Old 01-14-2021, 04:30 PM   #21
pjshier's Avatar
2017 27' International
Wasilla , Alaska
upper temp threshold
For charging 32F to 131F. Thinking mostly of the lower end: will the front compartment of our 27FBT - maybe with some modification - keep the batteries above 32 if the outside temp drops below overnight for several hours? Assuming the front compartment is closed, of course.
If not - will be planning an install of 2 100ah LiFePo units under one the curb-side twin in the interior-accessible storage locker.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 01-14-2021, 06:09 PM   #22
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi, hereís our recent experience with exactly this issue.
Our 4 100 AH lithium batteries (BB, unheated) are located in the front compartment of our 27FBT.
Earlier this week we had a hard freeze with a low of 24 degrees overnight (it was 30 degrees at 8:00 pm at the start of the night, so Iíd estimate we were below freezing for 12 hours or more).
We had the furnace running at 55 inside, along with a Dyson hot/cold fan to supplement, keeping the front bedroom at about 58.
That night, the temperature in the front compartment did not go below 42 degrees.
We have not added any special insulation or heaters for that compartment, as we currently have no plans to camp in conditions much colder than what I just described.
However, our charger/inverter is mounted in the front curbside exterior compartment, and vents partially into the front exterior compartment, and this may have helped the front compartment maintain heat.
I hope that data point helps as you consider your system.
Best,
Joe
jayseejay is offline   Reply With Quote
Old 01-15-2021, 02:05 AM   #23
pjshier's Avatar
Wasilla , Alaska
Very, very helpful
exactly the kind of real world info I needed. Thanks!
Old 01-15-2021, 01:38 PM   #24
mad_mechanic's Avatar
2019 27' Globetrotter
Seattle , Washington
Hey pjshier -
Don’t have the temp check but I used Low temperature batteries from LiFeBlue.
See link below.
https://www.lifebluebattery.com/rv-b...mperature.html
Best regards
Thomas
Thomas
2019 Ram Rebel
WBCCI 06370
Region 10
mad_mechanic is offline   Reply With Quote
Old 01-15-2021, 02:19 PM   #25
Originally Posted by AKNate View Post
My factory setup had a 1000 W inverter with a 4 AWG feeding it from the battery and the DC bus bar with a 6 AWG feeding it. If yours is similar and youíre replacing it with a single feed wire from the new battery that then splits out, Iíd recommend using at least 2 AWG. Iím not sure if youíre saying you have a 6 and 8 in parallel, but even that Iíd upsize. 1000 W at 12 V is 83 A, plus your DC loads. Maybe your factory inverter is smaller though.
Iíd also recommend fuse protecting each wire to its ampacity if you havenít.
Edit: I see you have breakers in there, but canít make out their rating. You want them to trip at less than the wire rating.
Hey AKNate -
Quick update. I eventually beefed up my wire gauge. Thanks again. I had a brainfart in my calculations. ;-)
Updated pictures attached including peplink CAT18, Cerbo GX and weboost for remote monitoring/wifi.
ID:	387011   Click image for larger version
Thomas
2019 Ram Rebel
WBCCI 06370
Region 10
Old 01-16-2021, 05:40 AM   #26
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I put two 100 a/hr BB lithium batteries in the front storage compartment of our 25GT FBT. We are getting on the road today. Expecting most nights to be below freezing during four weeks on the road. I’ll know soon enough if the batteries can maintain a usable charge. I promised my LW that I would set the thermostat higher than 50 at night, and we would have enough battery power to do it. Going for 55 now. 200 amp portable solar panels for when we stay in the same place long enough to use them. Honda 2000 if the portable panels can’t keep up.
I’m hoping the front compartment stays warm enough to allow the batteries to maintain a complete charge.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 01-25-2021, 05:40 PM   #27
stevejones's Avatar
Traveling to , Arizona
Originally Posted by pmclemore View Post
My two Lifepos are under our queen. (and under me too, of course).
Pat
Ours is in the "back" of the front compartment, which puts them right beneath us in our queen bed, one 300AH LifeBlue on each side. The advantage of where they are at, is the weight is balanced and the impact to storage is minimized. The disadvantage is that in order to replace them, you have to take the top off the bed for full access to the batteries. However this also makes them pretty much impossible to steal.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
stevejones is offline   Reply With Quote
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
AS 22FB- how many/type of Lithium can be install inside waninae39 Batteries, Univolts, Converters & Inverters 12 03-07-2018 06:47 PM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
