Old 12-18-2020, 02:27 PM   #1
Sumterville , Florida
Rear camera monitor mount
Awaiting delivery of 27FBT and have questions regarding mounting of rear camera monitor.
What dash mounting hardware comes with the the monitor, and is it configurable to be compatible with RAM mount hardware.
Thanks.
SVTOTEM is offline   Reply With Quote
Old 12-18-2020, 03:11 PM   #2
2021 30' Globetrotter
Spring , TX
Super strong sucker... works 👍
2020 Ram 2500
mwag is offline   Reply With Quote
Old 12-18-2020, 03:43 PM   #3
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
The monitor should come with a bracket that has a suction cup to stick on your windshield
Castaway is online now   Reply With Quote
Old 12-18-2020, 08:37 PM   #4
Thank you, I thought that was the case. I was wondering if it could be adapted to RAM mount devices. Any idea?
Old 12-19-2020, 05:41 AM   #5
Castaway's Avatar
Celina , Ohio
I have a Ram and have never heard of a mounting device, what is it?
Gary
Old 12-19-2020, 05:52 AM   #6
Ah, not the truck. RAM is the name of the manufacturer of modular mounting devices. Give them a look. Lots of creative uses.
Old 12-19-2020, 08:17 AM   #7
Mollysdad's Avatar
Yes! I spent some time researching and used a few RAM parts. The nice feature is the 1" ball makes a universal type gadget.
I didn't want anything attached to the windshield, and my GPS sits on a dash mount, so I devised a cup holder to arm mount. I like it.
The hardest part was the plate to hold the monitor. I was ready to use Velcro when I found a "4 hole I-grip Amps mount". Your monitor may vary.
Old 12-19-2020, 09:23 AM   #8
2017 19' International
Rosemere , Quebec
Thanks.
You should maybe be getting a VWOS43 Voyager Digital Wireless Observation system- confirm with the dealer-. I don't see the measurements in the owner's manual n(You can download it online). I just stuck my monitor in the left bottom corner of the windshield and dash boar with some Loctite Fun-Tak, it's been holding fine for 4 yrs. It comes with a bracket and suction cup. You can sink up to 4 Cameras to the Monitor. For more info; ASA Electronics 1-877-305-0445. etrailer also carries this Voyager camera.
Projet2907 is offline   Reply With Quote
Old 12-19-2020, 11:10 AM   #9
2015 27' FB International
Seminole , Florida
Monitor mount on windshield
Speaking from experience, in some states, Florida for certain, ( I received a ticket), it is illegal to attach any device to the windshield except for the toll transmitter.The cop says they obscure the drivers vision. I tried but failed to convince the cop that the monitor was below my vision and putting it lower would mean I would have to keep looking down to see what was behind me.
This to me seems to as dangerous as holding a cell phone, which is also illegal in Florida.
GandW is offline   Reply With Quote
Old 12-19-2020, 02:58 PM   #10
Napa , California
In California, it can't be mounted to the windshield, so you have to find some way to do it lower on the dash.
Atwebs is offline   Reply With Quote
Old 12-20-2020, 07:20 AM   #11
Malia20's Avatar
2017 20' Flying Cloud
Oriental , North Carolina
I have a Furrion Backup camera. I went with the RAM Mount Universal Magnetic Power Plate III Holder. Works great and the monitor pops off with a quick twist. The Plate III has two magnets (very strong hold) and the metal plate (double stick-taped to monitor, 1.5"X2") is indexed to the Magnetic Power Plate so the monitor always ends up in the same place. The Power Plate II has only one magnet and is not indexed. I then added a RAM mount Diamond Plate with 1" Ball to join the Power Plate to the RAM arms. A RAM Tough-Mag (66mm) Ball Base holds it all to the dash. Very pleased with the setup.
Safe travels.
Fred
Malia20 is offline   Reply With Quote
Old 12-20-2020, 08:33 AM   #12
Mollysdad's Avatar
I mentioned the 4 hole AMPS mount, because the back of the monitor had the slots for it (sort of, still took minor filing) Then, it just snaps on.
