RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-21-2020, 03:38 PM   #1
2021 16' Caravel
Callao , Virginia
Lug Nut Socket Size - Caravel 16RB
Hi! New member here. My wife and I are picking up a Caravel 16RB early next month. We're newbies to travel trailers and this forum has been a great source of information - thanks! I do have one question I have not been able to find an answer for, though.
What size socket do I need for the tire lug nuts on our Caravel 16RB?
I emailed Airstream and they said 1/2", but that seems awfully small. I see from another thread in this section that the 19CB calls for a 13/16" socket, which is a lot bigger.
Does anyone who has a Caravel 16RB know what size socket I will need? Any guidance you can provide to this newbie would be greatly appreciated!
kmrice is offline   Reply With Quote
Old 11-21-2020, 04:07 PM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
I use a deep 3/4" socket (19mm should be interchangeable with that, by the way)
— David
Old 11-22-2020, 08:38 AM   #3
2021 16' Caravel
Callao , Virginia
Thanks! I see you have a Flying Cloud 26U. I wonder if the lugs on the Caravel 16RB are different? 3/4" seems reasonable, but Airstream said 1/"2", which seems pretty small.
I'm having TPMS devices installed in the wheels, so I know the wheels will have been recently remounted when I pick up. I want to be sure I can torque them periodically as called for in the manual.
Old 11-22-2020, 08:53 AM   #4
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
My 2020 International has 13/16” lugs. I was told by my Airstream dealer that they were 3/4”, but I very quickly found out that the dealer was wrong.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Dennis C is offline   Reply With Quote
Old 11-22-2020, 09:07 AM   #5
Silvr_Bullet's Avatar
42° 2' 27" N / 74° 7' 6" W , US
Receiving conflicting answers? Call Airstream at Jackson Center.
Silvr_Bullet is offline   Reply With Quote
Old 11-22-2020, 10:41 AM   #6
UnklJoe
2015 28' Flying Cloud
Box Elder , South Dakota
If memory serves me correctly, the stud ("bolt") size is 1/2-inch, and the lug nut size is 3/4" or 13/16"--depending on whether or the those stupid tin covers are used on the lug nuts. I think I read somewhere that AS had discontinued them, but I met someone this summer with a 2019 AS which still had them from the factory. (AS is nothing if not consistently inconsistent. Wait until you have to replace screws in door hinges and shelves--and you WILL (have to replace screws in door hinges and shelves).)
I always use a four-way lug wrench for all my vehicles, and that pretty much covers all the typical sizes of lug nuts. I find using the four-way lug wrench easier than a ratchet and extension and socket--I have MUCH more leverage. I then use a torque wrench and extension and socket to tighten the lug nuts to the proper torque, and then I check the torque after an hour or two of driving. And I'm always pretty surprised at how much the lug nuts "loosen" (require re-torqueing) after a couple of hours. (I carry a socket set and not just one socket, so I'm covered there, too.)
UnklJoe is offline   Reply With Quote
Old 11-22-2020, 11:03 AM   #7
2021 20' Bambi
MURFREESBORO , TN
Lug Nut Size
I took delivery of a 20 foot Front Bedroom Bambi in early November. I have purchased a Craftsman 1/2" drive torque wrench, a 5" extension and a 13/16" socket for the lug nuts. It fits perfectly. I am thinking that the 1/2" is the drive size. I hope that helps.
TIM ACREE is offline   Reply With Quote
Old 11-22-2020, 01:15 PM   #8
greenflag's Avatar
2016 30' International
Quartz Hill , California
Make sure the socket you purchase is a six point. There is less chance of rounding off the lug nut. I use a 1/2 inch breaker bar to loosen them prior to raising the tire off the ground. I believe the torque spec for them is 100 ft/lbs.
greenflag is offline   Reply With Quote
Old 11-22-2020, 02:01 PM   #9
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
Yes to this and add the 6 point socket.
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup,
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 11-22-2020, 03:21 PM   #10
Mollysdad's Avatar
Since we're talking sockets, my lug nuts are 13/16".
I bought one of those cross wrenches that has all four sizes. Couldn't use it, because the Sendel rims have the nuts recessed, you need a six point DEEP, THIN WALL, socket to fit.
But sockets are cheap, relatively, so why not get both 13/16" and 3/4"? The 3/4" will fit the stabilizer jacks in case you think about using a cordless drill to make life easier. "More is more".
Toss in a 3" extension and a 1/2" drive breaker bar from Harbor Freight ($20, get the long one) and lug nuts will fear you!
I use the breaker bars on the hitch also, and all that gear lives under the back seat of the truck.
Old 11-23-2020, 08:22 AM   #11
UnklJoe
YES to the six-point socket!
And, YES to the six-point socket--which is an absolute necessity if the lug nuts have those stupid tin covers.
All the four-way lug wrenches I have ever seen (since I was knee-high to a grass-hopper) only have six-point "sockets" on them. The last one I bought (from Harbor Freight) had six-point "sockets."
Guess I'll have to check the Sendel wheels next summer, because a 3" lift kit and 16" tires are looming in our future....
Old 11-23-2020, 08:53 AM   #12
Agree, your solution provides leverage that helps reduce tennis elbow. Everyone know what tennis elbow is? Hint it’s not always associated with playing tennis☹️
Old 11-23-2020, 12:25 PM   #13
2021 16' Caravel
Callao , Virginia
Thanks so much for all the helpful replies! This forum sure is has a wealth of information.
I called Airstream and the person who answered at the service department immediately said "I'm sure they are 13/16ths but let me check to be certain." He did, and confirmed that they were 13/16ths. I appreciated his checking to make sure. Thanks for the suggestion that I call.
It looks like those of you were correct who suggested that the 1/2" my email from Airstream referred to really meant the drive size, not the lug size.
caravel
Basecamp lug nut socket Bullwinkle Base Camp 18 09-18-2020 08:33 AM
Basecamp Lug Nut Socket - found it! otisb Base Camp 0 09-15-2020 09:59 AM
Lug nut socket size jaygoree Wheels, Hubs & Bearings 7 03-04-2015 03:54 PM
Where do I get a lug nut socket Antique Pedaler Wheels, Hubs & Bearings 3 11-27-2006 06:59 PM
Lug Nut Socket Help... AZstreamin Wheels, Hubs & Bearings 20 09-21-2006 07:04 AM
