Old 04-01-2021, 06:45 PM   #1
2004 22' Safari
2019 27' Globetrotter
San Luis Obispo , California
Lithium GP3000 Solar Am I Nutz!
2019 Gt 27'
Added GoPower3000 today👍
Ordered 4 BBs
Thinking about adding to existing factory solar
...then as we were going through the trailer with one lead battery attached confirming that everything worked I realized what the heck was I doing!!
I am putting together a mountain of high class power and the only thing that the inverted batteries power supply feeds is LED lights, TV, and a DVR !
I'm sorry but I think I'm stupid and I'm starting to back off on the 4 batteries and I certainly am not going to add more solar just to power my inside LED lights.
I suppose this is kind of like saying the emperor is not wearing any clothes since this is what we think we need... but do we?
I got so wrapped up in Lithium, solar, and a great CI power supply when I finally came to the realization that I don't need all this just to power led lights!!
Ok I'm really asking what am I missing.
My mech said he could possibly hard wire another dedicated inverter line and outlet to the kitchen counter area and that would at least have some value for larger appliances.
I suppose the non-Airstream folks that load their RV,s roof with solar and storage compartments with lithium probably have a different inverter wiring system than my GT does.
I really wanted it to work out but now I'm thinking only two BB lithiums and no more solar and will save a bundle... hope this helps someone
Boondocking means more than an endless supply of only LED lights and tv
George O'
SLO, Ca
gboneill is offline   Reply With Quote
Old 04-01-2021, 08:50 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Your 30A or 50A Globetrotter can be converted to run everything off the larger 3000W inverter if that’s your goal. I do this all the time.
Using an inverter like a Victron MultiPlus you can pass an entire 30A trailer through it of with the addition of a Smart Phase Selector you can power the entire 50A unit.
It’s not cheap but it can be done and perform quite well if done correctly.
Wiring trailer inverters to a sub panel should in my mind be a thing of the past.
Old 04-01-2021, 11:40 PM   #3
2020 19' Caravel
Ammon , Idaho
In my years of lurking on this forum, it has been my observation that a common method for sizing electrical systems, particularly batteries and solar, is the "install as much as I can fit" approach. If money and weight are of no concern then this method seems to work.
It appears that maybe you are more of the "install what I need" type. Adopting a more practical approach to these upgrades, based math or experience, can reveal that several hundred Watts of solar that maintain as many amp hours of battery capacity may be excessive for a given person.
Of course, individual lifestyles dictate those individual needs and desires so I am not passing judgment here.
OutdoorIdaho is offline   Reply With Quote
Old 04-02-2021, 05:55 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You would have more power to run the furnace and the fans. That is a big deal in many climates.
And to run the fridge if you have the 12 volt compressor kind. And a CPAP.. Do at least 2 lithium batteries.
Old 04-02-2021, 05:58 AM   #5
Dave-n-Janet's Avatar
Moss Point , Mississippi
And don't forget charging the e-bikes and electric coffee maker!
Dave-n-Janet is offline   Reply With Quote
Old 04-02-2021, 06:08 AM   #6
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I'm actually considering doing something similar on the soon-to-be new-to-me 1994 Excella 25.
I had already ordered a Victron Multiplus II 3000 which is a hybrid inverter/charger for use in my motor home. We since decided to downsize into a 25-ft Airstream, and if I install this hybrid inverter in the 25-ft trailer with a few BB lithium batteries it will be possible to run the rooftop a/c from a small Honda 2000 generator. For us, this reason alone makes the install seem worthwhile as I won't have to wrestle with a larger generator or a pair of smaller ones just to have the a/c running. I also plan to switch the fridge to a 12vdc compressor fridge, and the larger battery capacity will mean that we'd be able to go for at least a few days without sun hitting the solar panels and still be okay.
richard5933 is offline   Reply With Quote
Old 04-02-2021, 06:54 AM   #7
2004 22' Safari
Maybe this is my real question...
Thank you for your ideas, for myself I wanted to write out what I realize is my real question.
The globetrotter has eight electrical outlets but only five of them will work off of an inverter. That is probably to protect the three main outlets that might be using more power than the existing inverter can handle. However all eight outlets work off of either shore power or generator so all the outlets can handle it. Now with my Go Power 3000 and numerous lithium batteries I am producing enough power to adequately power those three non-inverter outlets the same as shore power albeit limited. So if I'm right there's going to be a wiring or setting solution to this issue. GP tech support was great during the installation so I think my first call is going to be to them today. I don't see a reason why that device should not be allowed provide power to all 8 electrical outlets the same as any other generator. g
Old 04-02-2021, 09:34 AM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We fitted nine 100 watt AmSolar panels on the roof of the 2014 Classic and five of the same panels on the roof of our 2015 23D International Serenity. We have a 600 amp-hour lithium battery under the front sofa of the Classic and a 300 amp hour lithium battery under the side sofa just forward of the wheel well. Both trailers were rewired with commercial Hubbell 20 amp 120Vac GFI outlets and all are powered through the inverter so any one can be used when off grid.
