Old 05-16-2021, 01:15 PM   #1
2021 27' Globetrotter
Turlock , California
What is this??
Washing my 2021 Globetrotter FBQ this AM I came across this (see photo). What is it??? It’s located over the front bedroom.
We do have SiriusXM from the factory and it has a separate antenna which is clearly labeled (differently) over the back end cap over the stereo.
The symbol on it looks like the WiFi symbol to me, but I can’t figure out what purpose it might serve. Any ideas?
Attachment 1
Eric
2021 Globetrotter 27 FBQ
2020 Superduty Powerstroke
ACI 2107 - Greater Bay Area Unit
emactex is offline   Reply With Quote
Old 05-16-2021, 01:23 PM   #2
Here's the photo...
Sorry - the AIR Forums app is vexing me and I can't figure out how to attache a photo from my camera roll. Here's the photo uploaded from computer.
Eric
Old 05-16-2021, 01:25 PM   #3
Oh geez...
Apparently, my spelling's not great ("attache a file") and I can't figure out how to rotate a photo being uploaded. The photo on my computer is right side up but it rotated 90 degrees counter-clockwise on upload and I couldn't figure out how to change it...
Open for any suggestions on what this mystery thing is on top of the trailer, AND on how to upload images to the Forum!
Eric
Old 05-16-2021, 02:45 PM   #4
Daytona Beach , Florida
“If I have seen further than others, it is by standing on the shoulders of giants.”
I was told and it seems to work for me, crop your photos so they are wider than taller , then save, download and paste.
nitzo is offline   Reply With Quote
Old 05-16-2021, 02:57 PM   #5
Awesome - thank you!
Eric
Old 05-16-2021, 03:04 PM   #6
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It is a cover for the pre-wire for the Airstream Connected system.
Under that cover are 5 wires for a Poynting Antenna system.
The cover has a small eyebolt screwed to the inside and the wires are zip tied to it.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 05-16-2021, 04:11 PM   #7
Coloradobus's Avatar
Installation looks pretty messy. And what’s with the bubbled paint. Im stunned this install is on a 2021 model trailer
JIM n CHRIS
‘62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,’90 SQ Sream, ‘06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
Coloradobus is offline   Reply With Quote
Old 05-16-2021, 04:26 PM   #8
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
That is not bubbled paint, it is water. However, it is a pretty sloppy sealing job around the attenna cover.
thewarden is offline   Reply With Quote
Old 05-16-2021, 06:10 PM   #9
2021 23' Globetrotter
Melbourne , Florida
You don’t have to limit it to the AS connect system. It should work with most Wi-Fi/Cellular antenna and router packages. I just installed mine yesterday. The pre install and the leads zip tied to the cover saved me hours of installation time.
Lumenyaare is offline   Reply With Quote
Old 05-16-2021, 06:18 PM   #10
Very cool - thank you!
Eric
Old 05-16-2021, 06:19 PM   #11
Thanks Lumenyaare! So then where do the wires terminate in the coach?
Eric
Old 05-16-2021, 06:48 PM   #12
Melbourne , Florida
Every coach is different. Mine terminated just under the cap in the overhead storage above one of my twin beds. I had to remove the panel at the end of the storage locker. Removed three screw caps and three screws and it opened up to the area where the speaker wires and the antenna leads are run.
Old 05-16-2021, 08:08 PM   #13
2020 25' Globetrotter
San diego , California
Also just turn your phone sideways when taking the photo and then make the image less than actual size. Try large or medium.
JunkYard is offline   Reply With Quote
Old 07-27-2021, 09:53 PM   #14
2021 25' Globetrotter
Kinnelon , New Jersey
Curious what antenna and router you used. I am also planning on installing one on my 2021 GT. I have an AT&T MiFi. Could I route the MiFi signal through the exterior antenna to get a better signal?
Jason P M is offline   Reply With Quote