I like your idea also!
Old 12-20-2020, 10:27 AM   #13
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I mount mine to the windshield, but the suction cup seems to have weakened, and fell down a few times. I now have the DILL TPMS, and it suction cups to the windshield.. I may move it to the floor, as I don’t look at all that often.
I was wondering if the rear camera monitor couldn’t just mount to the rear view mirror? All you can see anyway is the front of the trailer.. Anyone tried it up there?
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 12-20-2020, 11:41 AM   #14
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
I made a setup that allows me to hook the monitor over my rear view mirror. I made it out of some pvc gutter material I had laying around and used a combination of epoxy glue and velco to mount it to the mirror. Works great! I look at the mirror anyway to see what is behind me, so it is the natural place to look. It stays where I put it, is out of the way, and plugs into the outlets on the dash.
Flynavy is offline   Reply With Quote
Old 12-20-2020, 12:16 PM   #15
2013 30' Flying Cloud
Kingwood , Texas
I use a $50 WiFi camera with my iPad Velcroed to my rear view mirror. Just a natural movement to see a rear view behind the trailer.
DoubleR is offline   Reply With Quote
Old 12-20-2020, 06:31 PM   #16
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Rear Camera Mount
Thanks.
Just picked up my 2021, 25'FBT FC a few months ago. The hardware, for the inside the cabin mount, is a really good suction cup that works as-long-as the window is clean.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 12-20-2020, 08:50 PM   #17
Thanks for the replies. It looks like Mollysdad and Fred have found RAM solutions and that is the direction I will plan to go. I am interested in Fred’s magnet based approach.
It will be a few months before I pull this together, but I will post a description of the final setup once complete.
Bill
Old 12-23-2020, 10:14 AM   #18
kbmwrs's Avatar
2016 25' International
Morgan Hill , California
For those with late model Ford trucks....in the center of the dash is the flat pocket tray. I cut a piece of wood to fit in that pocket. Painted it. Attached a light piece of flat metal (aluminum) across the top. On the bottom I velcroed (heavy duty) it to the bottom of the tray (sans rubber tray insert). The metal surface now provides a good suction mount for the supplied mounting system. And all this is removable back to normal when not in use.
This is for ANY monitor with suction mounting of course.
kbmwrs is offline   Reply With Quote
Old 12-23-2020, 11:26 AM   #19
Mollysdad's Avatar
I'm slow, but I finally re-read your post and what you asked was if the OEM backup monitor could be adapted to a Ram arm.
In general I'd say, no. But anything can be adapted. There's plenty of aftermarket suppliers that sell interfaces to adapt to Ram. It just takes some time on Google.
Assuming the knowledge base is correct on the 4.3" monitor, it appears to include this suction cup mount. IF it is the same ball size as my GPS, (17mm?.) then you should find RAM parts to provide that ball.
How about downloading the Voyager Manual and see if it mentions the mount?
Rats, I looked online at the manual and it doesn't give any details on the mount.
However, I found a ball adapter that's designed to go from Garmin to Ram.
Might be something to keep in mind for your Voyager mount.
GPS City has the goods.
The size "A" RAM is 9/16".
ID:	385384   Click image for larger version
Old 12-23-2020, 01:23 PM   #20
2018 30' Classic
Jacksonville , Florida
I carry it in a bag in the console until I need it. Fits fine.
Overstreet is offline   Reply With Quote
Voyager WiSight backup camera monitor mount ibosket General Repair Forum 10 08-27-2020 08:06 AM
Voyager bu camera monitor mount broken The Colonel Audio, Video & TV 4 07-18-2017 05:44 AM
rear mount camera AL’ UM- MONEY Audio, Video & TV 3 11-07-2010 06:07 PM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 04:10 PM
Rear View Video Trailer Camera Mount Location chaimemet Towing, Tow Vehicles & Hitches 10 02-07-2008 08:15 PM
