Old 04-22-2024, 09:37 AM   #1
2024 20' Caravel
Westerville , Ohio
Shower and holder broke - quick fix?
Hi there! Took 24 Caravel 20FB for maiden voyage and shower wand would not go into holder very easily, and apparently I didn’t put it back correctly, because when we got back to home base, shower wand was on shower floor and tannish part that it clips into had fallen out of the housing up top. Is this easy to fix? It it always so awkward trying to put the shower wand back into it’s holding place?
CopyPirate is offline   Reply With Quote
Old 04-22-2024, 09:58 AM   #2
2022 20' Caravel
Southeastern , Pennsylvania
We replaced ours with this:
https://www.amazon.com/gp/product/B07Y2GLRMZ/
RickBullotta is offline   Reply With Quote
Old 04-22-2024, 10:47 AM   #3
2008 22' Safari
WE NEVER travel with the shower-wand in its holder. We Always place it on the floor of the shower….usually inside a collapsible rubber bucket we bought at WalMart and find useful for all kinds of duty while travelling.
https://www.walmart.com/search?q=col...va2Yyj9Rjjm90c
Old 04-22-2024, 11:25 AM   #4
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
If it's truly broken, I'd add this to the warranty repair list. In our experience Airstream is pretty good about replacing stuff that gets broken even if it could be construed the customer broke it. They are replacing our bathroom mirror even though we ran over a curb which caused it to flip up. We contacted our dealer and they ran it by Airstream and offered to send the part. Our trailer is in JC for other repairs so I had them do the fix, but with something like this the part might simple to replace.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 04-23-2024, 11:00 AM   #5
2021 16' Caravel
Fullerton , California
CopyPirate,
2021 Caravel 16, upgraded shower head and holder to this:
https://a.co/d/67GrojA
FYI, you should always take head off the wall and place on the floor during travel, and might as well because it will end up there anyway. In our small wet bath, I simply wrap up the hose and head and place behind the toilet to keep it from sliding around.
Hope this helps. Hope you enjoy your Caravel as much as we do.
NeahBay is offline   Reply With Quote
Old 04-23-2024, 11:47 AM   #6
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
We replaced ours with the Oxygenics also. Not because ours broke but because it's just a much friendlier head to use. The spray pattern is better, and the off/on flow lever works better.
Also, like Boxite recommended, place it on the floor when traveling.
Mikebrady62 is offline   Reply With Quote
HDMI End Broke! Is THIS A Fix..Maybe..??? TravisH Audio, Video & TV 9 06-26-2023 08:23 AM
Trailer Steel Step Holder Broke mythbuster88 Steps 8 03-31-2020 09:37 PM
Suburban NT 30M Furnace quick fix Chuckles Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-16-2013 04:21 AM
Marker lights--quick fix tip. Sneakinup Lights - Interior & Exterior 1 12-01-2003 02:42 PM
window broke, need advise on how to fix infinite LUX Our Community 4 08-03-2003 08:55 PM
