Old 04-03-2021, 01:12 PM   #1
Tamarack's Avatar
2019 Nest
Oregon City , OR
Water pump indicator light mystery...
The water pump "on" indicator light had never worked since we purchased our trailer new. I just figured it must be a faulty unit. The other day I decided to take a look and I discovered the white wire from the SeeLevel harness (meant to be jumpered to the switch) neatly folded back and bundled with the other wires and secured by electrical tape. It had never been stripped and this appears to have been intentionally done. I can't think of a reason why the factory would do this??
I kind of like having that little light as a reminder that the pump is on
Name:	Water pump light wire.jpg
ID:	392265   Click image for larger version
Name:	Water pump light.jpg
Tamarack is offline   Reply With Quote
Old 04-03-2021, 04:29 PM   #2
2020 19' Caravel
Ammon , Idaho
My guess is that was the condition it was left in after all the wiring was installed. For some reason, oops, it was not connected in at the same time as the rest of that bundle. Given that it is only a feedback light, I also guess everything passed QA since the pump and the monitor display worked..
So I would say the only intentional part was that the wire was where it should have been, the rest was oversight.
Very cool that you figured it out and fixed it. I bet it feels pretty good to see that light on now.
OutdoorIdaho is offline   Reply With Quote
Old 04-03-2021, 04:47 PM   #3
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
Interesting. I didn’t even know there was a light there!
I may do that too. How did you connect it?
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 04-03-2021, 06:10 PM   #4
Tamarack's Avatar
2019 Nest
Oregon City , OR
Originally Posted by Dennis C View Post
Interesting. I didnít even know there was a light there!
I just put a new crimp spade connector on the side of the pump switch with the single/red wire -- crimping the white wire in together with the red wire.
Much simpler that the way I just described it
Old 04-04-2021, 11:43 AM   #5
2018 28' International
Mesa , Arizona
On my 2018 28ft international, I took it back to the dealer because the light didn't work. Dealer explained that the light comes on only momentarily when first turn on then goes off. If the water heater is not coming on the light comes on and stays on as a warning.
kdfulsome54 is offline   Reply With Quote
Old 04-04-2021, 11:45 AM   #6
Mesa , Arizona
Sorry everyone, I read that first line as water heater instead of water pump. My bad.
Old 04-11-2021, 07:14 AM   #7
love nest's Avatar
2019 Nest
Louisa , Virginia
I found that in May 2020 and the dealer told me that it was supposed to be like that because all the others where like that. The video for Airstream showed the light working. I found the diagram on the Seelevel web site. It was when I was having problems with my 12v breakers.
2019 Nest FB
2014 F150 STX 5.0
SS Works long headers & Duel exhaust, Banks Ram Air
5 Star Custom Tune
Louisa, Virginia
love nest is offline   Reply With Quote
Old 04-11-2021, 08:44 AM   #8
Tamarack's Avatar
2019 Nest
Oregon City , OR
You should have posted what you found out back in May (maybe you did and I just couldn't find it ) and it would have saved me some time!
Old 04-11-2021, 06:03 PM   #9
love nest's Avatar
2019 Nest
Louisa , Virginia
I thought I had sent it as part of a thanks but I looked back and did not see it. Will try to do better. I was a forum Newbie.
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
Old 04-11-2021, 06:08 PM   #10
Tamarack's Avatar
2019 Nest
Oregon City , OR
Ha! You jogged my memory, and I just found your private message that very clearly tells me about that mysterious white wire! I'm the one who should be apologizing! Thanks
Old 04-12-2021, 09:24 AM   #11
Dennis C's Avatar
I’ve been camping for the last couple of weeks and I’ve been on city water, so I haven’t used the water pump. I switched it on today after thinking about this thread, only to find out that the green light already works in my International. I’m surprised I hadn’t noticed this before. Thanks for bringing it to my attention!
Dennis
added water pump switch/indicator to IS 19 preedtx Sprinter and B-van Forum 0 10-24-2020 12:26 PM
Water heater Indicator light carver 1 Water Heaters, Filters & Pumps 9 01-21-2014 10:16 AM
water pump on off indicator light featherbedder Electrical - Systems, Generators, Batteries & Solar 7 03-01-2013 09:16 PM
Black Water Light Indicator & Water Heater problems SGM ADAMS General Repair Forum 9 04-17-2012 05:18 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
