Introduction: Newbie to the RV lifestyle, but lived in a 21ft travel trailer full time for 5 years during college (1980-1985) and owned a 28ft sailboat for 15 years. So I'm not completely ignorant about portable living :-)
Have a 2022 Globetrotter 27 FB Twin on order. Manufacturing starts today 4/18/2022 (Yay!
). Hope to take possession sometime in late June or early July 2022.
Tow Vehicle will be 2016 Porsche Cayenne S. Yeah, I've read the 1200 posts in the epic Cayenne, Audi Q, VW Tuareg towing thread, but that's not why I'm engaging the experts here (self declared and otherwise
The topic of the day is Globetrotter carrying capacity (or the lack thereof).
Goal: I want to be able to install a 1200ah LiFePO4 battery bank, 3KVA inverter, ~800W of solar, and also have Ultimate Airstreams install their Grand Lounge+Custom Cabinet+wardrobe upgrade and still have a budget left over for the weight of any personal gear I might need (such as food, clothing, fresh water, folding chairs, gas grill, etc, etc).
Now for some math. The information below comes from a photo of the factory supplied sticker on the side of a GT 27FB Twin that is identical to the one I have ordered (i.e. same options, same floorplan). This information "is not" from the factory brochure.
GVWR = 7600lbs
GAWR Front = 3800lbs
GAWR Rear = 3800lbs
So, GVWR = 2 * 3800lbs = 7600lbs (as it should be)
The dry weight of the trailer as manufactured with factory installed options (w/2nd A/C, battery, propane, etc) = 6674 lbs.
The max cargo rating on sticker = 926lbs. This is exactly = GVWR - dry weight = 7600lbs - 6674 = 926lbs. This is also exactly correct.
Note:
Fresh water tank = 39 gallons * 8.3lbs/gallon = 324 lbs
Grey water tank = 37 gallons * 8.3lbs/gallon = 307 lbs
Black water tank = 39 gallons * 8.3lbs/gallon = 324 lbs
Let's assess a few trailer load scenarios:
Load scenario #1:
If someone is forced to travel with all 3 tanks full for some reason, the total weight would be 955lbs.
This would exceed the GVWR of the trailer "without" any additional owner cargo (food, clothing, kitchen equipment, camping chairs, portable gas grill, etc)
Load scenario #2:
Only the fresh water tank is full = 324lbs
New lithium battery bank (four 300ah LiFePO4) batteries = 83lbs/battery * 4 batteries = 332lbs
inverter + solar cells + heavy wiring would be additional weight on top of the battery weight
Planned Seating and cabinetry upgrades = ~300lbs
Total is much greater than 956lbs without including any owner food, clothing, kitchen equipment, camping chairs, portable gas grill, etc.
Scenario #3:
Fresh water tank is full = 324lbs and no other modifications.
That would leave 926lbs - 324lbs = 602lbs for owner gear.
Only scenario 3 works within the safety rating published via the sticker on the side of the trailer, and even it doesn't leave much room for gear (600lbs or so give or take).
Scenario #1 with a reasonable set of owner gear on board would be prohibited within the weight rating documented by the sticker on the side of the trailer. And I know for sure that there are times when owners have to drive with all tanks full and then dump at their destination or somewhere along the way.
AXLE UPGRADE:
So, I started thinking that an axle upgrade was in order since the GVWR is being defined by the GAWR * 2 (for dual axle trailer) = 3800lbs * 2 = 7600lbs.
I spent quite a bit of time studying Dexter's catalog this weekend.
#10 axles are available with a weight rating range of 2300-4000lbs.
#11 axles are available with a weight rating of 4100-6000lbs.
With a published GAWR on the sticker attached to the Airstream = 3800lbs, the logical conclusion is that the 27 FB Twin GT is using a #10 axle.
So, I contacted the dealer to find out if Airstream could upgrade the axle for me during manufacturing.
I expected the answer to be "No" and I wasn't disappointed as that was their exact reply
What I didn't expect was that the Airstream contact indicated that all Globetrotters that are dual axle (e.g. >=25ft in length) use #11 axles.
Huh?
I ended up talking on the phone with someone from Airstream (I didn't ask if it was ok to use his name in this thread, so I'll refer to him as the "Airstream Guy").
We went round and around on the topic on the phone.
The Airstream Guy said that they are definitely using #11 axles on dual axle trailers and have many trailers on the road for many years without any problems. My position is that information is irrelevant. What matters is what the GVWR is and the measured dry weight of the trailer plus the weight of the load that the owner puts in the trailer. If the dry weight + owner gear weighs more than GVWR, then it's game over.
GVWR for GT 27 FBT = Axle weight rating * 2 (for dual axle trailers) = 7600lbs, so the axles are definitely determining the GVWR weight rating based on the math at the top of the email above.
The Airstream Guy was confident that Globetrotters that are dual axle (25ft and above) are using Dexter #11 axles and that Airstream is using an intentionally conservative rating. He doesn't know what the actual GAWR rating is for the #11 axle that is installed, but is relying on the axle weight range that Dexter puts in their catalog = 4100 to 6000lbs to try and reassure me that everything is going to be ok. Well, I know for a fact that Dexter will custom fabricate axles with lower weight ratings than the ranges published in their catalog for a given axle (e.g. #10 vs #11, etc). So I can't really rely on fuzzy assurances from the Airstream Guy (no offense intended) that the axles are definitely #11 and have at least 4100lb GAWR per axle. And, I really need to know what the exact GAWR rating is for each axle.
I have a hard time with this argument given how much prospective owners scrutinize GVWR in order to choose the right trailer for their tow vehicle limits and intended owner loads. If they were conservative in their published ratings, they become less competitive in the marketplace for RV's.
So, my next challenge is to find someone that has access to a 2022 globetrotter 27 FB twin and take pictures of the Dexter axle serial number and any other markings or stickers on the axle so that I can call up Dexter and find out which axle is on the trailer and what the exact GAWR is.
If you own a GT 27 FBT could you please post the information requested above along with a photo of the weight rating sticker on the side of the same trailer?
I also need to know what tires are installed (the manufacturer, model, and max speed and weight ratings) as those can be limiting factors too.
This is definitely a safety issue.
As you can tell, I'm an Engineer and I firmly believe that the numbers really do matter :-) As does anyone who happens to be on a bridge when it collapses due to a misplaced decimal somewhere.
Can any of the current owners chime in and help gather the axle and tire information requested above? Thanks in advance.
Please be gentle, this is my first posting on airforums
