Old 02-10-2020, 02:28 PM   #1
2020 25' Globetrotter
Malibu , California
Lithium batteries inside
Anyone mount them inside under twin bed?
Garfish is offline   Reply With Quote
Old 02-10-2020, 03:26 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i moved to lion and moved them under the bed in my As 22fb
waninae39 is offline   Reply With Quote
Old 02-10-2020, 10:04 PM   #3
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
In my way of thinking thatís the perfect location. It gets weight off the tongue and keeps them warmer. They canít charge below 32 degrees. Hereís my setup. This is fancier than you might be thinking of as it has 500ah of lithium, solar and a hybrid Victron 3000 inverter.
ID:	360911   Click image for larger version
daleyocum is offline   Reply With Quote
Old 02-10-2020, 10:31 PM   #4
Malibu , California
Thanks for the pix. This is under one of the twin beds?
Old 02-10-2020, 11:44 PM   #5
daleyocum's Avatar
Portland , Oregon
Yep, all five of them fit perfectly under the curb side twin of a front bed FC25. That’s handy as well because it’s where the wiring culminates in the infamous rats nest at the head of that bed. That’s where the battery wires from the tongue battery box used to go.
Old 02-11-2020, 08:54 AM   #6
Boise , Idaho
Very nice clean setup.
mtbmitch is offline   Reply With Quote
Old 02-11-2020, 10:03 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
My two Lifepos are under our queen. (and under me too, of course).
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 02-11-2020, 10:38 AM   #8
eagletoo's Avatar
Long Island , New York
Possible dumb question. When the batteries are relocated to under either twin, is there a problem (too much weight) resulting with the AS listing to one side or the other?
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
2022 Globetrotter 23FBT - On Order - patiently waiting arrival
Airstream Club #2600
Iíd rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 02-11-2020, 11:12 AM   #9
Rrys's Avatar
2018 27' Globetrotter
Greensboro , North Carolina
I'm assuming the box sitting in the outside storage compartment is the Victron 3000. I'm seeing only 3 Battleborn Lion Batteries. Those 3 add up to 500 Amp Hours? And I like the battery cutoff you installed!
Was this a do it yourself design or kit or pro install?
Thanks!
Rrys is offline   Reply With Quote
Old 02-11-2020, 12:54 PM   #10
pjshier's Avatar
2017 27' International
Wasilla , Alaska
Looks VERY smart. Are the other two batteries set end-end behind the visible three? Or am I missing something...
And I feel your appreciation of moving weight off the tongue. Our two 6 volts at the effective end of the significant arm described by the distance between the front axle and the coupler is unwelcome.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 02-11-2020, 09:21 PM   #11
daleyocum's Avatar
Portland , Oregon
Thanks!
That’s an older picture when I just had 300ah. I’ve since taken over the smaller cabinet next to it for two more. In the cloudy PNW, 300ah wasn’t quite enough as we use a lot of power with induction cooktop, tea kettle, TV, hair driers, etc. There’s 500w of solar on the roof and another 100w on a portable panel I can move around.
Yes, the blue box in the outside storage compartment is the Victron hybrid inverter/converter/charger. I took out the converter and transfer switch that came with the trailer so the Victron does all of the power management and talks with the Victron Solar controller and battery monitor.
Because of the Victron, I set it up so the rest of the trailer just thinks it’s plugged into shore power. That means all the outlets are live all the time. You just have to keep the overall load under the 3000w the Victron can supply.
I did this myself (I’m an electrical engineer). AMSolar has kits and superb support for those interested. I, however, pieced this install together myself from various sources to save a few bucks.
To answer the question of too much weight on one side, I haven’t noticed any problems. Lithium batteries are about half the weight of lead acid or AGM, about 31 lbs each. They are only about 18” off the centerline of the trailer so that helps. Lithium also means you can mount them inside (no outgassing) and at any orientation, something I couldn’t do with lead acid.
Old 04-12-2020, 06:14 PM   #12
mad_mechanic's Avatar
2019 27' Globetrotter
Seattle , Washington
Lithium inside our 27FB GT
Hey everybody -
Iím the newby here and your battery setups
look awesome. I thought I share our Lithium project which we recently completed in putting one 200Ah Li battery inside the front compartment off our 27FB. If you have any questions pls let me know. I also went with the AMSolar package.
Best regards
Thomas
ID:	365624   Click image for larger version
Thomas
2019 Ram Rebel
WBCCI 06370
Region 10
mad_mechanic is offline   Reply With Quote
Old 04-18-2020, 08:55 AM   #13
Hey daleyocum -
Great looking install. Totally agree with you on AMSolar. They have great customer service.
Best
Thomas
Thomas
2019 Ram Rebel
WBCCI 06370
Region 10
Old 04-18-2020, 09:04 AM   #14
Phase two of our project. Now with solar panels and controller installed. I left space Between the switch and the MPPT for the Cerbo GX.
ID:	366022   Click image for larger version
Old 04-18-2020, 09:37 AM   #15
2018 30' Flying Cloud
Anchorage , Alaska
Originally Posted by mad_mechanic View Post
Hey everybody -
Best regards
Thomas
What size wire are you using to the battery? It looks small to me, but itís hard to tell from the picture.
AKNate is offline   Reply With Quote
Old 04-18-2020, 07:18 PM   #16
Hi there -
6AWG and 8AWG.
Thomas
2019 Ram Rebel
WBCCI 06370
Region 10
Old 04-18-2020, 09:49 PM   #17
Anchorage , Alaska
Hi there -
6AWG and 8AWG.
My factory setup had a 1000 W inverter with a 4 AWG feeding it from the battery and the DC bus bar with a 6 AWG feeding it. If yours is similar and youíre replacing it with a single feed wire from the new battery that then splits out, Iíd recommend using at least 2 AWG. Iím not sure if youíre saying you have a 6 and 8 in parallel, but even that Iíd upsize. 1000 W at 12 V is 83 A, plus your DC loads. Maybe your factory inverter is smaller though.
Iíd also recommend fuse protecting each wire to its ampacity if you havenít.
Edit: I see you have breakers in there, but canít make out their rating. You want them to trip at less than the wire rating.
Old 04-20-2020, 08:26 AM   #18
Hey AKNate -
Thanks for the advise and call outs. I have 30A breaker so my 6AWG is protected. I hardly use the inverter and if only for small loads. But to your point, I will see how it works and potentially upsize the gauge and breakers. Regards Thomas
Thomas
2019 Ram Rebel
WBCCI 06370
Region 10
Old 01-14-2021, 04:12 PM   #19
pjshier's Avatar
Wasilla , Alaska
temps in fwd compartment?
Mad - any info on the relative temps in that forward compartment? Just picked up a couple of LiFePo 100ah units and thinking either the front compartment with a little insulation directed at separating the batteries from the outside compartment door area, or under one of the twin beds in one of the internal accessible storage lockers. Here in AK - the relative temps could be an issue in the shoulder seasons. Thanks!
Old 01-14-2021, 04:20 PM   #20
Scottsdale , Arizona
Is there an upper temp threshold?
Drtrash is offline   Reply With Quote
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
AS 22FB- how many/type of Lithium can be install inside waninae39 Batteries, Univolts, Converters & Inverters 12 03-07-2018 06:47 PM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
