Old 10-10-2019, 11:31 AM   #1
Parrish , Florida
Hard wired surge protector
Looking for suggestions for where to install my 50 amp EMS surge protector. We have a (new to us) 2018 GT 27Q.
Jimingram55 is offline   Reply With Quote
Old 10-10-2019, 05:26 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
If you can access where the power comes into the trailer and have room to put the unit there, that is my suggestion. Our 34' has a panel accessible via the rear hatch which matches that area and is where we installed ours. We were then able to run the cable for the display up into the trailer and place it in a semi-convenient area.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-10-2019, 07:48 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Jimingram55, we were lucky enough to visit Jackson Center while our 27’ GT was in production. I happened to take a photo of the street side before the interior was installed. You can see the power coming in and the controller before it was permanently put in place. It might help you visualize where your EMS might fit.
Good luck!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 10-11-2019, 06:16 AM   #4
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
We have a ‘14 Flying Cloud 27fb twin. Same coach as your GT with different trim out.
I mounted our 30 amp surge suppressor under the floor of the center closet. I attached it upside down through the plywood floor/shelf with bolts and rubber isolators. The power cable comes into the coach in this space. I ran a new piece of properly sized romex from the input side of the surge to the power cable inlet, and moved the original wire from the inlet to the output side of the surge. Worked like a charm.
Your coach probably has 50 amp service, but same concept. If you’re not trained in electrical, I suggest a licensed electrician do the install for you.
Hope this helps.Click image for larger version
ShinyPete is offline   Reply With Quote
Old 10-11-2019, 09:13 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The only two practical locations are at the power connector and behind the converter / charger (assuming those are two different locations ).
The converter / charger is not all that hard to pull out. Indeed disconnect the battery and shore power first. Past that it's a couple screws and likely a wire or three. Maybe 15 minutes if you get distracted. Once it's out, you will have a pretty good idea of just how much space you have.
Old 10-11-2019, 09:25 AM   #6
RJJ
RJJ's Avatar
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg , Florida
My 30 amp EMS is installed in the converter area. The remote pendant is on the wall above. Very convenient to keep an eye on my amp usage. 👀��
RJJ is offline   Reply With Quote
Old 10-11-2019, 09:58 AM   #7
2018 27' Globetrotter
Maple Valley , Washington
We have the same model/year trailer. I mounted the EMS under the closet floor, there was a perfect place there to put it. Pull open the panel below the closet door with the heater duct vent. You can see the power inlet from there, and the power wire had plenty of slack to reach the EMS. Ours had nothing installed on the floor inside that compartment, and the EMS fit in perfectly.
We installed it in the line between the side power inlet and the electrical panel. This does not protect the line coming from the power inlet at the front of the trailer.
jec1 is offline   Reply With Quote
Old 10-11-2019, 10:01 AM   #8
2010 19' Flying Cloud
2020 25' Globetrotter
Fayettville , Georgia
Jackson Center
Good luck!
Jeff
Jeff
We have ordered a new 2020 25’ GT and have considered going to the factory to watch it in production. Did you enjoy it? Did you get to have any interaction with the line workers?
Mike
Mike1948 is offline   Reply With Quote
Old 10-11-2019, 10:53 AM   #9
cptdzl's Avatar
2018 27' Flying Cloud
Erie , Pennsylvania
same here 2018 FC27FB
Ours is a 50 amp trailer so no issue there and AS did leave plenty of wiring in a big loop that I just split and wired each end to the surge protector. Just a thought (30 amp right) if your front power connector is only used for your generator that power source should be more reliable than the unknown sources from the various campgrounds. Also I "thought" with two connection points there is (should) be a transfer switch? I just looked at my manual and the wiring for the FC 30 does list a transfer switch.
EXPERIMENTAL based on untested ideas or techniques and not yet established or finalized
Rick & Becky #28279
2018 FC27FBQ
2021 RAM 2500 Hemi 6.4
KD3OBX 146.520
cptdzl is offline   Reply With Quote
Old 10-11-2019, 11:18 AM   #10
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
Pro and cons for having an installed surge suppressor:
Pros:
1. hidden from eyes... no more eyesore.
2. no more hooking it up every time you camp
Cons:
1. when it blows, you have to replace it. hire an electrician again.
2. more expensive: electrician fees and every time when it blows.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 10-11-2019, 12:43 PM   #11
jeffmc306's Avatar
McHenry , Illinois
Originally Posted by Mike1948 View Post
Jeff
Mike
Mike, we really did enjoy the tour experience. You are right up close but there's no real interaction with the line workers. They were very friendly but have a job to do so we politely stayed out of their way.
