Well interestingly enough one of the cabinet door hinges separated on us when opening the cabinet. The other hinge and the struts keep the door in place. I just unscrewed the hinges from the door and snapped it back together. Then one of the hinges on the little cabinet under the bed came loose. Hope I’m not chasing these things forever.
Also, the little magnetic switches that turn the lights on in the cabinets are pretty flakey. I have two of them that don’t come on sometimes. Then you have to tap them with something and they’ll work.
And one false start with the awning. It only opened a bit then stopped. We closed it and it opened right up. I’d have paid extra for a manual awning. These things are nothing but a headache especially because we never leave them open at night and close them whenever we leave the trailer. Maybe I’m OCD but I’d hate to see a quick Florida storm whip up and take the awning with it.
Originally Posted by DutchB
First thing is to check to see if the seller received a recall notice and you should check https://static.nhtsa.gov/odi/rcl/202...1V325-9169.PDF
My wife was sitting at the dinette of our 2021 manufactured in July 2020 when I closed the cabinet door and it flew off hitting her on the head. She had a lump and concussion symptoms for a few weeks.
Check out the attached picture and lack of glue adhering to the cabinet and note that it is only glue holding the doors. I would get this addressed right away.
Look to see if your doors are flush. The hinges were not properly adjusted on half of our other doors.
Customer service experience with AS corporate was TERRIBLE. Never even told us they were doing a recall. We found out by a mailed notice even though I saw the news online a month earlier.
AS windows tend to stick to the gasket and I see reports of people trying to open and the windows breaking. I unlatch on inside then go outside and GENTLY use my fingertips to pry the window open. There is a special lube you can use to treat the gasket but seems like it needs frequent application.
