Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-04-2020, 11:28 PM   #1
stephdave's Avatar
1969 25' Tradewind
2014 Interstate Ext. Coach
SUSQUEHANNA , Pennsylvania
Inline fuse location for stabilizer jack
Hey does anyone know where the in-line fuse for the stabilizer jacks are? We have a 2019 globetrotter 28fb - only had it 13 months now and now the front left jack will not function at all and you canít manually turn it either!
stephdave is offline   Reply With Quote
Old 07-05-2020, 06:19 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Sorry, not familiar with that model and fuse location. But if you cannot manually extend or retract post, I'm betting you have a bigger problem.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 07-05-2020, 06:25 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you can't manually turn the jack screw with the provided manual crank, all the fuses in the world won't help. Something is seized/broken/bent.
Old 07-06-2020, 06:40 AM   #4
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Following along. Please let us know what’s wrong, and how it’s resolved. As has been noted above, it doesn’t sound like a fuse issue.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19í Bambi, and (11) FC 23FB
GettinAway is offline   Reply With Quote
Old 07-06-2020, 10:30 AM   #5
2019 30' Classic
Belleville , Illinois
Climb under the unit and manually pull down on the arms. They sometimes seize in place. You should be able to manually retract and extend regardless of whether you have power to the stabilizer motors. I have a Classic and the inline fuse is behind the microwave. In my case the motor on the stabilizer itself needed replacing.
Presitla99 is offline   Reply With Quote
Old 07-06-2020, 08:30 PM   #6
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Stephdave, itís possible the jack retracted too far and blew the fuse. Grab the manual wrench that came with the trailer and rotate it counter-clockwise. You may have to lean on it to get it un-jammed.
Hereís a short video about the operation from Airstream Adventures: https://youtu.be/YP3xUdRr6aQ
If it still refuses to come down, youíre still within the 3 year factory warranty.
Let us know what you find!
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Stabilizer Jack Install Location tabney0315 Jacks, Stabilizers, Lifting and Leveling 5 07-05-2017 10:50 PM
What is this and is it important- inline fuse? RichHog Lights - Interior & Exterior 3 09-04-2014 11:21 PM
Inline fuse size off 12v bus NCrider Electrical - Systems, Generators, Batteries & Solar 3 07-05-2010 01:49 PM
Inline fuse holder needs fixin' silversnail Jacks, Stabilizers, Lifting and Leveling 2 05-25-2010 06:37 AM
12 volt inline fuse stops power??? tinbender Vintage Kin 6 07-09-2008 05:37 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
