08-06-2020, 10:53 PM
#21
2021 23' Globetrotter
VICTORIA
, British Columbia
I had this done to my 16' Caravel .
08-07-2020, 08:40 AM
#22
2019 Nest
Oregon City
, OR
Looks great!
08-22-2020, 04:11 PM
#23
2019 Nest
Oregon City
, OR
The sink finally installed!
This was so easy! OK, not a horribly difficult project in the end. It just required staring at it for hours trying to figure everything out and about 20 trips to the store.
It's "thru" bolted to the wall and along with a layer of 3M VHB mounting tape -- feels rock solid. I'll post some of the plumbing details later.
08-28-2020, 08:56 AM
#24
2019 Nest
Louisa
, Virginia
Bathroom sink
Morning
Just wondering, where does the drain and faucet hoses go once they disappears into the wall.
2019 Nest FB
2014 F150 STX 5.0
SS Works long headers & Duel exhaust, Banks Ram Air
5 Star Custom Tune
Louisa, Virginia
08-28-2020, 11:47 AM
#25
2019 Nest
Oregon City
, OR
Originally Posted by love nest
Morning
I drilled holes in the wall and just stuck them in! kidding...
I'll post some of the plumbing details that I previously promised this weekend.
We just got back from camping for several days and the sink worked out great!
08-29-2020, 11:41 AM
#26
2019 Nest
Oregon City
, OR
Some plumbing details
I'm sure the plumbing could be done in different ways (probably better), I used a 1 1/2" abs fitting with a 3/4" hose connection to connect the drain. I wanted a 1" hose connection to match the sink drain , but couldn't find one. It would probably have been easier to use a "saddle" to tap into the pipe, but i was nervous about leaks. I disassembled the roof vent to give me a enough flex in the pipes to put this fitting in. Whatever you choose to tap into the drain pipe, be sure to check that it clears the bathroom cabinet/toilet paper holder; mine does, but barely!
I am going back to put a "trap" of some sort to prevent drain odors (maybe inline trap), but I was in a hurry getting ready for a trip. We just plugged the sink when not in use. The good news is, that removing the bathroom cabinet for access to the plumbing is very easy and there's quite a bit of room for extra plumbing back there.
For the sink water supply, i just used a SharkBite T fitting to tap into the shower line (easy). I used a hole saw cut the hole for the water supply line. So, when we were at our campsite, we turned on/adjusted, and left the shower faucet on (shower sprayer off) and it supplies warm water to the sink when you open the sink faucet - worked great.
For the sink mounting bolts, i was able to reach behind the shower wall and use large metal washers to bolt thru on the back side with nylock nuts. As I mentioned previously, i also used heavy duty mounting tape between the back of the sink and the wall.
In hindsight, I might have gone with a taller faucet. This is a very small sink and I have large hands , but I really liked the quality and looks of the marine faucet. We are very happy to have a sink in the bathroom!
08-29-2020, 02:54 PM
#27
2019 Nest
Louisa
, Virginia
Bathroom sink
Looks very slick. Guess it is my turn. Any help with where to get the parts would also be helpful. Will start with cutting the sink that I already have.
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
08-29-2020, 04:18 PM
#28
2019 Nest
Oregon City
, OR
For the drain, you could use something like I did https://www.amazon.com/Canplas-11233.../dp/B00GK3S2GA or you could use a saddle style if you can find it in ABS plastic https://www.amazon.com/FIMCO-1-1-ABS.../dp/B00KY0NUE4
I just used washing machine drain hose, but there may be better choices out there.
The water pipes are 1/2" Pex piping. I have the tools for working with this, but the SharkBite fittings are so easy to use! I purchased locally, but the fitting I used is similar to this https://www.supplyhouse.com/SharkBit...EaAr99EALw_wcB
You'll have to figure out adapting to the supply line. No doubt there's a better way to do this than I did -- I might be changing this too, but it works for now.
09-04-2020, 05:26 PM
#29
2019 Nest
Louisa
, Virginia
Bathroom sink
Here is something you might like. The faucet is from Amazon, HOMEWERKS WORLDWIDE 3210-150-CH-B-Z Chrome Single Heavy Duty Basin Faucet
Sold by: hardwarestoreusa and the handle is from Lowes. Idem#297414 Visegrip lever diverter
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
09-04-2020, 05:46 PM
#30
2019 Nest
Oregon City
, OR
Nice! I'm looking forward to seeing your version of this installation
09-12-2020, 01:18 PM
#31
2019 Nest
Louisa
, Virginia
Bathroom sink
Ok, finally done. Same thing only different. Had to change to the shower trap drain cover because the saddle was too small for the vent pipe. Was still able to use the sink drain trap so all was not lost. It turned out as a bonus because I found the problem with the shower drain when I opened it up. It had a funky gasket on the flapper that was sticking to the opening causing me to have to plunge it all the time. Pealed off the gasket and it works great. Also I left the check valve to the shower head in the line. Also, it took both drains to make one that worked for the sink. thanks for all your help.
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
09-12-2020, 01:25 PM
#32
2019 Nest
Oregon City
, OR
Great! Definitely not a project for the "faint of heart" - ha ha!
Really glad it worked out for you!
10-22-2020, 01:41 PM
#33
West Haven
, Utah
This is amazing! We are considering the 16rb Caravel and thought it was awful having to clean up in the kitchen sink as well. Did you do this yourself or hire someone? How would one find someone to retrofit a sink as you have? Thank you! Nish
11-12-2020, 04:08 PM
#34
2019 Nest
Oregon City
, OR
The bathroom continues to change...
Added a step in front of the very tall toilet and a hanging trash can.
11-13-2020, 07:17 AM
#35
2019 Nest
Louisa
, Virginia
Bathroom changes
Morning
Looks really good. Did you build the step your self and where did you get your trash can. The dimensions would do also.
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
11-13-2020, 08:16 AM
#36
2019 Nest
Oregon City
, OR
Morning
I modified a step I purchased -- cut the height down, etc. https://www.teakworks4u.com/products...62c3a481&_ss=r
The step fits very securely in place, but for extra safety I added some heavy duty waterproof Velcro on the bottom where it sits on the shower pan. Obviously, I pull the step out for a shower.
The trash can is still a work in progress, but it hooks over the cabinet door and you can slide it under the sink as needed. I've tried two different versions. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
01-16-2021, 12:33 PM
#37
2019 Nest
Oregon City
, OR
Still making changes...
I changed faucet to get a bit more height under the spout -- other faucet was a bit too low for my big hands
Added some motion sensing led lights in the cabinet and went with a stainless trash can that easily lifts off the mounting bracket for a shower.
01-17-2021, 10:35 AM
#38
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Its looking great. Are the toilet paper holder and soap dish suction on or fastened, standard or after market?
Thx
Hittenstiehl
01-17-2021, 12:36 PM
#40
1962 28' Ambassador
Mesa
Thank you for sharing. They add to the look.
Hittenstiehl
