Propane
I added an external shutoff valve for emergency use. The corrugated split loom covers the rubber line from the output side of the Airstream propane regulator to keep UV light off the rubber. Shuts off everything in the Airstream propane system past this point.
This shutoff valve is behind the quick connection so it can shut off the Champion dual fuel generator. It is a design feature that bleeds off propane line pressure as the engine shuts down.
