Old 05-13-2020, 08:36 PM   #1
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Removing the furniture
Anybody got any tip or photos of removing the furniture from your GT. Im getting ready to install Lithium and inverter. I took a very quick look today and it did not look obvious so I thought I would ask before digging deeper.
Old 05-15-2020, 08:11 PM   #2
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
No one else takes their Globetrotter apart?
Old 05-15-2020, 08:16 PM   #3
Downhill502's Avatar
2020 27' Globetrotter
Fredericksburg , VA
lol not yet! I’ll let you go first.
Downhill502 is offline   Reply With Quote
Old 05-15-2020, 08:31 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
It going to happen I’ve just not had much time to explore how they are mounted in. Quick look does not reveal the screws
Old 05-15-2020, 08:42 PM   #5
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
One post about the sink
Ronnie, I remembered this thread about the sink dropping and disassembling the cabinet if that helps: https://www.airforums.com/forums/f54...ng-195077.html
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 05-15-2020, 09:50 PM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Thanks Jeff,
I’m primarily looking at how to remove the seating area with the upholstered backs.
Old 05-15-2020, 10:10 PM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
This is a sign!
Consider rear bed install. room for 800 ah+ - I’ve got two (2) 300ah Victron @112lbs each. BB are lighter lb/ah.
After careful mathematics supporting the very calculated decision to place ~275lbs of equipment under the rear queen bed I’m still at 990lbs static pounds (~11.5% of my wet weight) on the tongue with my 30’ international (basically same layout as yours). Still room for his & her storage bins under the rear bed - we used them for clothes to keep additional rearward weight low.
I left lead acid batts in the box to help tongue weight. ProPride helps too
Frame is well structured to support this weight - I gained the architecture diagrams from AS - there are two cross members right under the batts to support the weight. This is the same shell and frame as the 30’ international which has an additional 1,200lbs GVWR simply due to the dexter axels they use. 30’ floor plan for the international/globetrotter/flying cloud is an excellent, robust and overbuilt platform.
Trailer behaves very nicely with our without the propride.
ID:	367986   Click image for larger version
ID:	367988   Click image for larger version
wulfraat is offline   Reply With Quote
Removing furniture for flooring. Flynavy Floor Finishes 7 03-13-2019 07:29 PM
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 08:34 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
Wood Veneer Furniture Project joshua32064 Cabinets, Counter Tops & Furnishings 5 10-05-2003 12:52 AM
Airstream Article W/Airstream Furniture Photos JaceBeck Our Community 7 08-14-2003 05:17 AM
