Old 06-24-2022, 02:45 PM   #1
2021 16' Basecamp
Denver , Colorado
audio switch for JL Audio
Hi. Just took delivery of my 2022 20FB Caravel. To my surprise I discovered the JL Audio system is powered on when the battery disconnect is turned on. No separate on/off switch for the audio system other than remembering to turn it off every time you turn on the battery. When the cover is on the from of the JL Audio system you do not know the audio system is on resulting in unneeded battery drain. Sorry Airstream, but this is just cheap. Also putting a single 90 watt solar panel on the roof when the Basecamp at half the price comes with two panels is a joke. I have ordered 2, 90 watt B line Zamp panels from Zamp and a 90 watt portable with a built-in regulator from Zamp. That should take care of the battery charging issue. The Audio system fix that I came up with is to install a on off switch to power the Audio System on off separately. Before I take this on does anyone else have a fix to the Audio system issue? Many Thanks
Harry123 is offline   Reply With Quote
Old 06-24-2022, 07:11 PM   #2
2020 23' Flying Cloud
2019 22' Sport
Sebastian , Florida
If the reception on your JL is as poor as it is on my ‘20 23FB FC , you’ll never be turning the system on anyway.
As for the second solar panel, it may have as much to do with the target buyer or the real estate available on the roof as the cost. Airstream would never cut corners simply to enhance their profit.
Happy camping! That’s a nice trailer you bought!
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 06-24-2022, 07:27 PM   #3
2015 25' Flying Cloud
Schaumburg , Illinois
since you just took deliver of a *new* unit, here's something to consider before you wire in a separate on/off switch. I agree with you, that makes no sense that the battery disconnect does not include the radio so perhaps what you really have is a wiring mistake. Based on other posts across the forum, errors like this are not as rare as we would all hope them to be. If you have the time to invest, I would try to trace back the power feed of the stereo, it might be a dedicated line all the way back to the main electrical panel, and it might be wired on the wrong side of the disconnect switch. A simple move of that wire to a +12vdc terminal on the other side of the disconnect would be the best fix, but it will take some time to research it in your trailer, and it might be an effort full of frustration. It will help you in the long run, to become more familiar with all the wiring and how the systems are connected.
1StreamDream is offline   Reply With Quote
Old 06-24-2022, 07:47 PM   #4
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
Why do you need a separate on/off switch for the audio system? There’s already an on/off switch on the JL Audio system. Why not just push that and turn it off? Adding a second switch seems redundant.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Sierra Denali 1500
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 06-24-2022, 08:21 PM   #5
2021 16' Basecamp
Denver , Colorado
Thank you StreamDream I will take a look at the wiring and see if I can trace back. Dennis C: the JL Audio unit auto turns on whenever the battery switch is turned on. There is a travel cover on the JL audio so I didn't even notice it was on after turning the battery on. There is no way to turn off the JL Audio unit so it will not turn on when the battery switch is turned on, I contacted Airstream and was told that is the way the Caravels are wired. Obviously not good for battery life if you do not notice that the power is on to the audio unit
Old 06-24-2022, 08:35 PM   #6
Dennis C's Avatar
Ok, got it. Thanks. My JL Audio unit switches off when I press the power button and it doesn’t come on unless I press the button again.
I hope you get the issue resolved.
Dennis
Old 06-24-2022, 08:53 PM   #7
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
Mine works like this. Drives me nuts! Why on earth would this make sense to anyone?
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 06-27-2022, 12:13 PM   #8
2022 16' Caravel
London , Ontario
We have 2021 16RB and it does not work as you describe. It does not power on unless the button is pressed on it. I use it for bluetooth from phone for music.
critical367 is offline   Reply With Quote
Old 06-27-2022, 02:57 PM   #9
Escape Pod II
John Ware's Avatar
2018 22' Sport
2022 23' Flying Cloud
Orange , TEXAS
Could you be inadvertently pushing the on button when you put the rubber cover on? You think it is off and it really isn't and don't realize it is on until you power the trailer back up.
JEWare
John Ware is offline   Reply With Quote
Fixing bad water heater switch placement near light switch gmattingly On The Road... 5 07-06-2019 07:26 AM
Audio Speaker Select Switch? pteck Audio, Video & TV 9 11-01-2017 07:18 PM
whats this switch? next to storage kill switch. Looking4air Electrical - Systems, Generators, Batteries & Solar 1 06-28-2013 01:59 PM
Light Switch (Wall Switch) for 69 Overlander mbmbstreamer Lights - Interior & Exterior 3 03-21-2010 04:39 PM
Repairing The Audio System Rodger with a D Audio, Video & TV 1 07-20-2004 10:11 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
