Old 11-22-2021, 08:05 AM   #1
Barretta2's Avatar
2013 23' Flying Cloud
Naples , Florida
Tampa for body work?
I was exiting a gated community when the security gate closed on my 2012 FC. Significant body damage: door jammed, rear awning arm pushed back which ripped the panel seam top and bottom are the worst, although it also skewed the opposite side Equilizer bar so it was very tight to remove.
I live in Naples, FL…is there consensus that I should take it to Airstream of Tampa for repair?
TIA
Barretta2 is offline   Reply With Quote
Old 11-22-2021, 08:59 AM   #2
2022 Atlas
Homosassa , Florida
I would go to Jackson Center.
Tater is offline   Reply With Quote
Old 11-22-2021, 10:42 AM   #3
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Have you considered Airstream of South Florida at North Trail in Fort Meyers? I've never used them, but they are close to you.
Old 11-27-2021, 11:08 AM   #4
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
We had body work done at Southland Airstream/RV in Norcross, GA (metro ATL).
Like you, our incident included the rear awning arm being ripped off. They did a nice repair job.
They replaced the two rear corner panels and reinforced the awning attach point with an aluminum plate. Looks good. They gave me the option of replacing the entire upper side panel in lieu of the plate. I went with the plate.
They do a lot of body work there and stock the body panels. Because there isn’t access to interior without removing interior panels, they use Olympic rivets. As a precaution I sealed each new rivet with Captain Tolley’s. This probably wasn’t necessary since a sealing tape goes down in between panels where the rivets go.
You’ll hear a lot of different opinions re: Olympic rivets, however.
Just research the local dealer, as you are doing. If they do a lot of body work and have a good reputation I wouldn’t hesitate to use them.
KK4YZ is offline   Reply With Quote
Old 11-27-2021, 11:27 AM   #5
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
I had significant damage to my right rear quarter panel from backing into a pole while parking last year...I looked at several local TX locations but ended up going with JC as I wanted other stuff done as well while there.
That said, I visited Tampa (flew) to help my son pick up his Basecamp20X earlier this year...had I brought my AS, I would have had them fix the body damage; they were very knowledgeable about body work on an AS, had capacity resources, and could quoted me 3 day turnaround with similar $$ as JC. I saw some work they were in process of completing on another AS unit. I talked with them and was impressed. I would have taken my unit there if it were closer to TX...but as I mentioned, I wanted other work done at JC, like squeaky floor fixed, and we also wanted to attend Alumalina so we coordinated a month long trip; (ended up going down to St. Augustine and Destin FL anyway.)
2017 28' Twin Flying Cloud
Wide body vs narrow body Eric. Our Community 25 11-18-2021 09:21 PM
1996 wide body body parts - Texas byjaffe Airstream Classifieds 0 11-05-2020 09:16 AM
Need HELP in Tampa- Looking for someone to fix frame/ subfloor in Tampa? Mixter Repairing/Replacing Floor &/or Frame 13 12-08-2012 09:19 PM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 02:25 PM
Body work -- backed into a post :( Kistler Ribs, Skins & Rivets 11 08-21-2003 04:37 PM
