05-12-2022, 04:01 PM
2022 20' Caravel
Southeastern
, Pennsylvania
Weboost and Caravel Cable/Satellite Port
Has anyone installed a Weboost cell signal booster using the Cable/Satellite port on your Caravel to connect the external antenna? I'd like to avoid having to punch a hole in the trailer and screw around with internal cable routing if I can repurpose this port and cable for the antenna.
Thanks!
05-12-2022, 05:20 PM
2020 23' Flying Cloud
2019 22' Sport
Sebastian
I’ve done it. With the right adapters from Amazon, it seemed straightforward.
The problem is, it didn’t always result in a strong signal. Weboost doesn’t provide an indication of signal boost, so you don’t know if the signal is so weak that it’s a lost cause, or or are getting by on the ambient signal.
Another poster indicated it didn’t work for him, but he didn’t know why not.
Recently I have just run their cable through the bug fuzz on the dinette window.
The last time I organized my storage, I noticed a loose connector on their cable.
It’s all not quite the game changer I had hoped for, so I only attempt using the Weboost when I can’t get the cell data to work at all.
Bottom line: minimize the complications if you can. If you want to be elegant, get a signal meter to verify results.
-Don
(That man in that tiny can)
(Same man, Bigger can)
05-13-2022, 05:31 AM
2022 20' Caravel
Southeastern
, Pennsylvania
I was also realizing that with the combined Satellite/Cable/Antenna wiring in the Caravel, it would likely not be possible to use the Weboost external antenna and the HDTV antenna simultaneously.
05-13-2022, 12:40 PM
Delaware ZMan
2016 22' Sport
Lewes
, Delaware
I added my connector this way, and installed the amplifier under the closet in my 22fb. It’s a little tight to twist the connector when hooking up, but very effective.
05-13-2022, 12:56 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
- Stewart
05-14-2022, 06:04 AM
2022 20' Caravel
Southeastern
, Pennsylvania
Yeah, I was thinking that re-using the cable connector would cause interference between the cell boost and the HDTV antenna if trying to use both.
05-14-2022, 06:05 AM
2022 20' Caravel
Southeastern
, Pennsylvania
Originally Posted by s1000pre
Thanks. Unfortunately, the Caravel doesn't have separate SAT and Cable ports, and the HDTV antenna multiplexes on the same cable, so it seems that I'll need to run a new cable if I want to implement this.
07-31-2022, 08:55 AM
2020 19' Caravel
SANTA MARIA
We recently went with the STARLINK sat dish that's super easy to install for even newbies. It does not provide better cell service but does provide excellent WiFi if you have a clear view of the sky. In areas where the campsite had zero cell service and zero WiFi (as most do) this option worked amazingly.
2020 Caravel 19cb
Haven't arrived but well on our way!
KK6YFG
Central Coast of California
Calvary Chapel of Santa Maria
08-02-2022, 01:05 PM
2022 20' Caravel
Southeastern
, Pennsylvania
Out of curiosity, did you turn on "Wifi Calling" on your phones? If so, you may be able to receive and make cell phone calls over Starlink.
Unfortunately most of the places I'll be going will be tree covered, so Starlink is probably not an ideal option for me.
08-03-2022, 08:23 AM
2020 19' Caravel
SANTA MARIA
Starlink
Yes, we have, and it works pretty flawlessly.
Open sky is really a must if possible though, but it's always worth a try wherever you camp. I've been recently surprised by how many campers are using Starlink.
2020 Caravel 19cb
KK6YFG
08-03-2022, 10:46 AM
2024 30' Globetrotter
Houston
I have installed a WeBoost destination RV connected through the external satellite port on my 2021 Caravel 22FB.
The pre installed satellite cable terminates by the stereo and blue ray player and is clearly marked. Simply screw that cable in to the input side of the WeBoost amplifier and your all set.
There were no adapters required for me to connect my external WeBoost antenna to the external caravel satellite port.
Both systems are 75 ohm.
Works great and easy installation.
08-03-2022, 10:54 AM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
This works, assuming you do not need/use your satellite for TV...many do. So running a separate 75 ohm cable recommended...I am going to remove the outside connecting junction (SAT/CBL) port, disconnect the Cable line, and run a separate line under my stove/sink area and under my L seat, next to the water heater tank on the L-couch; then run it up the back of the couch to the front deck behind the couch. AC receptacle right there next to the window. Will report once complete...next day or so.
Still looking for best directional antenna pole location; Fiama in rear or A frame up front...suggestions with pictures appreciated.
10-02-2022, 05:26 PM
2022 23' Flying Cloud
2006 28' Safari SE
Gold Beach
, Oregon
I have a WeBoost I was using in my previous RV. I figured I could use the satellite port and am happy to see that it will work. Can you tell me how and where you installed the omni directional antenna? Thanks.
Idmtman
2022 Flying Cloud 23FB (Yalla)
2010 Toyota Tundra 4x4
TAC: ID-1
10-03-2022, 10:18 AM
Houston
I installed the external antenna on the telescopic 25’ pole that I clamp to the A frame jack when parked.
The internal antenna I keep in the AV storage locker by the amplifier for travel. When in use I pull it out of the locker and collect to the ceiling of the airstream with a magnet. The magnet is glued to the back of the antenna and a small metal disk is glued to the ceiling. It’s a cell phone mount re-purposed :
[ 2 Pack ] Magnetic Phone Mount,... https://www.amazon.com/dp/B07PRBJTFT...p_mob_ap_share
10-03-2022, 10:49 AM
2022 20' Caravel
Southeastern
, Pennsylvania
Have you tried simply leaving the internal antenna in the AV locker? I suspect it would perform more than adequately there. Just curious.
10-03-2022, 11:49 AM
Houston
I have and signal strength is definitely impacted, but can be good enough. One other reason I have for pulling it out of the locker is to ensure I get enough separation between the external and internal antennas to prevent feedback. I only have a 22’ trailer so the geometry is a challenge!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Can you run a Cell Booster through the Cable/Sat port?
febbraro |
Computers, Internet & Satellite |
49 |
09-03-2022 10:41 AM |
WeBoost using satellite connections
jnm30327 |
6 |
04-22-2020 04:10 AM |
any residents of Sequim ,Port Townsend or Port Angeles
kingfisher24 |
On The Road... |
6 |
10-15-2013 08:57 AM |
Satellite TV AND Radio, Theatre-like Sound, Cable, iPod, and Bluetooth all in one!!!
78GussyTX |
Audio, Video & TV |
12 |
11-12-2008 09:36 PM |
Installing cable port for tv
mtpalms |
Electrical - Systems, Generators, Batteries & Solar |
4 |
04-19-2005 09:44 PM |
