Old 08-06-2020, 04:16 PM   #1
2020 16' Caravel
San Jose , California
What is is dripping hose?
I suspect it is like condensation from the AC unit, but can someone confirm? Thank you! (newbie yes)Click image for larger version
Julbingo is offline   Reply With Quote
Old 08-06-2020, 04:26 PM   #2
2019 25' Flying Cloud
Houston , Texas
Originally Posted by Julbingo View Post
I suspect it is like condensation from the AC unit, but can someone confirm? Thank you! (newbie yes)Attachment 375067
Air conditioner.
DCPAS is offline   Reply With Quote
Old 08-06-2020, 04:39 PM   #3
2018 25' International
Slidell , Louisiana
Welcome to the forum and to Airstream camping! The evaporator drip pan also has a roof overflow in case the hose gets stopped up and condensation will run onto the roof if the trailer is not reasonably level. Also in Heat mode the outer coils condensation will just run onto the roof along the rain rail and down the side of the trailer.
Brian
BayouBiker is online now   Reply With Quote
Old 08-06-2020, 05:24 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There is also a drip tube from the Fridge ... it carries condensate from fridge area so it doesn’t pool in the fridge. There is a trough under the fridge internal coil... if those coils dripping.. that’s your water.
If not then AC.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-06-2020, 05:56 PM   #5
2020 33' Classic
DFW , Texas
Front AC unit on our Classic 33.
no_worries is offline   Reply With Quote
Old 08-06-2020, 05:58 PM   #6
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Welcome and greetings from PA!
Yes, it's most likely condensation from the A/C.
Old 08-06-2020, 08:15 PM   #7
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
If not then AC.
The fridge drain tube usually terminates in the compartment behind the fridge, where there are scuppers that let water (including from rain or sprinklers) drain out of the compartment. The hose the OP has pictured is definitely from the roof ac.
Peter
Instagram: @thealuminumtent
pcskier is offline   Reply With Quote
Old 08-06-2020, 08:19 PM   #8
2020 16' Caravel
Thanks everyone for all the response! Much appreciated!
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 8 04-15-2020 12:46 AM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
dripping hose at bib Marks71 Sprinter and B-van Forum 19 09-02-2016 11:42 PM
Dripping hose tarnished All Argosy Trailers 4 02-23-2013 06:20 AM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