We replaced both Dometic refrigerators with Vitrifrigo marine refrigerator/freezes that have a Dan Foss freon based compressor that runs off of 12Vdc and we replaced both stock water heaters with a Truma Aqua Go instant on water heater powered by propane only. Both trailers are converted to the newer Dometic CU-434 propane stoves.
Those are just the tip of the iceberg so to speak for the modifications to both trailers.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 04-02-2021, 09:38 AM   #9
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Agree. If you plan to camp mostly off-grid (boondock) during the colder months, then waking up at 4AM in a very cold trailer because your furnace fan has run out of power is no fun (happened to us). That is what led to the install configuration described in my signature. Didn't think I needed the lithium batteries and so far that has been the case.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 04-02-2021, 10:09 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard👍
Disclaimer....I'm odd.
Get two BB's and a converter/charger that will properly charge them and go camping. Up-grade if/when conditions warrant.
Obrigado, é hora de descansar.
Tahawus
Old 04-02-2021, 10:28 AM   #11
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Yep: you can do all that and spend big buck or keep it simple ... below is what we did-
Parts List:
Obviously we began with the batteries. We choose SOK 100Ah 12V LiFePO4 Deep Cycle Lithium Iron Phosphate Battery. We did this for several reasons.
Cost – The price of ALL lithium batteries in Canada are based on the US Dollar which means you add 35%. (Example: a Battleborn is $1000US = $1350CDN). The SOK is $620US – we purchased two = $1695CDN landed/delivered.
Wire Size was our next consideration. Research tells us that the standard 6 gauge battery wire used by RV manufactures including Airstream falls short of requirement. We would be looking at a 10% power loss. Based on distance travelled and amperage the battery wire specification reach was 2 gauge for this installation ($80).
Charger/Converter Upgrade. We have a IOTA multistage system at present. One of the unique design features with the IOTA system is the ability to upgrade (change out) the Smart Charge Controller unit from Lead Acid to Lithium ($35 upgrade).
Safety Circuit Breaker. Baomain ANL-80A Electrical Protection on the positive battery cable between the positive terminal and the existing kill switch ($11).
Miscellaneous. There will be the additional need for lugs, straps, screws, additional wiring, 1/2×1 framing etc. ($25+-) This will be determined once we dismantle the Lounge area in Blue Streak and finalise the instal plan ….
What we will not be installing:
Previously installed AiLi 350Amp Volt/Amp Battery Capacity Monitor + Shunt will be used to monitor the new instal.
Previously installed system Kill Switch.
A DC to DC charger from Red Dragon to Blue Streak. This is really not required as we will not be using our tow vehicle to charge the lithium batteries while we are driving. We have 200w of solar on the roof of Blue Streak which does the job. To protect our Tow Vehicle charge system we will simply pull the 30amp fuse.
A built in Inverter. We have a 300w inverter that we “plug-in” as required to grind our coffee (can’t live with out a fresh grind). We don’t run anything else to warrant a larger inverter. We also carry a Champion 3400 inverter generator which we run on LP should the need arise.
While we know of some folks who spent $16,000.00 to turn their Airstream into a “lithium system power plant”, our budget is $2000.00.
We have previously installed 200w of Solar + MPPT Solar Charge Controller and carry a 160w Solar suitcase (BC has trees)
If you want to see our install go here the-lithium-experiment-introduction/
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 04-02-2021, 10:52 AM   #12
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I am into mine for about $3,000 Canuck bucks. I have:
1 x 250ah GP Lithium Battery.
1 Victron 712 Battery Monitor
1 x GP 1500 invertor with Remote
1 x GP Converter (adjustable to 16V DC output)
1 x GP Shore Switch
Not counting my time to install this stuff.
All my outlets work off AC cord or when running the inverter.
I don't plan on ever running Aircon with out being plugged in. We don't get the heat and humidity over here.
I plan on getting a Victron Solar Charge Controller and about 300 to 400W of newer portable panels this year.
I should be able to run off grid for some time once this setup is complete. Just using the lights, TV and other light power consumers.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 04-03-2021, 10:14 AM   #13
2020 25' Flying Cloud
We like to boondock and the 2 AGM batteries fall short especially if we have to run the furnace. If you plan on boondocking in the fringe or winter season than 3-400 amp of lithium sounds about right to me. I have 360 watts of solar, I add 2 x 90 watts to my existing system, it keeps my AGMs topped off but they still can be down to 30% before the sun comes up and that is not good for the batteries. So I’m planning on adding 300 amp hours of lithium to avoid running out of juice or having to use my generator as often.
Good luck and travel safe,
Mike
mamorteguy is offline   Reply With Quote
Old 04-10-2021, 05:38 AM   #14
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I’m in the group that couldn’t run the furnace for three nights boondocking, without getting the generator out. Two lithiums and we are good to go. We carry portable solar panels bought used. Keeping it as simple as I can. But when it’s cold, I’m running the furnace.
I have no interest, at this time, to beef up the system to run AC off batteries and solar.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Oh Nutz! Andy Moreau General Repair Forum 4 12-01-2016 07:30 PM
Lithium Batt Solar Install 2015 Classic ghaynes755 Generators & Solar Power 54 12-14-2015 12:42 PM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
Leak driving us nutz!!! Anniedog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-04-2009 06:30 PM
