Q
I have a local shop build them. I bought an AutoCAD file form a guy and then we tweaked the design with the shop. They cut the metal with a water jet and welded it up on a jig. It then went to a powder coating shop . I had two built and how we have everything in place to build more as needed.
Old 09-09-2018, 08:13 PM   #5
MsRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Send a message via Yahoo to MsRivet
A Hot Mess
Seventy years of rodent dwellings!
The pipe frame is in rough condition. MrRivet knows there is one point of an almost complete rust through. Will know full extent of its condition soon when we do the shell transfer to the new frame. Iím sure at that point we will realize that maybe we should not have towed her home when the purchase was made. LOL
Safe Travels ~
MsRivet
Not all those who wander are lost.
Living the Dream ... Plan B
The 70 year journey of our Airstream Liner . . .
https://www.airforums.com/forums/f60...ey-176336.html
MsRivet is offline   Reply With Quote
Old 09-10-2018, 04:54 AM   #6
Sprouty's Avatar
1972 23' Safari
1963 16' Bambi
1947 22' Liner
That looks very familiar. Itís a great picture of how the ribs where secured to the frame. They just bent brackets out of aluminum sheet and pounded a type of twisted shank spike in to hold it. Itís amazing how well it held up for 70 years!
Good luck with the project.
Old 09-19-2020, 11:07 PM   #7
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Ballarat, Victoria , Australia
Wow! Im glad i found this thread Sprouty. I'm building a '49 TW chassis and intent do do something similar. I'll make cross members much the same as original but in steel, and run a pair of 4x2"s right through as you've done, but I'll keep the full length of 4" pipe as well.
I like the way you've tapered the ends of the RHS to stay away from the belly pan.
Stu
ID:	379045   Click image for larger version
Name:	Screen Shot 2020-09-20 at 2.57.10 pm.jpg
Disco Stu is offline   Reply With Quote
Old 09-20-2020, 06:38 AM   #8
I tow where I'm told.
MrRivet's Avatar
1948 22' Liner
1963 22' Safari
Oakland , Florida
We are restoring a 1948 Liner and this is what we ended up doing. It gave us the ability to add A 30 gallon Fresh tank and two 16 gallon connected tanks for grey water storage. We used 2x6 tubing and channel to keep the visual depth to the belly pan. Once it was wrapped with aluminum it has the appearance of a pipe frame.
Safe Travels!!
Tim
MrRivet is offline   Reply With Quote
Old 09-20-2020, 03:24 PM   #9
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Thanks Tim, I've been watching your thread and will be referring to it when it comes to belly pan time...
leak in water pipe under shower tray Annikins212 Sinks, Showers & Toilets 3 06-13-2014 03:56 AM
subfloor under door frame kokomoscalls Repairing/Replacing Floor &/or Frame 2 02-16-2014 07:27 PM
Aluminum sheet under subfloor? neeliebell Repairing/Replacing Floor &/or Frame 2 10-21-2013 12:16 PM
Exposed Subfloor Under Doorway? Ridgerunner3 Repairing/Replacing Floor &/or Frame 2 12-30-2011 03:53 PM
Factory tour ... Reflectix under subfloor? Zstream Repairing/Replacing Floor &/or Frame 4 07-30-2008 05:01 AM
