Old 06-28-2022, 08:59 PM   #1
The Wodlands , Texas
Removing plastic wrap remnants
Picked up brand new AS yesterday - not complaining but there are lots of rivets and panel edges with plastic wrap remnants. Other than meticulously tearing them off is there a safe more efficient way of removing.
TIA
waxman003 is offline   Reply With Quote
Old 06-28-2022, 09:17 PM   #2
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
We’re in our third camping season with our 2020 International 23FB and I’m still removing them.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Sierra Denali 1500
Airstream Club International #2805
Dennis C is online now   Reply With Quote
Old 06-29-2022, 06:01 AM   #3
2022 20' Caravel
Southeastern , Pennsylvania
Annoying, isn't it? This should be a basic quality check on delivery.
RickBullotta is offline   Reply With Quote
Old 06-29-2022, 06:29 AM   #4
2019 25' International
Providence , Senior Electrical Engineer
It is nearly impossible to get them all......how would quality sort this out?
As mentioned above....3 years later, we still have them....and peel off when/where we can.
kittmaster is offline   Reply With Quote
Old 06-29-2022, 09:27 AM   #5
solomon.m's Avatar
2020 27' Flying Cloud
Livermore , California
Agree the cling film bits are challenging to remove, I've had best success with plastic tweezers that came in a small first aid kit. I think they are provided for pulling slivers, stingers and plant thorns?
solomon.m is offline   Reply With Quote
Old 06-29-2022, 11:45 AM   #6
2022 20' Caravel
...then it shouldn't be used in the first place. Or during dealer prep they could take the time to do the best possible job removing them. It's rather cheesy having a $90,000 trailer with bits of plastic sticking out from under rivets and joints. I think they can do better.
Old 06-29-2022, 12:00 PM   #7
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Then there would be complaints about scratches on the surface of the aluminum and someone would say why don't they cover the aluminum with a plastic film.
Old 06-29-2022, 01:08 PM   #8
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I don't have any traces of plastic wrap left on my trailer - it is long gone, if it was ever there. But, I've worked with other equipment with similar problems.
Wondering if a heat gun on low setting used carefully would help at all? My thought is that it will cause the plastic film to shrink and pull away from the rivet.
Would obviously be a good idea to test this in an area not in direct view in case it doesn't work.
Richard
11018
richard5933 is online now   Reply With Quote
Old 06-29-2022, 04:22 PM   #9
Spaggs's Avatar
2022 28' Flying Cloud
GAINESVILLE , GA
After getting them almost all the way off, has anyone tried a hair dryer or heat gun to shrivel up the remainder of these little bugers? Just got our TT last month and wow, there are so many.
TV: 2000 Ford Excursion 6.8 liter, 2 WD, 4:56 G2 gears, remanufactured everything. 2022 28 FC, 50 Amp, Queen, ProPride w/V2 Jacks, Hughes EMS.
Goal: be able to comfortably spend 5 days a week boondocking (shower every few days or so) and at least once travel to AK.
Spaggs is offline   Reply With Quote
Old 07-31-2022, 01:22 PM   #10
Roo
2022 19' Caravel
Walkerton , Indiana
Perhaps try heating up a piece of the wrap first on a work bench or something your not worried about messing up. See what it will take to get it to shrink or hopefully not go straight to gooify.
Roo is offline   Reply With Quote
WANTED Insulation remnants: fiberglass, rock wool/ mineral wool - New Mexico EmilyRosebud Airstream Classifieds 0 03-22-2022 01:22 PM
Using the front side wrap as a template for the rear side wrap haaseome Belly Pans & Banana Wraps 0 10-11-2021 08:32 PM
Rear side wrap template when rear side wrap is missing haaseome Belly Pans & Banana Wraps 0 10-09-2021 01:13 PM
Mid way through interior vinyl removal - how to remove remnants and cross-hatch? mikeandnora Upholstery, Blinds, Walls & Interior Finishes 24 07-12-2012 09:12 PM
Replacement plastic banana wrap for 93 Excella flintgrease Belly Pans & Banana Wraps 0 09-12-2009 09:31 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
