Hello. Is there someone who have a 23 GT twin and no the exact tongue weight. I have to buy a Bleue Ox WD and I not sure between the 550 or 700 lb bars! The Airstream specs. says 525lbs and some video said 591 lbs! Thanks.
The actual tongue weight always varies from the spec. Usually heavier. I'm sure other will chime in, but I'd probably pick the 700 pound bars since you will be adding weight to the trailer when you load up for a trip.
