Old 02-10-2020, 08:43 AM   #1
2020 25' Globetrotter
Malibu , California
WFCO model?
Is the converter in the 25 GT the WFCO 8955?
Garfish is offline   Reply With Quote
Old 02-10-2020, 05:37 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Garfish, our 2019 27' GT has the 9855. We've got 50A service, dual A/C's.
On the 27', it's under the refrigerator, close to the distribution panel.
Not sure if it's different for the 25'. NOTE: The 8955 is the Distribution Center part number.
ID:	360892   Click image for larger version
Name:	Screen Shot 2020-02-10 at 6.48.55 PM.jpg
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 02-18-2020, 01:58 PM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
If you have an Airstream with a single A/C (30 Amp Service), then your shorepower converter is a WFCO 8955. This converter on my 2018 Globetrotter was able to charge at 13.8V and float at 13.2V. I never saw it charge at 14.4V like its advertised to do. Therefore, I replaced the battery charging section with a PD4655 Wildcat which will boost charge at 14.2V, absorb charge at 13.8V, and float charge at 13.2V. I wanted a 14.2V boost to quickly charge my batteries with a generator when boondocking. If you rarely boondock and charge with a generator, the stock WFCO 8955 charger will work just fine without upgrading.
2021 Northern-Lite 10-2 & F350 DRW PSD, 380W Solar/Victron/600A BattleBorn
0 nights 0 miles
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 02-20-2020, 07:12 AM   #4
2020 Globetrotter 25 FBT
GettinAway's Avatar
Wildwood , Missouri
AirMiles, we have the 25FBT with the WFCO 8955PEC. We do boondock fairly often, or stay in GGs without any hookups. I have been using a Honda 2000 to try and keep up with battery usage. (That was with a 23FB that had minimal battery drain). Iím thinking the GT25 will have quite a bit more power usage. How difficult is it to put in the PD4655? I did a similar install on the 23FB, but that was several years ago. Also, I was thinking of getting a suitcase solar charger. Can I have the solar charger and generator running at the same time? (With the PD4655?). Will it accept charging from both?
Thx
Jeff
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 02-20-2020, 01:56 PM   #5
AirMiles's Avatar
Originally Posted by GettinAway View Post
AirMiles, we have the 25FBT with the WFCO 8955PEC. We do boondock fairly often, or stay in GGs without any hookups. I have been using a Honda 2000 to try and keep up with battery usage. (That was with a 23FB that had minimal battery drain). I’m thinking the GT25 will have quite a bit more power usage. How difficult is it to put in the PD4655? I did a similar install on the 23FB, but that was several years ago. Also, I was thinking of getting a suitcase solar charger. Can I have the solar charger and generator running at the same time? (With the PD4655?). Will it accept charging from both?
Thx
Jeff
If you boondock often and charge with a generator you will benefit from upgrading to a PD4655. It was easy to install a PD4655 in my 30A Airstream. Just be careful to put the 120V wires and 12V wires in the right places. On mine, they needed to be criss-crossed versus the stock charger. I used the "Wildcat" version of the PD4655 and didn't need to change out the 12V fuse board.
Yes, you can get a solar suitcase and leave it connected while boost charging with a generator. My panels are permanently mounted so the solar charger is always connected and charging while I am boost charging with the generator and the PD4655.
0 nights 0 miles
Old 02-21-2020, 06:14 AM   #6
GettinAway's Avatar
Wildwood , Missouri
Thank you! I had to follow a YouTube video the last time I tried something like this. Is there a YouTube video for the PD4655? I’m sure you didn’t need to see a video, but it will help me for sure.
Thx
2020 25GT FBT
Old 02-21-2020, 07:01 AM   #7
Up North , Michigan
Perhaps this should help.
Greatlaker is offline   Reply With Quote
Old 02-22-2020, 05:17 AM   #8
GettinAway's Avatar
Wildwood , Missouri
Thanks Greatlaker! Currently on the road in our GT, but we have another long trip scheduled for September. I’ll need to get this done. Going to try something solar also, but on a very small scale.
2020 25GT FBT
Old 04-25-2020, 10:05 PM   #9
2019 23' Flying Cloud
Auburn , California
Too few pos terminals
Hello
I am also replacing my WFCO 8955 converter unit, but I have come across an issue. My new PD4655LIV fuse circuit board has 1 less pos terminal. See pictures. Top pic is current board. Do you know where I wire the extra red wire on the new board? Looks like it is coming from the battery.
ID:	366546   Click image for larger version
mountain1974 is offline   Reply With Quote
Old 04-26-2020, 05:43 AM   #10
AirMiles's Avatar
Originally Posted by mountain1974 View Post
Hello
You do not need to install the new board, the old board will work just fine. I did two PD4655L installs, one on my 2017 and one on my 2018 Airstream, and did not install the new board on either. I use the Wizard Pendant to switch the PD4655 into Boost mode and determine the mode based on the Pendant light. The new board basically only adds the Pendant's functionality.
0 nights 0 miles
Old 04-26-2020, 09:11 AM   #11
Auburn , California
I was wondering if I could do that. I have the lithium charger, so my understanding is the charge wizard doesnít work anyways and it outputs a continuous 14.6 V. I recently upgraded to lithium batteries and that was the point of changing out my converter. The only concern I would have is whether the old board is set up to handle the new voltage. The new board also came preinstalled with 30 amp fuses. Do I need to replace the old 40 amp fuses from the current circuit board? Not sure why they would be different. I also find it odd that I cannot find pictures of that specific circuit board anywhere online. Even the WFCO website has a different picture for that model. I have a 2019 23CB. Thanks
Old 04-26-2020, 05:16 PM   #12
AirMiles's Avatar
I would leave the old board as is with the 40A fuses. And yes since you are using the Lithium setting (jumper) there's no point in having the charge wizard pendant or new board with the switch and light.
0 nights 0 miles
Which model of wfco do I have? doughpat Batteries, Univolts, Converters & Inverters 22 09-23-2019 06:39 PM
AC and DC Panel Meter Additions to WFCO RonMansfield Batteries, Univolts, Converters & Inverters 1 06-28-2011 12:51 PM
Change-out Univolt for WFCO Bulldogger Batteries, Univolts, Converters & Inverters 10 11-09-2007 08:11 PM
Wfco 9865 Sundance Batteries, Univolts, Converters & Inverters 8 07-15-2007 07:23 PM
wfco 9800? rama777 Electrical - Systems, Generators, Batteries & Solar 6 10-02-2006 10:14 PM
