Old 04-12-2020, 07:32 AM   #1
Water pump
The water pump in our 2019 27’ GT only seems to work smoothly if both kitchen and bath faucets are running at the same time. If just one or the other is running, the pump “thumps” and the water comes out pulsating... defective? Air in the line?
PamK53 is offline   Reply With Quote
Old 04-12-2020, 08:40 AM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Normal
kscherzi is offline   Reply With Quote
Old 04-12-2020, 08:45 AM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I installed an accumulator to help solve for this.
https://www.amazon.com/SHURFLO-182-2.../dp/B000N9VF6Q
wulfraat is offline   Reply With Quote
Old 04-12-2020, 08:52 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The pump is supplying more water than the faucet can handle. The pump is cycling on and off as the pressure builds up and then drops. With two faucets open, the pump is running constantly to keep up with the demand.
Richard
Old 04-12-2020, 09:37 AM   #5
2019 27' Globetrotter
Denver , North Carolina
Yes it's normal and happens for the reason Richard explained. It's worse in some trailers than others but it can be mitigated to some degree.
First and easiest thing to do is make sure your water heater has an air gap, see your water heater manual. This works something like an accumulator.
Consider adding an accumulator as wulfrrat did and/or this pump silencing kit.
Lastly if you have pipes that are rattling and you can access them you can slip a piece of foam pipe insulation over them.
I've done all of the above with fairly good results.
Dave S
link2dks is offline   Reply With Quote
Old 04-12-2020, 09:43 AM   #6
2016 30' Classic
Houston , Texas
Interesting. Where did you install the accumulator?
dhroberts is offline   Reply With Quote
Old 04-12-2020, 09:47 AM   #7
wulfraat's Avatar
Water pump
You can install it anywhere within the pressurized cold water plumbing system. In my case I stuck it under the sink.
ID:	365567   Click image for larger version
Old 04-12-2020, 12:19 PM   #8
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Mine is installed under the bathroom sink
Larry
lsbrodsky is offline   Reply With Quote
Old 04-16-2020, 09:18 AM   #9
mad_mechanic's Avatar
Seattle , Washington
Larry
Hey Larry
Like the idea. You got a picture by any chance?
Best
Thomas
Thomas
2019 Ram Rebel
WBCCI 06370
Region 10
mad_mechanic is offline   Reply With Quote
Old 04-16-2020, 09:28 AM   #10
1976 Argosy 28
Buford , Georgia
I have one out of a '76, just pay shipping and my require some plumbing fittings, but it's all metal (i'm guessing stainless).
strangepod is offline   Reply With Quote
Old 04-16-2020, 09:34 AM   #11
lsbrodsky's Avatar
No pic, sorry. I mounted it to the back of the sink enclosure. Plumbing was simple.
Larry
Old 04-18-2020, 08:45 AM   #12
Larry
Cool. Thanks
Old 04-18-2020, 08:52 AM   #13
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
I also installed the accumulator and the pump silencing kit, both from Surflow. While I was at it I put foam tubing, normally used for insulating pipes from the cold (get it at any big box hardware store) around any of the pipes near the pump that we’re contacting anything else. I did all of this down near the pump, under the hall closet in a 25’.
Makes a significant difference.
daleyocum is offline   Reply With Quote
Old 04-18-2020, 12:31 PM   #14
2019 28' International
Going Where , The Climate Suits Our Clothes
Thanks for the question and the answers. I have the pulsing particularly bad on my bathroom sink. Now I understand why it only happens with the cold water. Now I know how to fix it.
Beerboy is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
