Old 11-14-2020, 03:19 PM   #1
2018 Basecamp
Memphis , Tennessee
Caravel Tank Heat
I recently sold my 2018 Basecamp with tank heater and purchased a 2021 Caravel without tank heat. I boondocked as low as 14 degrees in my Basecamp with no freezing issues. Does anyone know if Caravels have tank heaters Iím not finding?
BC18 is offline   Reply With Quote
Old 11-16-2020, 05:10 AM   #2
2020 19' Caravel
Wapakoneta , Ohio
I don't believe they have a tank heater but they are insulated and the ducting for the furnace goes around or by them to help.
jagpanzer is offline   Reply With Quote
Old 11-16-2020, 05:27 AM   #3
2018 25' International
Slidell , Louisiana
In addition to the furnace ducts as mentioned, with any volume of water in the tanks, it will take a couple days to freeze given the insulation. Even if you do not use the furnace, say you use a portable heater, the conduction down to the tanks will increase freeze time to several days. Eventually the cold will catch up to the tanks with no furnace heat. You can add hot water to the tanks every once in a while also. Also a good idea to wrap the dump line with bubble wrap to reduce cold conduction through the pipe for extended cold.
Brian
caravel
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
