Old 06-26-2020, 06:51 AM   #21
2019 Nest
Brevard , North Carolina
Originally Posted by Stephen Ryan View Post
Thanks so much for sharing! Great idea and it is very useful for me. However, I don't know how to install it. Is anyone can give me some suggestions?
Stephen. Read all of the posts on this thread. I posted some specific instructions and a photo of the dimmer switch I used. You would need some basic wiring skills, tools and a multimeter
TheHoff is offline   Reply With Quote
Old 06-29-2020, 05:35 PM   #22
love nest's Avatar
2019 Nest
Louisa , Virginia
Dimmer switch
Originally Posted by TheHoff View Post
Plenty of room behind the switch. See photos of my instillation
Did you need to add a piece of plastic to mount it to the original switch plate.
love nest is offline   Reply With Quote
Old 06-29-2020, 06:56 PM   #23
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
How about an on/off switch on the porch light fixture? I had this in my old trailer. It was an RV grade 12V DC fixture with a small on/off rocker switch.
Or if you are handy, drill a small hole in the porch fixture and install a little on/off switch. This is probably more of a direct solution rather than trying to find an oval shaped RV fixture with a switch.
Then you can just leave the wires alone and change one fixture or wire in the switch to the 2 wires that go into the porch light. You would still have access to having them all on or turn off the porch light and have the awning and handle lit up.
Name:	Screen Shot 2020-06-29 at 5.54.09 PM.png
PB_NB is offline   Reply With Quote
Old 06-30-2020, 06:58 AM   #24
2019 Nest
The on/off switch would work, but I have to say being able to dim the outside lights adds another level of cool to the Nest and is great when sitting outside at night.
Old 06-30-2020, 07:01 AM   #25
2019 Nest
It has been a while now, but as I recall, I did have to fabricate an interface mounting piece I made out of a scrap of high black high density polyethylene, but still used the original mounting plate so it all looks original. I did post a photo of the final install.
Old 06-30-2020, 09:48 AM   #26
love nest's Avatar
2019 Nest
Louisa , Virginia
Dimmer switch
For those that have not done anything yet I found this on eBay. Airstream dealer wanted $100. 513178 - Switch panel, Backlit LED digital dimmer. Could not get the link to work but this is the Airstream part # and you can do a search that will bring you to the spot on eBay. Around $45
Old 07-01-2020, 08:47 AM   #27
love nest's Avatar
2019 Nest
Louisa , Virginia
Dimmer switch
https://www.ebay.com/p/1553693476?iid=352571219410
The brand of the switch is ELLO-ITC and their part # is 2130-BKBNBK for black and 21030-WHWH for white. This link works.
Old 08-23-2020, 07:41 AM   #28
love nest's Avatar
2019 Nest
Louisa , Virginia
Dimmer
Long time getting it done. Just got it back.
2019 Nest FB
2014 F150 STX 5.0
SS Works long headers & Duel exhaust, Banks Ram Air
5 Star Custom Tune
Louisa, Virginia
Old 10-29-2020, 12:25 PM   #29
2019 Nest
Austin Area , Texas
Thanks for finding this dimmer that looks just like the other dimmers in our Nest. Amazon delivered mine yesterday. I have a few questions….
1 - Did you install it yourself?
2 - If so, where did you hook up the ground wire? and
3 - How did you expand the hole in the wall panel?
Thanks In Advance - BeSerious
BeSerious is offline   Reply With Quote
Old 10-30-2020, 08:00 AM   #30
love nest's Avatar
2019 Nest
Louisa , Virginia
Dimmer
Morning
Go to ebay and look up the listing below. I tried a link but it did not work. it has the install diagrams. Yes I installed myself. The wiring is pretty obvious once you pull out the old one. I used a Dremel tool to enlarge the opening. Mark the opening centered on the original opening. I adjusted the new opening so that the top of the new one was even with the top of the others. Hope this helps.
ITC 21030-BKBNBK Backlit LED Digital Slim Dimmer Black Nickel RV Marine Lights
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
Old 10-30-2020, 08:09 AM   #31
love nest's Avatar
2019 Nest
Louisa , Virginia
Dimmer
Morning
I was wrong about the Jigsaw the blade is too long. Been a while.
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
Old 10-30-2020, 04:05 PM   #32
2019 Nest
Austin Area , Texas
Morning
...Yes I installed myself. The wiring is pretty obvious once you pull out the old one. I used a Dremel tool to enlarge the opening. ...
Thanks for the additional info.
The existing outside light switch only has incoming and outgoing 12v wires. The ITC 21030-BKBNBK Backlit LED Digital Slim Dimmer has an additional ground wire.
What I was really curious about was how/where you found a ground for the black lead. For example did you tap one of the 4 wires for the Awning In-Out rocker switch? And if so, which one?
Thanks again - BeSerious
ID:	382225   Click image for larger version
Old 10-31-2020, 04:27 PM   #33
love nest's Avatar
2019 Nest
Louisa , Virginia
Dimmer
Yes any system ground will work. Sorry I had not gotten back but my computer crashed and I am just now getting the replacement working.
2019 Nest FB
2014 F150 STX 5.0
5 Star Custom Tune
Louisa, Virginia
Old 11-01-2020, 06:47 AM   #34
2019 Nest
Austin Area , Texas
Thanks. Sorry to hear about your computer.
GetRealBro
Easy Fix for warming up those bright LED lights pcskier Lights - Interior & Exterior 47 10-15-2019 06:03 PM
Rear reading lights too bright? 1jacobo Sprinter and B-van Forum 22 11-06-2018 10:32 AM
Dark Sky - Bright Lights on MH's RV's at Campgrounds Michigander Land Yacht/Legacy Motorhomes 36 09-30-2018 02:15 PM
bright lights relay dieselblimp Classic Motorhomes 4 05-26-2016 09:59 PM
Bright idea for power savers Tinsel Loaf Electrical - Systems, Generators, Batteries & Solar 2 10-05-2003 06:48 PM
