Old 09-06-2020, 06:30 AM   #1
2019 25' Globetrotter
rochester , New York
LED bulbs too bright
Has anyone found a bulg replacement that has warmer light or better yet has different color modes such as red or green?
PeteC is offline   Reply With Quote
Old 09-06-2020, 07:49 AM   #2
Grace the Airstream
2020 27' Globetrotter
You might want to find out what they put in the 2021 models. Supposedly they moved toward a warmer tone of led which helps with the brightness.
pdavey is offline   Reply With Quote
Old 09-06-2020, 07:54 AM   #3
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
https://www.amazon.com/gp/aw/d/B011E...b_b_asin_title
These are nice. Put out around 2800 kelvin without any significant color cast. Very comparable to the old tungsten bulbs that were in my trailer.
Ian
Iansk is offline   Reply With Quote
Old 09-06-2020, 08:43 AM   #4
2006 28' International CCD
City , Georgia
I tried a number of the inexpensive LED bulbs like linked above but didn’t have good results. They worked fine at first but developed annoying flicker after low hours of use.
I’m pleased with these bulbs (good color, no flicker). Warm version for general lighting, natural for brighter task oriented lighting.
(I have no clue why the vendor is calling them landscape bulbs??)
https://www.superbrightleds.com/more...ens/2698/7840/
GotTaGo is offline   Reply With Quote
Old 09-06-2020, 09:21 AM   #5
SilverFire
2007 19' Bambi
EUGENE , OR
M-4 is a great source of quality natural light bulbs ann other spectrum bulbs and out perform cheap foreign bulbs from my experience. They have a sale on through September 7th. I replaced all my bulbs with M-4, huge improvement. Copy and paste link below.
https://m4products.com/
SilverFire is offline   Reply With Quote
Old 09-06-2020, 10:48 AM   #6
Los Angeles , California
Has anyone changed the bulbs in a Basecamp?
Amazing thread. I didn’t even think bulb replacement was even possible.
Has anyone attempted this in a Basecamp?
Or does anyone know if it would even be possible?
The basecamp lights are so bright and have no dimmer. I’d like to solve at least one of those issues.
gab
gabt is offline   Reply With Quote
Old 09-06-2020, 11:03 AM   #7
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
We used these amber disc to put over the lenses from the inside. Gives a much warmer light.
http://https://www.amazon.com/WAC-Li...50974282&psc=1
Very easy to do.
Mikebrady62 is online now   Reply With Quote
Old 09-06-2020, 12:25 PM   #8
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
You can get gel sheets, cut out to fit (small circles) and insert into the LED lights, at least it worked on my 2013. A member posted this idea and I went with it. I found the pinks and oranges worked best and in as many layers as you need to reduce the glare. You can get them through StageLightingStore or Amazon.
FE
Is taking it all with you, really getting away from it all?
Fair_Enough is offline   Reply With Quote
Old 09-06-2020, 02:05 PM   #9
Grace the Airstream
gab
Add one of these to your basecamp to replace the switch.
I am going to change the one in the bathroom to this in our Globetrotter.
https://www.etrailer.com/Accessories...BoC1OoQAvD_BwE
Old 09-06-2020, 04:49 PM   #10
So G4 will fit the recessed fixtures?
Old 09-06-2020, 05:13 PM   #11
waninae39's Avatar
2017 22' Sport
NCR , Ontario
you can now get dimmers for LED lights. check amazon or some good electrical/lighting stores . these dimmers only works for better quality LED that support dimming.
many big box stores sell the cheaper LED. easily seen by looking for " not dimmable" on the package
waninae39 is offline   Reply With Quote
Old 09-06-2020, 11:50 PM   #12
2003 31' Classic
Maryville , Tennessee
We had to order the warm led lights.
tjbsilv is offline   Reply With Quote
Old 09-07-2020, 11:06 PM   #13
SilverFire
2007 19' Bambi
EUGENE , OR
Pete-C: Yes, M-4 has led bulbs for the recessed fixtures, bayonet, double pin, short, long & others. I have 24 light fixtures in my trailer (reading lamps, sconce lamps, standard fixtures (bath, closet,& storage compartment), overhead recessed lights, surface mounts lights, and porch light on my Winick Special Edition. If I remember correctly 7 or 8 different styles and M-4 had them all. There were 3 primary spectrums to choose from. Bright led hurts my eyes and although I usually prefer warm led lighting for reading, the natural light spectrum for my eyes (balancing brightness, warmth, & illumination.
Good luck with your choice and selections.
SilverFire
Old 09-08-2020, 05:44 AM   #14
Thanks! That helps a lot. I think the bulbs the factory supplies are bright white.
Old 09-13-2020, 09:47 AM   #15
Mollysdad's Avatar
I was thinking of changing my "scare" light to a red LED.
Does anyone know what bulb fits? And has anyone found a source for red LED's?
I'm not interested in a red gel.
Old 09-13-2020, 11:13 PM   #16
SilverFire
2007 19' Bambi
EUGENE , OR
Red Led Bulbs
I'd select blue over red (2nd link below), so folks don't knock on your door thinking it is a red light invitation (1st link).
https://www.superbrightleds.com/more...QaAoCUEALw_wcB
https://www.superbrightleds.com/more...EaAvzgEALw_wcB
Old 09-14-2020, 12:43 AM   #17
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
There’s an extensive thread on inserting theater lighting gels into the lights. The first post of this thread links to the full CTO gel at B&H Photo but we found that WAY to dense. We settled on the 1/4 CTO.
It’s cheap and easy to do.
https://www.airforums.com/forums/f44...ts-168004.html
daleyocum is offline   Reply With Quote
Old 09-14-2020, 06:57 PM   #18
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
4000k LED
Hi.
I've replaced all my 1156-style bulbs with these.
https://www.amazon.com/SRRB-Replacem...98&sr=8-2&th=1
They are the 4000K natural white color, a nice in between bright white led and yellow incandescent. 4000k is a bit difficult to find. I've been using them for over a year and REALLY like them. they are definitely brighter, I usually only turn on 1-bulb of the 2-bulb light fixtures. I've only had one bulb fail, based on the quantity of bulbs purchased and time used I still feel very good about them. I have a 2003, the color fits the ambiance very well.
My 2-cents!
2003 Safari 25SS
Ahroc is offline   Reply With Quote
Nest outside lights too bright TheHoff Nest 2018 - Current 33 11-01-2020 06:47 AM
Campground's/Camper's Too Bright Lights Jenfm Airstream Lifestyle 121 09-11-2020 05:48 AM
Scare Light way too bright Alovlien Lights - Interior & Exterior 21 12-19-2019 10:23 AM
Rear reading lights too bright? 1jacobo Sprinter and B-van Forum 22 11-06-2018 10:32 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