We should have allowed at least two days for the visit because even though our unit was on the line, we missed seeing it in the final stages by a half-day. The photo I shared was of a similar unit. The production manager managed to track down our serial number and said it was still in fabrication but if we came back the next day it would "make the turn" and be in final assembly. I had to be back to work so they allowed me to take some photos of another GT.
If you go, tell the tour guide at the beginning that you're there to see your new trailer and give him the SN. They'll do their best to track it down and allow you to take photos. I've seen post by other owners who were luckier and got to go inside their unit (end of the work day?) Ask your dealer for the build date and VIN. Then, check back within a week of the build to see if the date changed. Ours was ordered in early December 2018 and hit the line the week of April 1. It only slipped one week from the original build date.
*I did see where Airstream was going to suspend plant tours as they get closer to moving into the new building so check with your dealer / call Airstream to confirm.*
Good luck and hope you can go!
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 10-11-2019, 03:46 PM   #12
Our manual does show a transfer switch, and in our manual packet we have a manual for a WFCO T-30 automatic transfer switch. By default, the switch passes power through the side inlet (shore power), and if power is applied to the forward inlet (generator power), it automatically switches to that source in 20-30 seconds. We have never had a reason to use the forward power inlet.
Old 10-11-2019, 04:52 PM   #13
Jeff
Thank you very much for your reply. Our dealer is going to let us know the build date and serial number and will make sure to contact the tour department before I take off. We took the tour a few years back. This will be our second AS.
On another note I plan on using an external surge protector. Have you ever used one?
Old 10-12-2019, 07:27 AM   #14
Half a Rivet Short
Pros:
Cons:
Hi
Pros:
1) It's out of the rain, snow, mud and dirt. It does not rot away in a couple years
2) It has a nice readout you can see inside the trailer and understand what's going on.
3) You don't have to store it in a (scarce on an AS) outside storage locker
Cons:
It's a DIY job to put it in or do something with it ..... oh my aching back ....
Old 10-12-2019, 01:00 PM   #15
jeffmc306's Avatar
McHenry , Illinois
Jeff
Mike, you are most welcome, glad it was helpful. Yes, I use a Progressive 50a unit: https://www.progressiveindustries.net/ems-pt50x
It saved us on our last trip in a state campground; tripped on under voltage which can be a silent killer of high draw units like Air Conditioners. If you’re getting dual air, Airstream provides a 50a to 30a dog bone. I also picked up a 10’ 30a extension cord for the generator and put the EMS in the middle. Just get a grounding plug for the generator which tricks the EMS from seeing the floating ground on the genset.
Good luck!
Jeff
ID:	354115   Click image for larger version
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 10-13-2019, 09:21 AM   #16
Jeff
Thank you for the heads up on the generator. I have used that very model before but I didn’t ground it. I’m not familiar with a ground plug. I suppose you can buy them from Champion. What did you use?
Mike
Old 10-13-2019, 01:28 PM   #17
jeffmc306's Avatar
McHenry , Illinois
Jeff
Mike
Mike, sure thing! It’s actually called a neutral ground bonding plug. I found one by Southwire at Camping World but you can find them on Amazon too. You can make your own if you want (Google it).
Here’s the one I have: https://rvpower.southwire.com/produc...g-model-44400/
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 10-13-2019, 10:27 PM   #18
Jeff thanks. I glad I ran into you on here. I’ve learned a lot.
Old 10-15-2019, 06:46 AM   #19
2017 25' Flying Cloud
Woodway , Texas
I installed our Progressive 50A behind the breaker panel in our '17 FCFB, i.e., under the bed.
After reading other posters' comments, if I had to do it all over again, I'd probably install it closer to the inlet, near the furnace as there seems to be room there, too.
No worries about the unit failing and having to (un)install it--the sacrificial parts are on a circuit board that slips out of the casing once the cover's removed and the relay or contactor while of Chinese mfg seems fairly robust.
emelaich01 is offline   Reply With Quote
Old 10-20-2019, 01:20 PM   #20
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
Ayup
What emelaich01 said is true, you call Progressive and they'll help you through the process, only a component is replaced and they'll know what to send you.
The rest of the hardware stays in place. You can even call them before you need it and get a back-up component in advance...
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Surge Protector Protector...... terirdh Electrical - Systems, Generators, Batteries & Solar 11 08-06-2020 12:15 PM
Hard wire PD surge protector featherbedder Electrical - Systems, Generators, Batteries & Solar 2 06-01-2019 11:14 PM
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
Hard wired or plug-in Surge Protector Air-Hed Electrical - Systems, Generators, Batteries & Solar 38 06-10-2013 08:59 AM
Are men hard-wired to ignore their wives? yukionna Off Topic Forum 63 02-16-2007 06:04 AM
