Originally Posted by Teton Stream
PCSkier, read your post and thought I would share with you the outcome of installing an accumulator in my 2017 23FB to cut down on pipe noise. I did the same think on my 2010 20' FC Bambi and it worked perfectly. I tried it on my 2017 23FB and the water pressure went pear shaped... anemic pressures. When I called JC they informed that in the Bambi they installed pressure cut off pumps and in the 23FB they had installed variable speed pumps (speed of pump reacts to pressure needed versus demand pump on 100% until pressure reached). Took out the accumulator tank and pressures were back to norm... noise still present.
FYI
Thanks for this. I think I've read about that, but mine is a 2014 and that's the old on/off pump so I should be OK. I might even just get a new pump. But meanwhile, I noticed something on my last trip. The banging pipes in the shower seems to dissipate quite a bit once the shower has been used and the pipes that service it are full of water.
